DCI ACRONYMS LIST (Barco) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-30-2008, 06:59 AM - Thread Starter
PRETERNATURAL IMMERSOPHIL
CINERAMAX's Avatar
Quoted: 1672 Post(s)
Liked: 915
Send a message via Skype™ to CINERAMAX
A/V
Acronym for Audio Visual.
go to top
AES
Acronym for Audio Engineering Society.
go to top
AES
Acronym for Advanced Encryption Standard.
go to top
ANSI
Acronym for American National Standards Institute; coordinates the development of U.S. voluntary standards in both the public and private sectors. ANSI has established the standard followed by projector manufacturers for measuring lumen brightness.
go to top
APL
Acronym for Average Picture Level.
go to top
ASIC
Acronym for Application Specific Integrated Circuit.
go to top
Aspect Ratio
The ratio of width to height of a frame or screen. The most common aspect ratios for projectors are 4:3, 5:4 and 16:9.
go to top
ATA
Acronym for Air Transport Association.
go to top
BCR
Acronym for Business Case Review.
go to top
Brightness
The thing that makes darkness go away, measured in lumens on a projector.
go to top
BSI
Acronym for British Standards Institute.
go to top
CBC
Acronym for Cipher Block Chaining mode.
go to top
CGA
Acronym for Color Graphics Adapter. Display standard with resolution format up to 320 x 200 ( = 1,6).
go to top
CGI
Acronym for Computer Generated Image.
go to top
CLO
Acronym for Constant Light Output.
go to top
CODEC
Coder - Decoder or Compressor - Decompressor.
go to top
Contrast Ratio
The ratio of the maximum white to the minimum black level possible for a particular spot on the image with the background light levels factored out.
go to top
DAS
Acronym for Direct Attached Storage.
go to top
Data Compatibility
Relates to the video and computer signal formats the projector is capable of displaying.
go to top
DCM
Acronym for Digital Cinema Master.
go to top
DCI
Acronym for Digital Cinema Initiative.
go to top
DCP
Acronym for Digital Cinema Package.
go to top
DI
Acronym for Digital Intermediate.
go to top
D-ILA
Acronym for Direct-Drive Image Light Amplifier.
go to top
Display Technology
The type of technology used to produce bright, clear images in high resolution. Projectors use many different display technologies such as Digital Light Processing and Liquid Crystal Displays (LCDs) combined with high-brightness lamps and precision optics.
go to top
DLP
Acronym for Digital Light Processing; a data projection technology developed by Texas Instruments using a microprocessor to display bright, colorful images in fully lit rooms. Used primarily in portable and ultra-portable projectors, the DLP chip is the size of a postage stamp and contains millions of microscopic mirrors one for each pixel that hinge on an axis, reflecting light through a color wheel to create your image.
go to top
DMA8
Acronym for Digital Media Adapter (Dolby).
go to top
DRM
Acronym for Digital Rights Management.
go to top
DrSM
Acronym for Distribution Security Manager. The controlling device of the security systems in the distribution process.
go to top
DSM
Acronym for Digital Source Master. A Digital Master created in postproduction from which different versions and duplication masters may be created.
go to top
DTF
Acronym for Digital Tape Format.
go to top
DVD
Acronym for Digital Versatile Disc.
go to top
DVI
Acronym for Digital Video Interface.
go to top
ECB
Acronym for Electronic Code Book.
go to top
EDCF
Acronym for European Digital Cinema Forum.
go to top
EGA
Acronym for Extended Graphics Adapter. Display Standard with Resolution Format up to 640 x 350 ( = 1,83 ).
go to top
Ethernet
A hardware standard used for networking. Often used to connect a projector to a remote PC. Current ethernet standards include 10baseT and 100baseT ethernet.
go to top
ExSM
Acronym for Exhibition Security Manager.
go to top
FC-PH
Acronym for (Gigabit) Fibre Channel Physical and Signaling Interface.
go to top
FPGA
Acronym for Field Programmable Gate Array. Chips with programmable logic.
go to top
FPS
Acronym for Frames Per Second.
go to top
GUI
Acronym for Graphic User Interface.
go to top
HDTV
Acronym for High Definition Television; a high-resolution television standard using an 1125-line broadcast signal.
go to top
HASP
Acronym for Hardware Against Software Piracy. A hardware-based software protection system. HI Acronym for Hearing Impaired. HVS Acronym for the Human Visual System. International Electro technical Commission.
go to top
HDTV
Acronym for High Definition Television. Television standard using a 1125 line broadcast signal.
go to top
ISAN
Acronym for International Standards Audiovisual Number.
go to top
ISO/IEC
Acronym for International Organisation for Standarization / International Electrotechnical Commission.
go to top
Keystone (Keystoning)
The distortion of an uncorrected image projected on a wall or screen, typically shown to be wider across the top and shorter across the bottom, resembling a keystone in a doorway.
go to top
KM
Acronym for Key Management. The process of managing the creation and distribution of encryption Keys that are used for locking and unlocking encrypted content.
