Dolby Atmos Theatre System - Page 39 - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #1141 of 1405 Old 06-24-2014, 12:24 PM
zorg43x's Avatar
Quoted: 31 Post(s)
Ok, now I see, how you calculated this.
Compression - you mean thermal?
I am using mostly PA woofers and drivers in OSWG, but even for normal HT speakers those SPLs don't seem unrealistic I would say. But I don't know what is your definition of "high level distortion"...
_______________
My overall opinion about their recommendation od 99dB at listener position is that this is just a recommended high value that the system is then able to deliver a decent sound, at much lower levels most of the time, so not 99dB all the time, just in peaks at most.
zorg43x is offline
post #1142 of 1405 Old 06-24-2014, 01:01 PM
markus767's Avatar
Quoted: 4188 Post(s)
Liked: 1577
6.5" woofer?
Exactly this is where it counts. Dynamic range is important. Same is true for images. You need a tremendous amount of "light" to make an image look realistic. Even if there's just a tiny little reflection coming from a drop of water.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #1143 of 1405 Old 06-24-2014, 03:22 PM
noah katz's Avatar
Quoted: 1094 Post(s)
Liked: 379
Originally Posted by markus767 View Post
Show me a real driver that does that. Look at PA drivers that are made for high SPL. You'll hardly find one.
I used the unremarkable Vifa WR165, which is in no way unusual.
If you're concerned with compression, use a 6" or 8" pro driver, many of which have 5 mm or more xmax.
Not sure it's an issue though; I'd think these would be peak levels with average power being a fraction of that.
Not sure why Dolby says these should be continuous levels.
noah katz is offline
post #1144 of 1405 Old 06-24-2014, 03:27 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5025
Because cinema.
These are all facts pulled from the Dolby Atmos cinema whitepaper.
Scott Simonian is offline
post #1145 of 1405 Old 06-24-2014, 07:50 PM
OzHDHT's Avatar
Quoted: 936 Post(s)
Liked: 521
I was told on good authority by my local distributor, that Steinway Lyngdorf will be unveiling their Dolby Atmos system in the US to vendors in September. I was told where but I'm guessing it will be at CEDIA. I'm hoping they don't take too long to offer an upgrade path to their existing customers, esp given I only just had a room set up with a SL S system.
OzHDHT is offline
post #1146 of 1405 Old 06-24-2014, 09:12 PM - Thread Starter
Roger Dressler's Avatar
Quoted: 1846 Post(s)
Liked: 978
Originally Posted by wse View Post
Tough to hang B&W800D2 on the walls! Do you think these will work B&W805D2?
The answer is the same if you ask yourself if they would work in your opinion as bass managed surround speakers. In terms of SPL, distortion, fidelity. If so, they're good to go.
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #1147 of 1405 Old 06-25-2014, 08:39 AM
thebland's Avatar
Quoted: 1664 Post(s)
Liked: 1003
I assume in a good set up these ceiling speakers ideally would reach reference level? I haven't seen anything on specifications for speakers..
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is online now
post #1148 of 1405 Old 06-25-2014, 08:44 AM
zorg43x's Avatar
Quoted: 31 Post(s)
6.5" woofer?
no, in my fronts but why not? it's always a good thing to have the directivity controlled
For rears I have a 8" almost-pro (Fane 8-225) though, with a non-OSWG, but a (cheap) driver is used too.
I mentioned a woofer, because the limit will be likely in its excursion, not in the tweeter/driver section. And I was mentioning 6.5" as an example which will be sufficient enough for effect speakers. So yes, maybe if you are talking about <40Hz or so, but above let's say 80Hz (my setup) it would not be a big deal for such a woofer size to peak at 108db@1m with tolerable distortion.
