Dolby Atmos Theatre System - Page 44 - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #1291 of 1405 Old 08-24-2014, 08:05 PM
PeterTHX's Avatar
Quoted: 327 Post(s)
Liked: 245
Originally Posted by TimFrost View Post
I know I’m a bit late in this but Peter, you’ve erroneously noted that Atmos is different to Fantasound - I would suggest it is its direct predecessor.
Far from being a multichannel linear system with tracks attached to specific speaker positions in the theatre, the Fantasound audio was recorded optically in 6 discrete channels of instrument groups none of which were allocated to a position in the theatre – you could in fact call them objects (sounding familiar?). Along with these sound objects track, was a separate control track that determined, within the playback system, both the level and the placement of the sound. Isn't that what Atmos achieves?
The only real difference between Fantasound and Atmos is that the former used the newly developed (in 1941) ‘panpots’ which were controlled by geared motors, and Dolby have the advantage of a completely digital chain.
Seems Disney (and Stokowski) were ahead of the game by 60 years , which considering commercial film sound is under 90 years old – is not bad.
Interesting, I've read so many conflicting reports on what Fantasound had/didn't have/setup etc. I'm still not 100% sure how it really worked.
True that it was way ahead of it's time, which really sad when you think of all the potential films it could have been used with until surround was relaunched in the 50s with Cinerama and 'Scope.
You forgot another advantage Atmos has over Fantasound: being used in more than one film
My opinions do not reflect the policies of my company
PeterTHX is offline
post #1292 of 1405 Old 09-24-2014, 12:08 PM
Quoted: 63 Post(s)
Liked: 7
For Dolby Atmos "Artcoustic" with SL Spitfire Series ROCKS THE ROOM!! WOOOW
130db.....
Beats Klipsch and all of those.
The good thing is that to drive these speakers you don't need to spend thousands in Amplification because the speaker is very sensitive.
Having a 300w/channel Amp with separated Processor or a good AV Receiver won't make much difference.
Back_to_the_Sound is offline
post #1293 of 1405 Old 10-17-2014, 04:43 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5069
Originally Posted by Bumper View Post
- What is my Darbee Darblet going to do on this HDMI 2.0 output? I assume it would work but I read issues on backward compatibilities...
Can't wait to find out
My Darbee Darblet works just fine with my Denon 5200.
kbarnes701 is offline
post #1294 of 1405 Old 10-17-2014, 11:37 AM
Bumper's Avatar
Quoted: 135 Post(s)
Liked: 42
Completely forgot I posted this queustion. That's probably why I didn't mention it anymore. Mine obviously also works since I got my unit mid september.
Just got word from my dealer that the TX-NR3030 arrived. He is testing it this evening. Still waiting for Onkyo to arrive at my place to come demo the 3030 against the 5200 and prove that the Onkyo can compete. Can't wait
rmerlano likes this.
Bumper is offline
post #1295 of 1405 Old 10-17-2014, 11:44 AM
wse
wse's Avatar
Quoted: 1976 Post(s)
Liked: 739
Originally Posted by g_bartman View Post
I will need to figure out where to place 4 Atoms in ceiling speakers within the next few months. I'm doing a 7.2.4 system. Looks like I'm going to use the Hsu in wall speakers at this point. From the diagrams I have seen, it looks like the front 2 are at the same width but a few feet in front of the main l/r and the rears a rat the same with as the sides but between the sides and rears. Does anyone know if that is right? I am having a house built and HAVE to use their contractor to install the speakers. Won't be doing Atmos right away, will be down the road. Any help is appreciated
Here you go
http://www.dolby.com/us/en/guide/dol...-4-setups.html
ATMOS seems to be very forgiving
wse is offline
post #1296 of 1405 Old 10-21-2014, 12:39 PM
CCSchoch's Avatar
Quoted: 191 Post(s)
Liked: 32
Originally Posted by wse View Post
I am just beginning to look into Atmos. Currently I have a 5.2 setup.
My room doesn't allow for rears, but I could put in 4 ceiling speakers to accommodate a 5.2.4 if I went to a Atmos receiver.
Current Setup
Fronts Axiom M60's
Center Axiom VP180
Surrounds Axiom QS8's (left and right of couch about 12 feet from front of room, no wall behind me, opens up to kitchen)
Subs Dual SVS PC13 Ultra (Front left and right corner)
Some beginner questions.
1. First, for those who currently have Atmos installed at home, is the improvement that noticable?
2. What will a receiver do with non atmos encoded blu rays. Will is just play sound in the normal 5.1 setup and the ceiling speakers will be ignored, OR will it re-direct sounds so the surround sounds get split up between the surrounds and the Atmos in ceiling speakers?
