Dolby Atmos Theatre System - Page 41 - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #1201 of 1405 Old 07-03-2014, 10:16 AM
H8nXTC's Avatar
I was thinking about adding a pair of in-ceiling Polk Vanishing Series LS speakers http://www.polkaudio.com/products/ho...ter/in-ceiling for a Dolby Atmos 7.1.2 system in the near future and was wondering if the pair of ceiling speakers should be installed directly above the listeners or in the midway point of the screen and audience. Searching these diagrams I found that it appears that if there is 2 pairs (4 speakers) they go above the front left and right and the rear left and right, but with just the pair should they go either above the side surround speakers above the audience/sofa (I'm leaning this way, with the sound coming from above) or the midway point (between the screen and the audience/sofa, above and forward of the audience) where the sound would come from if the bounce speakers where used instead of the in-ceiling speakers, but not sure. Anyone have any more detailed and correct documentation?
http://res.cloudinary.com/hrscywv4p/...kikndjyggr.jpg
http://res.cloudinary.com/hrscywv4p/...saxdqywjuh.jpg
H8nXTC is offline
post #1202 of 1405 Old 07-03-2014, 11:35 AM
Dan Hitchman's Avatar
Quoted: 3414 Post(s)
Liked: 1767
You really want a minimum of four ceiling speakers, but they do not go right above the fronts and rears. They're out in the room a bit more. I would wait a little bit because Atmos compatible speakers (and I don't mean the compromised upward firing variety) will start to trickle out here pretty soon. See what CEDIA brings before jumping into the deep end without first checking to see if there's any water in the pool.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #1203 of 1405 Old 07-03-2014, 11:48 AM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
Wonder what Klipsch Pro Speakers are used overhead in Dolby Atmos Theaters?
SanchoPanza is offline
post #1204 of 1405 Old 07-03-2014, 12:00 PM
Liked: 1767
Wide dispersal VBAT surrounds. Looks like a pseudo bipolar tweeter configuration.
http://www.klipsch.com/vbat
post #1205 of 1405 Old 07-03-2014, 12:03 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5285 Post(s)
Liked: 4174
Nearly almost like my Emotiva ERD surrounds.
Scott Simonian is offline
post #1206 of 1405 Old 07-03-2014, 12:21 PM
Liked: 1767
Are those tweeters wired in phase or out of phase? The VBAT's, I believe, are bipolar and in-phase.
post #1207 of 1405 Old 07-03-2014, 12:23 PM
H8nXTC's Avatar
OK, but if you can only install 1 pair of ceiling speakers, then? I read on the speaker manual that they suggest at least 2' distance from the wall. The upcoming $1,700 Onkyo TX-NR1030 receiver can only do 1 pair of ceiling speakers with a 7.1 system. The TX-NR3030 can do 2 pair but also costs about $700 more (plus $400-600 for another pair of 700-LS ceiling speakers is probably more than I or most others would be willing to spend for the additional pair of ceiling speakers). I'm ONLY interested in considering 1 pair of ceiling speakers additional.
H8nXTC is offline
post #1208 of 1405 Old 07-03-2014, 12:33 PM
Quoted: 197 Post(s)
Liked: 511
That would have been my guess; how do you KNOW this, personal observation?
Those might work well with vaulted ceilings...
post #1209 of 1405 Old 07-03-2014, 12:38 PM
Bass Enabler
Liked: 4174
Both, actually. There are toggles on the back near the posts that allows to switch one or both tweeters to be in or out of phase with the midbass.
Lol if one really wanted to you could set both tweeters to be out of phase. Probably with ... odd results. Hmmm.....
post #1210 of 1405 Old 07-03-2014, 12:54 PM
Liked: 1767
Making a best guess since they don't list other surrounds that would easily mount on the walls or ceilings. From their web page:
Virtual Boundary Array Technology (VBAT) Cinema Surround speakers utilize a pair of patented skewed horns for an extremely wide dispersion pattern-perfect as a sound wall for the latest digital sound formats such as Dolby Atmos™.
post #1211 of 1405 Old 07-03-2014, 01:05 PM
Quoted: 197 Post(s)
Liked: 511
Yes, sir, guessed that & read that before I posted the question.