Thats why they defined a limit high enough for a normal HT setup. If those Dolby's 99dB were meant as a constant level, then back my pardon, I would decrease the volume anyway
zorg43x is offline
post #1149 of 1405 Old 06-25-2014, 09:15 AM
thxman's Avatar
Quoted: 628 Post(s)
Liked: 654
It may be too early to tell, but which will most likely be the preferred Atmos setup? 7.1.4 or 9.1.2?
thxman is offline
post #1150 of 1405 Old 06-25-2014, 09:35 AM
Dan Hitchman's Avatar
Quoted: 3534 Post(s)
Liked: 1876
Dolby says 7.1.4
thxman likes this.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #1151 of 1405 Old 06-25-2014, 09:59 AM
thxman's Avatar
Quoted: 628 Post(s)
Liked: 654
Thank you.
thxman is offline
post #1152 of 1405 Old 06-25-2014, 10:12 AM
sdurani's Avatar
Quoted: 5068 Post(s)
Liked: 3545
I think 7 speakers around you can give a ring of sound that is seamless enough that adding another pair starts to get into diminishing returns. I wouldn't switch from 7.1.4 to 9.1.2, but I would go from 7.1.4 to 9.1.4. Wides would help, but not as much as a second pair of heights.
Reddig likes this.
Sanjay
sdurani is offline
post #1153 of 1405 Old 06-25-2014, 10:29 AM
Bass Enabler
Liked: 5025
Agreed.
I'll focus on 7.1.4 and then consider future expansion later on when the technology matures.
Reddig likes this.
post #1154 of 1405 Old 06-25-2014, 10:33 AM
Liked: 1876
A lot depends on how much additional information sound mixers will place above you. My guess, from the Atmos I've experienced, is that having the wide front side surrounds (also used in Atmos theaters) would probably be a more useful addition and be utilized more often by engineers. You'd get more precise lateral pans and dialog anchor points as well... ala "Gravity" and "Edge of Tomorrow."
I'd love to see if at least a 9.1.4 configuration was (and still is) part of Dolby's game plan for consumer Atmos. It would also possibly calm the Auro3D crowd that always points out... "Yeah, but Auro gives you 13.1!!"
post #1155 of 1405 Old 06-25-2014, 10:47 AM
markus767's Avatar
Liked: 1577
I agree that wides would be the most important addition but not because of the reason you've mentioned: psychoacoustic studies have shown that reflections (real or artificial) from ±55° are most significant for perceived spaciousness.
Spaciousness means more realism and more immersion. Overhead sounds are just a gimmick in my opinion. Very nice to have but not crucial for a real advancement in sound reproduction.
Markus
post #1156 of 1405 Old 06-25-2014, 10:53 AM
Liked: 1876
Atmos uses the front wide surround arrays for hard pan throughs and off-screen dialog/effects anchor points so there isn't such a big jump from the screen speakers to the side wall surrounds. It's more than just for reflection points. They're also easier for humans to locate due to our ear/brain correlation that has heightened lateral sensations rather than stuff coming from directly above you.
post #1157 of 1405 Old 06-25-2014, 11:16 AM
sdurani's Avatar
Liked: 3545
Lateral pans wouldn't be more precise as more stable (for listeners outside the sweet spot), same way a centre speaker is more for imaging stability than precise localization (those sounds would image at the centre of the soundstage even without a centre speaker). The benefits are small enough that it wasn't worth sacrificing any of the 4 height outputs.
Auro's 13.1 layout still uses a 7.1 base. If you have a 7.1.4 set-up with Auro and want to add a couple of speakers, you can only use them for additional heights. They'd rather do 6 height channels than sacrifice any of those outputs for wides.
Wides would be nice to have, but apparently are a very low priority compared to heights, both for Atmos and Auro.
Sanjay
sdurani is offline
post #1158 of 1405 Old 06-25-2014, 11:27 AM
noah katz's Avatar
Liked: 379
Because cinema.
Cinema just scales up the total sound power required to reach a given SPL.
Peak vs. continuous is a question of crest factor, and to require more continuous SPL capability would mean that cinema soundtracks' are lower.
post #1159 of 1405 Old 06-25-2014, 11:36 AM
Bass Enabler
Liked: 5025
You're right.
I was being a smart ass but I was implying that they might run there gear longer and harder (and with more power) than in the typical domestic environment. Also the specs were pulled from the cinema whitepaper which may not translate as literal for domestic use.
post #1160 of 1405 Old 06-25-2014, 12:26 PM
markus767's Avatar
Liked: 1577
My point was that Atmos uses sides for actually less than they could be used for, namely believable spaciousness.