go to top
LAN
Acronym for Local Area Network; the local area typically being an office building or technology campus. Great for controlling your projector remotely.
go to top
LCD
Acronym for Liquid Crystal Display; liquid crystals exist in an intermediate state between liquid and solid, and realign under electrical stimulation. Exceptionally slim and lightweight, they are ideal in word processor, computer, and TV displays.
go to top
LCDV
Acronym for Liquid Crystal Light Valve; predecessor D-ILA.
go to top
LCOS
Acronym for Liquid Crystal On Silicon.
go to top
LD
Acronym for Link Decryption. The device that decrypts the link
encryption.
go to top
LE
Acronym for Link Encryption. The device located in the Media Block that encrypts content in real time for a physical link between the Media Block and the projector.
go to top
Leq(m)
Acronym for Loudness Equivalent Measurement System.
go to top
LTC
Acronym for Linear Time Code.
go to top
Lumen
A measurement of the amount of visible light energy that comes from a light source and is perceived by the eye.
go to top
M1-DA DVI
A digital computer cable that allows you to connect an LP335 to a computer that has Digital Video Interface (DVI). This cable is compatible only with digitally enabled projectors, including the LP335. It will not connect to an LP330.
go to top
MADI
Acronym for Multi-channel Audio Digital Interface; therwise know as AES10. An AES/EBU multi-channel digital oaudio interface via a single coax cable.
go to top
MBlk
Acronym for Media Block; the portion of the playback device that encompasses decryption, decompression, and streaming processes.
go to top
MD
Acronym for Media Decryptor;The device located in the Media Block that decrypts the content. Media Decryptor The device located in the Media Block that decrypts the compressed content.
go to top
MIB
Acronym for Mangement Information Base.
go to top
Mini jack
An audio connection interface common on personal cassette/CD players, computers, and projectors.
go to top
MPEG
Acronym for Motion Pictures Expert Group.
go to top
Monitor
A computer display. Like the one you're probably looking at right now.
go to top
MTBF
Acronym for Mean Time Between Failure.
go to top
MTTR
Acronym for Mean Time To Repair.
go to top
Multimedia
An over-used term relating to an electronic device's ability to produce both visual and audio output. The term is used in relation to projectors when describing its ability to receive and produce visual and audio data.
go to top
NAS
Acronym for Network Attached Storage.
go to top
NATO
go to top
Network
Connecting two or more computers and/or networkable devices for data sharing or for remote control of devices.
go to top
NOVRAM
Acronym for Non-Volatile Random Access Memory.
go to top
NTSC
Acronym for National Television Systems Committee; the television standard for the United States, administered by the Federal Communications Committee (FCC). NTSC is 525 lines of resolution transferred at a rate of 30 frames per second.
go to top
Overhead Projector
In ancient history, overhead projectors were used to give presentations. They involved static pages of see-through "paper" on which black images were printed. Historians suggest ancient presenters even used marking pens to write on these transparent pages.
go to top
PAL
Acronym for Phase Alternate Line; the standard color system used throughout Western Europe except in France. PAL-M is the standard system in Brazil. It uses an interlaced format with 25 frames per second and 625 lines per screen.
go to top
PDA
Acronym for Personal Digital Assistant, such as a Palm or Windows® CE device.
go to top
Pin
The connectors used in computer/projector cables. Cables are often identified by the number of pins they contain. A typical computer video cable has 15 pins, and is called a 15-pin video cable.
go to top
PKI
Acronym for Public Key Identification.
go to top
PNG
Acronym for Public Network Graphics.
go to top
Power Down
A modern term for turning something off. Applies most commonly to electronics.
go to top
QSXGA
Acronym for Quad SXGA; Display Standard with Resolution Format up to 2560 x 2048 (5:4 -1,25).
QUXGA
Acronym for Quad UXGA; Display Standard with Resolution Format up to 3200 x 2400 (4:3 -1,33).
go to top
QXGA
Acronym for Quad XGA; Display Standard with Resolution Format up to 2048 x 1536 (4,3 - 1,33).
go to top
RAID
Acronym for Redundant Array of Inexpensive Disks.
go to top
RAM
Acronym for Random Access Memory. An electronic digital data storage device.
go to top
RCA
Also called Composite, RCA jacks are a common connection interface for audio and video sources.
go to top
Resolution
The measurement of a computer screen or projected image measured by the number of pixels wide by the number of pixels high. More pixels per unit of area produce a higher resolution giving more detail in the display of an image.
go to top
RGB
Red, Green, Blue; the chrominance information in a video signal; the primary colors from which all other colors can be construed.
go to top
ROM
Acronym for Read Only Memory. An electronic digital data storage
device.
go to top
S-video
A video connection interface. Also a generic name for Y/C, applied to S-VHS or Beta E.
go to top
SAN
Acronym for Storage Area Network.
go to top
SAWA
Acronym for Screen Advertising World Association.
go to top
SDI
Acronym for Serial Digital Interface.
go to top
SECAM
Acronym for Systeme En Couleur Avec Memoire (sequential color with memory); the color TV system used in France and throughout the Eastern Block Republics.
go to top
SG&A
Acronym for Selling, General and Administrative.
go to top
SIRAC
Acronym for Symptoms - Investigation - Result - Action - Control.
go to top
SM
Acronym for Security Manager. The controlling device of the security system in either the encoding, distribution or the Theatre Play Back process.
go to top
SMPTE
Acronym for Society of Motion Picture and Television Engineers.
go to top
SNMP
Acronym for Simple Network Management Protocol.