3. If I install 4 ceiling speakers, from the diagram above at Dolby, it looks like you should install them relatively close to the rear surround speakers...a couple in front of a couch and a couple behind a couch (which BTW is my setup...I have 1 listening position w/ a couch...by surrounds are to the left / right of the couch).
I thought I seen a diagram a while ago that showed 2 front Atmos speakers toward the front of the room and 2 Atmos ceiling speakers at the rear of the room. But from the diagram above it looks like all 4 are toward the rear of the room.
Which setup is preferred / correct?
Thanks for any assistance!!!
CCSchoch is offline
post #1297 of 1405 Old 10-21-2014, 03:43 PM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
Current Setup
Fronts Axiom M60's
Center Axiom VP180
Yes.
That's up to you. Atmos and the new Dolby Surround upmixer are separate functions. Atmos decodes Atmos-encoded soundtracks. DSU upscales non-Atmos soundtracks to use (almost*) all of your speakers. DSU is one of maybe a half-dozen playback options available. Two of them are "legacy" upmixers (DTS Neo:X and Audyssey DSX). Others can leave the incoming decoded soundtrack unmodified, down-mix it to stereo, etc. (Almost* = Front Wides are not used. But you wouldn't have FW if you nave a 5.2 configuration.)
Right. There are 5 overhead positions. You seem to be describing the two pairs closest to the seating, which are called Top Front and Top Rear.
I don't know which picture you're looking at, so I can only guess that it's a trick of perspective. The 5 allowed overhead positions are called (from front to back) Front Height, Top Front, Top Center, Top Rear and Rear Height. You can use any two of them, so long as they're not adjacent to each other.
That's very much up to you. Top Front + Top Rear probably are the most appropriate if you're going to be using in-ceiling speakers.
From your comments, I'm guessing you might not have seen the oft-posted speaker placement diagrams that D+M provides in their Denon and Marantz manuals. See below.
ID:	323377   Click image for larger version
Selden
Selden Ball is offline
post #1298 of 1405 Old 10-22-2014, 05:59 AM
CCSchoch's Avatar
Quoted: 191 Post(s)
Liked: 32
Thanks for all the info!!! Here's the 5.1.4 diagram I was looking at on dolby. Sounds like I can setup exactly like this to surround the seating area with 4 ceiling speakers and my two surrounds, or I can pull two of the ceiling speakers more toward the front of the room, correct?
I think I would probably just leave it as the diagram shows. Only issue is I have two can lights in the ceiling to work around too...but I can probably make it work out.
Thanks again!!!
CCSchoch is offline
post #1299 of 1405 Old 10-22-2014, 08:41 AM
Liked: 1494
Dolby's guidelines for home speaker systems are quite generous, so your plan should work fine.
p.s. This is intended to be the thread for discussing Atmos in commercial theaters, not for in-home installations. Sorry I didn't notice that before writing my initial reply. Home theater questions would get more responses in the thread The official Dolby Atmos thread (home theater version)
Selden
post #1300 of 1405 Old 10-22-2014, 10:41 AM
CCSchoch's Avatar
Quoted: 191 Post(s)
Liked: 32
Oooops, didn't even realize this. Thanks for the direction!!!
Wish I could move it over, don't feel like re-typing.
CCSchoch is offline
post #1301 of 1405 Old 10-22-2014, 07:41 PM
PRETERNATURAL IMMERSOPHIL
CINERAMAX's Avatar
Quoted: 1672 Post(s)
Liked: 915
Send a message via Skype™ to CINERAMAX
Is living with Dolby Atmos worth the faff?
Gary J and ambesolman like this.
Sincerely, GC*
rAVe Best ATMOS DEMO CEDIA 2016. HOARDS AWARDS, ACCOLADES, 1ST ART CREDS.,WLD. RECORDS, & HI PERFORMANCE 16-24-32-48 CH. MIDI-PLF CINEMAS WW. - CUSTODIAN HIGH END IMMERSIVE CINEMAS TO SMPTE & ADV. IMAGING SOC. HELP Combat Channel Insufficiency with Altitude 48!*GC = GANGSTA C. genus: cineramus maximus. GC Twitter (Now staging Humanitarian Relief Aide to Great Bel-Air Circuit B-chain & 6P/HDR Projection Famine of 2017)
CINERAMAX is offline
post #1302 of 1405 Old 10-23-2014, 05:54 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
Incremental benefit at big expense for the HT. I'm sticking with 7.1. It's more for commercial theaters.