Thank you for your answer!
Anyone KNOW!?
post #1212 of 1405 Old 07-03-2014, 01:13 PM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5071
Anyone KNOW!?
The current information is that the Atmos-enabled modules will work with regular (not vaulted) ceilings. This info is from Andrew Jones, the renowned speaker designer who has designed Pioneer's Atmos modules. If you have vaulted ceilings you will need real speakers up there.
kbarnes701 is offline
post #1213 of 1405 Old 07-03-2014, 01:16 PM
Quoted: 197 Post(s)
Liked: 511
Read that already, friend; but, that was not the answer to my question.
post #1214 of 1405 Old 07-03-2014, 01:54 PM
kbarnes701's Avatar
Liked: 5071
Ah - sorry - I see it now. And have no idea, unfortunately. I misread your earlier post, sorry.
post #1215 of 1405 Old 07-03-2014, 02:10 PM
helvetica bold's Avatar
Quoted: 388 Post(s)
Liked: 242
I have a small apt in NYC. I wonder if there will be small Atmos speaker packages.
Right now I have (don't laugh!) the energy classic 5.1 system. I love it and those little guys pack a punch! If I don't plan to move I guess I could do 5.1.2 w/ the up firing speakers in the future. I know it's not ideal but what alternative do I have!
Atmos is not kind to those with small spaces.
helvetica bold is offline
post #1216 of 1405 Old 07-03-2014, 02:55 PM
Quoted: 197 Post(s)
Liked: 511
Oh, sir, but you DO have a VALID point; may be in vain to try them from the ceiling...
And Thank You for your answer!
post #1217 of 1405 Old 07-07-2014, 04:04 PM
javanpohl's Avatar
Quoted: 533 Post(s)
Liked: 263
Is anybody else struggling to decide if they want 7.1.2 or 7.1.4? Part of me thinks that 7.1.2 would be ideal because you'd have the ceiling speakers right above you. In 7.1.4, they'd be spread out around you. Now, perhaps 7.1.2 could be too easy to localize the speakers but 7.1.4 could diminish the sense of something being directly overhead. My rear speakers, for example are currently at the top of the rear wall, in a .4 setup, the rear portion of the ceiling speakers would not be too off-axis from the rear speakers. The perceived spatial difference could be negligible.
javanpohl is offline
post #1218 of 1405 Old 07-07-2014, 04:11 PM
Liked: 1767
I'd take the four ceiling speaker approach in small to medium sized rooms. They're individual "channels" of overhead sound, they aren't duplicated front and back. If a movie like Transformers or The Hobbit is your thing then you want to be able to recreate movement or panning of sounds overhead. With only one pair of overheads, you cannot recreate that sensation very well.
post #1219 of 1405 Old 07-07-2014, 05:05 PM
sdurani's Avatar
Quoted: 4484 Post(s)
Liked: 2904
True, if you want to hear sounds right above you, place a pair of speakers right above you. However, the downside to a single pair is that you can only get left vs right movement overhead, not front to back. For that, you need two pairs, once slightly forward of your listening position and one slightly rearward of your listening position.
That's not a good, even though they'll be getting different signals, it will still sound like it's coming from the same direction. How high are your ears off the floor when seated (36", 42"?), how high is your ceiling, and how far behind you is your back wall?
Sanjay
sdurani is offline
post #1220 of 1405 Old 07-07-2014, 05:19 PM
boothman's Avatar
Quoted: 59 Post(s)
Overheads
I think a set of 4 NHT ic-4's for the overhead channels would work very well with 3 tweeter array in each.
boothman is offline
post #1221 of 1405 Old 07-07-2014, 05:28 PM
asarose247's Avatar
Quoted: 697 Post(s)
Liked: 454
why or why not would 4 of these in an overhead square of "good " spacing be OK?
