Barco Vs Christie vs NEC, whats real advantage? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-28-2011, 12:40 PM - Thread Starter
Jon Spackman's Avatar
Hi,
I am needing to install a DCI compliant projector setup for a client in their home, the room is 70ft long and about 30ft wide. The screen is already installed as the room was done and working, but we have been asked to change out the consumer grade projector for a DCI version.
What I want to know is TODAY (as in end of 2011), what are the real world differences in the three DCI capable brands in terms of suing them in a home environment. IE does one have better ability to switch brightness for 3D, or is one easier to operate with Crestron, or does one have auto brightness changeover when 3D is detected (maybe they all do).
Does say a Christie offer advantages in being able to tune it for 2D viewing on a small screen (16ft wide 1.85:1 screen).
Does one brand have easier 4k conversion in the near future?
Are they all fast frame rate compatible?
We want to spec the best unit, but I need to know why one is better than another. If they are.
I realize all these projectors are amazing and there is no bad DCI capable unit, just trying to find some small differences so we can better select a unit to install.
Thank you!
Jon
Just enjoy HD in whatever form you can (Sat, Cable, D-VHS, OTA, HD DVD, or BD).
Jon Spackman is offline
post #2 of 7 Old 11-28-2011, 01:32 PM
donaldk's Avatar
Quoted: 407 Post(s)
Liked: 83
Already thinking of taking them to court, LOL.
donaldk is offline
post #3 of 7 Old 11-28-2011, 02:33 PM - Thread Starter
Huh?
I am trying to find out the benefits the brands offer amongst themselves. I just want some info as to what brand to choose, not get ammo for a legal case.
post #4 of 7 Old 11-28-2011, 04:07 PM
W.Mayer's Avatar
Quoted: 220 Post(s)
Liked: 264
barco have a sealed light engine.
dust the biggest cr. ratio killer is a no issue.
i think barco is the only one that do it.
W.Mayer is offline
post #5 of 7 Old 11-28-2011, 05:28 PM
pokekevin's Avatar
Liked: 102
Originally Posted by Jon Spackman View Post
Huh?
I think he meant how you mispelled use lol
pokekevin is offline
post #6 of 7 Old 11-28-2011, 06:47 PM
donaldk's Avatar
Quoted: 407 Post(s)
Liked: 83
Indeed: 'differences in the three DCI capable brands in terms of suing them'
donaldk is offline
post #7 of 7 Old 11-28-2011, 09:42 PM
Alan Gouger's Avatar
Quoted: 31 Post(s)
Liked: 56
Jon ck out this thread. If the link does not give direct access it is page 7, 2nd post from bottom. The entire thread is worth reading. I run a Barco, series two. The software is very user friendly and intuitive and as Mayer mentioned Barco has a sealed light engine. Christie makes a small footprint 110volt unit that will light up that screen size. Christie also has user friendly control software. NECs software takes a little getting use to but they allow you to use regular cinema xenon lamps.
There are some other toys needed that will make life easier if installing in a non commercial environment. If you have further questions feel free to drop me a PM.
Here is a direct link if the above does not work. Start at the 15th post from the bottom.
Alan Gouger is offline
Reply D-cinema Equipment and Theaters