Markus
post #1161 of 1405 Old 06-25-2014, 12:28 PM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
DeAf ;-) Tech has announced add-on speaker modules...
SanchoPanza is offline
post #1162 of 1405 Old 06-25-2014, 12:29 PM
Liked: 1876
I think I would rather have actual on ceiling speakers.
post #1163 of 1405 Old 06-25-2014, 12:45 PM
Quoted: 197 Post(s)
Liked: 511
Lots of details to be filled in; I'm not taking a promise of Future Firmware. Want some user reports.
Thankfully, we have some pioneer ;-) types here at AVS Forums.
post #1164 of 1405 Old 06-25-2014, 02:04 PM
wse
wse's Avatar
Quoted: 2204 Post(s)
Liked: 806
Yes I am glad I already have a pair of in ceiling speakers VOG right above the seats so it can rain I wonder if I will feel the heat from the sun?
Bower & Wilkins Signature 7NT
I would have loved these but at the time they were not available
http://www.bowers-wilkins.com/Speake...es/CCM8-5.html
wse is offline
post #1165 of 1405 Old 06-29-2014, 12:04 AM
CBdicX's Avatar
Quoted: 1257 Post(s)
Liked: 259
If Atmos will be the same "great succes" as Front High and Front Wide speakers (also a way to sell more speakers) it will be a dead born child..........
CBdicX is offline
post #1166 of 1405 Old 06-30-2014, 07:15 AM
Quoted: 108 Post(s)
Liked: 70
I hope so!
Deckard97 is offline
post #1167 of 1405 Old 06-30-2014, 07:39 AM
Liked: 1876
Originally Posted by Deckard97 View Post
I hope so!
Damn, so no what do I do with my new $15k in speakers?? Put lower fidelity Atmos speakers on top of them? This upgrade sh#t is getting pretty lame....hopefully this gimmick stays in large commercial theaters only. I go for quality speakers over quantity, regardless over the codec.
First it was 3-d and then 4k for TV's, now it's atmos requiring a new AVR and more speakers? What's next and who could afford to upgrade every 3 years? I can't wait to hear a demo of this Atmos setup in an average sized room...I need a good laugh.
Never heard Atmos in a theater, I take it. It can be pretty spectacular. Better listen to a demo of the home version first before you decide no one should enjoy it. You might just run out and want to upgrade... you never know. And the upward firing speaker "modules" are compromises. You should put good, Atmos heights on the ceiling. Hopefully, speaker makers will be releasing matching, wide dispersal monopole ceiling speakers soon that conform to Dolby Atmos specs.
Reddig likes this.
post #1168 of 1405 Old 06-30-2014, 08:39 AM
thxman's Avatar
Quoted: 628 Post(s)
Liked: 654
Nothing wrong with options. Some live and love just 2ch. Some love. 5.1, etc... It would be sad if no new tech hit home theater, . Figure out what YOU want, get it and leave it for what ever time frame keeps you happy. For some Atmos will be night and day, for others hardly noticed, if at all. No rule states any theater must have it "all" to be enjoyed.
My current setup has been running strong for about 5 years with 7ch and I knew (well, speculated ) Atmos was coming. My previous setup lasted me 13 years, I got Dolby Digital (Denon AVR5600) in 1996 when most folks had still never heard of it. I am speaking primary about AVR/SSP and speaker placement, so obviously I have done some here and there with video, etc, but nothing that required changes to the room. For Atmos, I am going to strip down and start again, and my next setup should keep me happy for many years as well.
thxman is offline
post #1169 of 1405 Old 06-30-2014, 08:39 AM
Quoted: 108 Post(s)
Liked: 70
My bad
I'll try to keep my comments to myself next time, and apologize for swaying people against ( Atmos ) it.
If things improve I will give it a listen. I just hope it will integrate well with my current speakers...I plan on keeping those until the end.
Enjoy!
Brian
post #1170 of 1405 Old 06-30-2014, 08:57 AM
sdurani's Avatar
Liked: 3545
I just thought I'd build a final system and be done with it.
Nothing wrong with that. But why would you hope that everyone else be stuck with your limitations?
Sanjay
sdurani is offline
Reply D-cinema Equipment and Theaters