Gary J is offline
post #1303 of 1405 Old 10-23-2014, 11:08 AM
CINERAMAX's Avatar
Liked: 915
But what about the soundhole above you?
Sincerely, GC*
post #1304 of 1405 Old 10-23-2014, 11:16 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
again incremental. Cost/benefit not there for me, maybe you.
Gary J is offline
post #1305 of 1405 Old 10-23-2014, 04:28 PM
Quoted: 833 Post(s)
Liked: 174
Originally Posted by CINERAMAX View Post
I read that article... He doesn't understand that just because it's HDCP that doesn't make it more future proof than non HDCP units. Units like the Denon have faster processing capabilities. For whatever reason I think there is a trade off between going HDCP & processing power. I don't rule out that there could be a fair amount of planned obsolescence involved between all the AVR manufacturers.
However... anything to make 4k worthwhile won't be around for at least a few years (HDR content / content graded with expanded color gamut)... unless if you are a 4k nut there really isn't much benefit known about to going 4k for a while. Sure, people could buy the Vizio R series, but what will they beable to watch on it that's graded for HDR?
For me personally, the Atmos upgrade was worth it... I was still stuck on 5.1. I can understand if someone doesn't want to upgrade from 7.1... however, the upmixing I can assure you is quite amazing.
I am ticked off about the lack of (good) Atmos content for home... but it's not enough to make me regret being an early Atmos adopter, quite simply because this was a huge upgrade for me and movies sound like 10x better on this system. I got the 7.1.4 setup, on a lot of older movies I do hear height information, and it isn't subtle.
Aras_Volodka is offline
post #1306 of 1405 Old 10-23-2014, 04:30 PM
Quoted: 833 Post(s)
Liked: 174
Atmos isn't just for commercial theaters btw... while there are some things that can't be done at home yet vs. the theater... I heard an improperly installed 5.1.2 Atmos demo @ Best Buy... the demo wasn't bad compared to the theater.
post #1307 of 1405 Old 10-24-2014, 07:10 AM
CCSchoch's Avatar
Quoted: 191 Post(s)
Liked: 32
I am on a 5.1 still too (well, 5.2 if you take into acct I have dual SVS's )
Sounds like that for peeps on a 5.1, the Atmos is a nice upgrade, but for peeps already on the 7.1 or 9.1 train, not so much. Fair statement?
When you say upmixing, does that mean that the AVR will take non Atmos soundtracks on CD's or BluRays and utilize the new Atmos speakers I install in the ceiling? I have an Onkyo Receiver now so would most likely stick with Onkyo, Maybe move to Denon. So they'll have pre-set sound selections to utilize the Atmos speakers?
If I make the jump, I'd install 4 ceiling speakers to go to a 5.1.4 system. I thought I read on another thread that on a Onkyo receiver that only 2 of the atmos speakers can be powered with the AVR, and the other 2 have to be powered with a seperate amp.
Is that accurate?
Thanks for any assistance.
CCSchoch is offline
post #1308 of 1405 Old 10-24-2014, 08:30 AM
Liked: 1494
That's what the new Dolby Surround upmixer does, yes.
Is that accurate?
Your home Atmos questions would be better answered in the Home Atmos thread. The official Dolby Atmos thread (home theater version)
I think you might be confusing Onkyo's Atmos receivers with D+M's.
Selden
post #1309 of 1405 Old 10-24-2014, 08:39 AM
CCSchoch's Avatar
Quoted: 191 Post(s)
Liked: 32
Apologies again, I thought I was in the home theater section again.
CCSchoch is offline
post #1310 of 1405 Old 10-24-2014, 08:43 AM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2900
Depends on how those 7.1 or 9..1 speakers are configured. If none of those speakers are used as heights, then Atmos would be a nice upgrade, since it will give those peeps overhead imaging that they're not currently enjoying.
Sanjay
sdurani is offline
post #1311 of 1405 Old 10-24-2014, 10:55 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5283 Post(s)
Liked: 4167
Scott Simonian is offline
post #1312 of 1405 Old 10-24-2014, 12:26 PM
sdurani's Avatar
Liked: 2900
Sanjay
sdurani is offline
post #1313 of 1405 Old 10-24-2014, 02:16 PM
Quoted: 833 Post(s)
Liked: 174
Is that accurate?
Yes... I'm not sure about CD's but yeah... 5.1 mixes sound so much better in Atmos, it will send information to the height speakers... better yet if it's a TrueHD disc. K Barnes wrote a good review of the upmixing in his impressions of the X5200W, maybe ask him if He can show you the post.