SNMP / UDP / 1P
Acronym for Simple Network Management Protocol Over User Datagram Protocol Over Internet Protocol.
go to top
Speaker
A device in a projector that gives life to displayed images by emitting sound.
go to top
Stereo
An audio playback technology that divides sound into two or more sources, creating a more realistic sound.
go to top
Subwoofer
An audio device dedicated to replicating the lowest, deepest sounds ascertainable by the human ear.
SVGA
Acronym for Super Video Graphics Adapter. Display Standard with Resolution Format up to 800 x 600 (4:3 - 1,33).
go to top
SXGA
Acronym for Super XGA. Display Standard with Resolution Format up to 1280 x 1024 (5:3 - 1,25).
go to top
SXGA+
Acronym for Super XGA+. Display Standard with Resolution Format up to 1400 x 1050 (4:3 - 1,33).
go to top
SXRD
Acronym for Silicon X-tal Reflective Display.
go to top
TASA
Acronym for Trailer Audion Standards Association.
go to top
TCP/IP
Acronym for Transmission Control Protocol / Internet Protocol.
go to top
TFT
Acronym for Thin Film Transistor. Technology used in LCD screens, also known as active matrix.
go to top
TM
Acronym for Trade Mark.
go to top
TMS
Acronym for Theatre Management System.
go to top
UHP
Acronym for Ultra High Performance and/or Ultra High Efficiency; a term typically used with metal halide lamps that power ultra-bright projectors.
go to top
UML
Acronym for Unified Modeling Language; OMG's (Object Management Group) standardized way of modular application design.
go to top
Uniform Brightness
Across a lighted surface, uniform brightness refers to the lack of brighter or dimmer areas of a projected image.
go to top
UPS
Acronym for Uninteroptable Power Supply.
go to top
USB
Acronym for Universal Serial Bus; a peripheral connection interface for low-speed devices notable for it's hot-swapability.
go to top
UXGA
Acronym for Ultra XGA; Display Standard with Resolution Format up to 1600 x 1200 (4:3 - 1,33).
go to top
VESA
Video Equipment Standards Association; a computer industry association which regulates video output standards for the SVGA graphics modes.
go to top
Ventilation
Airflow through a projector's internals for the purpose of cooling the lamp, or light source.
go to top
VGA
Acronym for Video Graphics Adatpter; a video resolution equating to 640x480 pixels in size.
go to top
VI
Acronym for Visually Impaired.
go to top
VGA
go to top
VPN
Acronym for Virtual Private Network.
go to top
WAN
Acronym for Wide Area Network.
go to top
Watt
A measure of electrical power. As it pertains projectors, a watt measures the power of the internal speaker.
go to top
Weight
The actual weight of the projector minus power cord, bag, and other optional accessories.
go to top
WQUXGA
Acronym for Wide QUXGA; Display Standard with Resolution Format up to 3840x2400 (8:5 - 1,6).
go to top
WSXGA+
Acronym for Wide SXGA+; Display Standard with Resolution Format up to 1680x1050 (8:5 - 1,6).
go to top
WUXGA
Acronym for Wide UXGA; Display Standard with Resolution Format up to 1920x1200 (8:5 - 1,6).
go to top
WXGA
Acronym for Wide XGA; Display Standard with Resolution Format up to 1366 x 768 (16:9 = 1,77).
go to top
XGA
Acronym for Extended Graphics Adapter. Display Standard with Resolution Format up to 1024 x 738 (4:3 = 1,33).
go to top
XML
Acronym for eXtensible Markup Language. XML is a markup language for structuring arbitrary data. XML was designed to replace HTML, which was deemed too restricted with its fixed set of elements and attributes.
go to top
Sincerely, GC*
rAVe Best ATMOS DEMO CEDIA 2016. HOARDS AWARDS, ACCOLADES, 1ST ART CREDS.,WLD. RECORDS, & HI PERFORMANCE 16-24-32-48 CH. MIDI-PLF CINEMAS WW. - CUSTODIAN HIGH END IMMERSIVE CINEMAS TO SMPTE & ADV. IMAGING SOC. HELP Combat Channel Insufficiency with Altitude 48!*GC = GANGSTA C. genus: cineramus maximus. GC Twitter (Now staging Humanitarian Relief Aide to Great Bel-Air Circuit B-chain & 6P/HDR Projection Famine of 2017)
CINERAMAX is offline
Reply D-cinema Equipment and Theaters
