Dolby Atmos Theatre System - Page 38 - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #1111 of 1405 Old 06-23-2014, 03:52 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
Originally Posted by Dan Hitchman View Post
Dolby Atmos' white paper spells out the requirements. They recommend surrounds that go down to about 40 Hz as ideal for everything but the front screen speakers.
That means I will have to have woofers too then.
ellisr63 is offline
post #1112 of 1405 Old 06-23-2014, 03:53 PM
Dan Hitchman's Avatar
Quoted: 3561 Post(s)
Liked: 1905
Well, the decoders will have surround subwoofer outputs if you have smaller speakers.
ellisr63 likes this.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #1113 of 1405 Old 06-23-2014, 04:02 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
My problem will be that I will need lighter speakers than my Klipsch Heresy HIPs for the heights as I don't know about the ceiling supporting them with clips, and double drywall. If I can put them in my columns and aim them up I will be fine but then it comes down to having the pinpoint dispersion in a package that is no bigger than my Heresy speakers. The only other option I can think of would be to make a new pair of speakers and use the Heresy drivers in it and add drivers for the heights. Looking at the images for the speaker example I can't image how small the height channel drivers must be... Makes me think they might be using full range drivers like a Bose 901 with a very narrow dispersion.
ellisr63 is offline
post #1114 of 1405 Old 06-23-2014, 04:11 PM
wse
wse's Avatar
Quoted: 2204 Post(s)
Liked: 809
Link please to white paper
wse is offline
post #1115 of 1405 Old 06-23-2014, 04:42 PM
Schwa's Avatar
Quoted: 1122 Post(s)
Liked: 1173
deleted - wrong thread
Schwa is offline
post #1116 of 1405 Old 06-23-2014, 04:55 PM
Liked: 1905
Here you go.
http://www.dolby.com/uploadedFiles/A...ifications.pdf
post #1117 of 1405 Old 06-23-2014, 06:22 PM
OzHDHT's Avatar
Quoted: 953 Post(s)
Liked: 533
So how long will it take for the Krell, Anthem, Lexicon, Classe, McIntosh and the likes to bring ATMMOS to their pre/pro?
I am sure that it will be at least three to five years
Might have to buy a Marantz
+1 was just thinking the same. I just blew off years of Integra and more recently Denon, to move to McIntosh processing. Kind of reminds me of that famous Godfather line....Just when I thought I was out...They pull me back in! Starting to think it's a clever ploy by the Japanese makers to keep early adopters like me buying their products (I do realise they have far more $$ to spend on product development and licensing than the high end makers of course).
Deckard97 likes this.
OzHDHT is offline
post #1118 of 1405 Old 06-23-2014, 08:23 PM
ambesolman's Avatar
Quoted: 1100 Post(s)
Liked: 921
YES!!!
Lol, now I can stop being a d**k about it "not existing" anymore.... I guess.
Bring it! I'm ready for Atmos.
Never change who you are scott
Sent using Tapatalk since the mobile version is still 👎
ambesolman is offline
post #1119 of 1405 Old 06-23-2014, 08:38 PM
wse
wse's Avatar
Liked: 809
So these should be fine then
800D2
- Frequency response 32Hz-28kHz ±3dB on reference axis
http://www.bowers-wilkins.com/Downlo...d_brochure.pdf
wse is offline
post #1120 of 1405 Old 06-23-2014, 08:40 PM
Liked: 1905
Yes! Hang these from the walls. However, there are some premium commercial theaters that can and do have BIG honkin' surrounds.
post #1121 of 1405 Old 06-23-2014, 08:44 PM
wse
wse's Avatar
Liked: 809
These will work for me
http://www.bowers-wilkins.com/Speake...2-Diamond.html
wse is offline
post #1122 of 1405 Old 06-23-2014, 10:00 PM - Thread Starter
Roger Dressler's Avatar
Quoted: 1872 Post(s)
Liked: 1004
I wonder what the specs are for the height drivers... I don't think they will need to be full range... Maybe mids and tweets?
Dolby states:
>>If bass management is used, the surround loudspeakers frequency response (±3 dB) must extend to 90 Hz or lower. The crossover frequency should be set based on the capabilities of the surround loudspeakers, but must not be higher than 100 Hz.<<
The above is in a cinema paper. But as it is fully consistent with existing bass management practice for home systems, it should not pose a problem.