Depending on what your budget & space is... I'd recommend going 7.1.4 so you can add rear surrounds... it adds so much to the dimension of the sound... but I understand some rooms don't allow for space behind the listening position. I reoriented my living room just so I could go 7.1.4, I now have a sideways half section of a couch facing me (haha)... but it's sooo worth it.
The cheaper Atmos onkyo units only do 5.1.2. I think the cheapest unit that can do 7.1.4 is the Denon... if you do go Atmos I'd recommend the X5200W if you can spare the cash. JDsmoothie might be able to work out a deal for you... I got mine from him. I went from a Yamaha HTR 5830 to that... the difference was not subtle!
post #1314 of 1405 Old 10-24-2014, 02:18 PM
Quoted: 833 Post(s)
Liked: 174
Is that accurate?
Oh and yeah you need an external amp to use all 4 heights in the Denon or any other high end .4 system... the reason why is AVR's simply wouldn't be able to add more pre-amps due to power consumption (I think). So you get something like the AMP-100 to power 2 of the 4 height speakers... or whatever you want to use it for with the amp assign in the Denon.
post #1315 of 1405 Old 10-24-2014, 02:31 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
The ear level surround format is also a factor (i.e. 5.1 vs. 7.1 or higher). The Denon X4100W requires a 2-ch amp if you want a 5.1.4 setup as the receiver only has 7 internal amps. The X5200W can do 5.1.4 without an external amp since it has 9 internal amps. Of course, moving up the chain to a 7.1.4 setup would require an external amp and you are of course limited to 9.1.2 due to the 11-ch max on this model. A lot of members on the Dolby Home Theater thread are waiting for an "affordable" AVR/SSP that does 9.1.4 or higher. I suspect this could come with the first ground up Atmos (or Auro) designed unit. Most of the units announced this year are last year's model with some upgrades that fit the current footprint.
jkasanic is offline
post #1316 of 1405 Old 12-19-2014, 08:14 AM
rramacha's Avatar
Quoted: 118 Post(s)
Liked: 33
Speaker Selection for Atmos and Aurora
Hello All
I am also considering installing new speakers and wiring before AV8802 is released.
I currently have a 5.2 system
AV8801
Front Left and Right Klipsch RF 7II
Center Klipsch RC 64II
Surround JTR Slanted Single 8's.
Two Seaton Subversive HP+ in the front.
I am planning to add two slaves to Seaton next year and spread them between front and back.
Now I am trying to see for front heights and Rear Surrounds if I can use Airmotiv 6 or Stealth 6 from Emotiva or should I stick with JTR's for this.
What speaker options do I have for in ceiling speakers and Voice of God Speaker.
I am eventually planning to replace Fronts and Center with Catalyst 12C.
Cheers
Raj
rramacha is offline
post #1317 of 1405 Old 12-19-2014, 12:06 PM
PeterTHX's Avatar
Quoted: 327 Post(s)
Liked: 245
Anyone please help:
Anyone in the LA area, is there a theater that is playing "The Hobbit: Battle of the Five Armies" in *both* HFR and Dolby Atmos?
I thought I found one at Arclight Sherman Oaks, but the current showtimes are just listed now as HFR 3D, not Atmos. I tried to call but the person on the phone was less than helpful. Too uncertain for a 70 mile drive.
PeterTHX is offline
post #1318 of 1405 Old 12-22-2014, 07:28 PM
FilmMixer's Avatar
Quoted: 1723 Post(s)
Liked: 2084
Originally Posted by PeterTHX View Post
Anyone please help:
It is in theater 1 (the biggest theater there) in HFR and Atmos.
FilmMixer is offline
post #1319 of 1405 Old 01-01-2015, 07:41 AM
zimmo's Avatar
Quoted: 128 Post(s)
Liked: 44
I finish my installation.
my room is 11x20 x 8
now i have 7.5 .4
onkyo tx-nr3030
4 speakers in ceilling Yamaha ns-ic800
6 monitor 9 paradigm
1 center cc390 paradigm
4 subs ikon 15 inch
1 buttkicker lfe
bluray sony bdp-790
when i play transformer and the expendables wowowow,this recever av onkyo tx-nr3030 its move they air
zimmo is offline
post #1320 of 1405 Old 01-05-2015, 06:52 AM
CINERAMAX's Avatar
Liked: 915
now i have 7.5 .4
onkyo tx-nr3030
4 subs ikon 15 inch
1 buttkicker lfe
bluray sony bdp-790
HOW ABOUT THIS 13.4.10?
Sincerely, GC*
Reply D-cinema Equipment and Theaters