I can see that relying on reflectivity from the horns would contribute to "sonicly directive confusion" in as much as the object is have them NOT be so close to the walls as to interfere with sound from the surrounds, rear or side.
that's why it seems co-axe's of a direct nondispersive approach may be more effective
KLH C-180B Indoor/Outdoor 170 Watt Dual Woofer 3-Way Speakers
DescriptionWitness theater-like audio quality while watching your favorite movies within your house with the KLH C-180B speaker system. The 3-Way construction of this KLH stereo speaker is responsible for delivering sharp sound at wider range of frequencies. This KLH home theater speaker features a peak power handling of 170 Watt reproducing louder bass. The 0.63 inch tweeter in this KLH stereo speaker produces higher frequency sound with great clarity. The KLH C-180B is equipped with 5.63 inch of woofer for delivering low frequencies with minimum distortion. You can mount this KLH home theater speaker on your wall or simply keep it on your table either vertically, horizontally or free standing
<div id="buttons">
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #1222 of 1405 Old 07-07-2014, 05:42 PM
Bass Enabler
Liked: 4174
Definitely! wrt use of coax speakers, Will.
These types of speakers splash sound all over. Whether or not that is a goal or if it works well within the intended environment is up to speculation.
You certainly wouldn't want to use multi-polar speakers in a well treated room. Ivan's room, for example.
post #1223 of 1405 Old 07-07-2014, 05:51 PM
sdurani's Avatar
Liked: 2904
It won't help anchor sounds above you by bouncing them off the side walls.
Sanjay
sdurani is offline
post #1224 of 1405 Old 07-07-2014, 06:20 PM
OzHDHT's Avatar
Quoted: 784 Post(s)
Liked: 417
I think some folks are jumping the gun here proposing existing ceiling speaker options (esp ones that don't have the correct dispersion pattern) before any official Atmos certified speakers have been released or formally announced. I'd imagine within a few weeks we'll start to see solid info on what exactly various manufacturers are going to be releasing for Atmos. Certainly by the the time CEDIA rolls around we'll have a pretty decent idea.
Dan Hitchman likes this.
OzHDHT is online now
post #1225 of 1405 Old 07-07-2014, 06:29 PM
wse
wse's Avatar
Quoted: 1980 Post(s)
Liked: 741
Yes I am holding to decide what will be the next move!
wse is offline
post #1226 of 1405 Old 07-07-2014, 06:38 PM
Orbitron's Avatar
Quoted: 479 Post(s)
Liked: 355
As we get further along, photos showing our speaker layouts with user comment.
Orbitron is offline
post #1227 of 1405 Old 07-07-2014, 06:46 PM
asarose247's Avatar
Quoted: 697 Post(s)
Liked: 454
Thank you both, Scott and Sanjay and others for sensible input such as,
SLOW DOWN TURBO.
this will me give a few more months to try and budget for an E-Ticket to Audio Nirvana . . .
I just figured out that I can take the 2 SLX out of the man-cave to have 4 for the tops, IF APPROPRIATE, and
JEESH, Give it a rest.
thank you
post #1228 of 1405 Old 07-07-2014, 07:18 PM
javanpohl's Avatar
Quoted: 533 Post(s)
Liked: 263
I don't see how Dolby could recommend one type of speaker that's going to work "the best" for every theater or preference. It's just going to be like the di-pole vs bi-pole vs-direct radiating argument all over again. Granted, a co-ax in-ceiling speaker will probably work "best", but that's not going to be feasible or ideal in every situation.
post #1229 of 1405 Old 07-07-2014, 07:47 PM
OzHDHT's Avatar
Quoted: 784 Post(s)
Liked: 417
I think they are probably more likely to to specify what types won't work well generally, say ones with incorrect dispersion patterns to be able render Atmos effects correctly. I can see it being more like a certification that technically certain speakers/designs meet the criteria for Atmos reproduction, but it's going to be up to individual or installer to work out which particular speakers and layout work best in a particular room.
post #1230 of 1405 Old 07-07-2014, 07:56 PM
asarose247's Avatar
Quoted: 697 Post(s)
Liked: 454
now its all semantics
there may be a range of characteristics that will deem a speaker or speakers "suitable" within a range of variously configured /suitable for home HT applications to include minimally ,FR, Dispersion characteristics, power handling, etc.
Hopefully a minimally compromised chip/algorithm will do the wrap up, which if along with Audyssey, should be able to give optimally what we want.
Reply D-cinema Equipment and Theaters