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #1123 of 1405 Old 06-23-2014, 10:12 PM
markus767's Avatar
Quoted: 4254 Post(s)
Liked: 1654
Originally Posted by Roger Dressler View Post
Dolby states:
So we're still looking at speakers that need to have >10" woofers to get to reference SPL without compression and distortion.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #1124 of 1405 Old 06-23-2014, 10:24 PM - Thread Starter
Liked: 1004
The height speakers do not need to be any larger or capable than the main speakers.
post #1125 of 1405 Old 06-23-2014, 10:28 PM
Liked: 1905
Roger,
Do you have any idea if Dolby might be encoding their Atmos Blu-ray tracks (the ones they say are coming this fall anyway) with metadata that can control more than the current 7.1+4 layout? In a sense, future-proofing the mixes if hardware and software come out (hopefully in 2nd gen products) that can add more speaker/sub outputs (maybe via an add-on device)?
post #1126 of 1405 Old 06-23-2014, 10:29 PM
markus767's Avatar
Liked: 1654
The Dolby specs says, "Each loudspeaker and associated amplifier must have a maximum output capability of 99 dB continuous SPL at the reference listening position." and "Each surround array and the associated amplifiers must be able to produce 105 dB continuous SPL at the reference listening position. To meet this requirement for surround arrays with fewer than four loudspeakers, each loudspeaker must be able to produce more than 99 dB continuous SPL."
Markus
post #1127 of 1405 Old 06-24-2014, 12:38 AM - Thread Starter
Liked: 1004
Roger,
It would be fairly pointless to create an object-based audio system that is limited to a set of speakers. I thnk the 7.1+4 constraint is in the current DSPs (and wallets).
As I note, those specs are for commercial Atmos cinemas.
post #1128 of 1405 Old 06-24-2014, 12:46 AM
markus767's Avatar
Liked: 1654
Sure but reference level applies to home theaters as well, no?
99dB SPL at the listening position requires speakers that are capable of 105dB for a listening distance of 2m and 108,5dB for 3m. I don't know many speakers that would qualify.
Markus
post #1129 of 1405 Old 06-24-2014, 12:56 AM - Thread Starter
Liked: 1004
Not for most of us, I reckon. But there are some who go there. The fact remains -- the height speakers are never asked to carry more freight than the mains. The requirements are just the same as any other bass-managed consumer surround speaker. If one is happy with their satellites, those will serve nicely for heights.
ambesolman likes this.
post #1130 of 1405 Old 06-24-2014, 01:02 AM
markus767's Avatar
Liked: 1654
Correct, the heights and surrounds are spec'd at 6dB below the mains. Anyway, there's a difference between sounds-good-to-me™ and uncompressed and undistorted. Anything <10" will most likely don't get you to the latter even with bass management enabled.
Markus
post #1131 of 1405 Old 06-24-2014, 07:32 AM
Liked: 1905
Thanks, Roger. I hope you're right.
post #1132 of 1405 Old 06-24-2014, 09:19 AM
zorg43x's Avatar
Quoted: 31 Post(s)
HTH are you calculating this?
zorg43x is offline
post #1133 of 1405 Old 06-24-2014, 09:27 AM
noah katz's Avatar
Quoted: 1107 Post(s)
Liked: 387
Originally Posted by sdurani View Post
What does that have to do with mounting smaller versions of his horn speakers overhead?
Nothing, my mistake.
A 6 1/2" closed-box driver at ~4 mm excursion gives 108 dB/1 m assuming a XO that's down 3 dB at 90 Hz, and much higher SPL if vented.
Noah
noah katz is offline
post #1134 of 1405 Old 06-24-2014, 09:41 AM
markus767's Avatar
Liked: 1654
Show me a real driver that does that. Look at PA drivers that are made for high SPL. You'll hardly find one.
Markus
post #1135 of 1405 Old 06-24-2014, 09:44 AM
markus767's Avatar
Liked: 1654
Use any of the calculators you'll find online, e.g. at sengpielaudio.com
Markus
post #1136 of 1405 Old 06-24-2014, 09:45 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5973 Post(s)
Liked: 5036
Markus, are you using electrostatics powered with tube amps or something?
Scott Simonian is offline
post #1137 of 1405 Old 06-24-2014, 09:46 AM
markus767's Avatar
Liked: 1654
No, distorted sound is NOT what I was talking about
Markus
post #1138 of 1405 Old 06-24-2014, 10:00 AM
wse
wse's Avatar
Liked: 809
Hello Roger,
Tough to hang B&W800D2 on the walls! Do you think these will work B&W805D2?
wse is offline
post #1139 of 1405 Old 06-24-2014, 10:20 AM
zorg43x's Avatar
Quoted: 31 Post(s)
Common markus, noah katz is aproximately right. I think you are misunderstanding the whole SPL story....
"99dB SPL at the listening position requires speakers that are capable of 105dB for a listening distance of 2m and 108,5dB for 3m."
as you wrote. It's somehow totally miscalculated/misunderstood. Even though, in what distance is then the listener from the speakers?
The 99dB at the listening position, let's say 3m, is capable any decent i.e. 6.5" speaker with average sensitivity, let's say 85dB/W/m, with no more than 50W if I am calculating it correctly...
zorg43x is offline
post #1140 of 1405 Old 06-24-2014, 11:22 AM
markus767's Avatar
Liked: 1654
Err, just like I've said:
Code:
Required SPL   Listening distance   Required SPL @ 1m
99 dB SPL      1 m                   99,0 dB
99 db SPL      2 m                  105,0 dB
99 dB SPL      3 m                  108,5 dB
Not without compression and and/or high level of distortion.
Markus
Reply D-cinema Equipment and Theaters
