Dolby Atmos Theatre System - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #181 of 1405 Old 05-02-2012, 07:45 PM - Thread Starter
Roger Dressler's Avatar
Quoted: 1719 Post(s)
Liked: 871
Originally Posted by iansilv View Post
Would it be accurate to describe Atmos as almost like a 'resolution enhancement' in terms of sound spacialization? As in, a helicopter sound has to move from the front of the room to the back. Atmos can do it with a standard 5.1 configuration, or it could take advantage of 16 speakers along the ceiling by moving the same sound through those speakers... So it just increases the 'resolution' of the sound panning front to back by using more speakers to fill out the movement, like more pixels in a television...
Exactly. Not only more pixels, but pixels in places there were none before.
Deadwood II Theater
Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #182 of 1405 Old 05-02-2012, 10:42 PM
noah katz's Avatar
Quoted: 1032 Post(s)
Liked: 364
Originally Posted by sdurani View Post
That's because they aren't similar: one is an object-based mixing/rendering system while the other is room correction.
I was going to take issue with this under the assumption that you meant RC = EQ, but under the expanded definition of spatial correction I see your point.
Originally Posted by Roger Dressler View Post
Not really the same thing, though, in my understanding.
First, there is no Trinnov encoder...
True, but there's no encoded material today nor will there be any significant amount for some time to come.
...And not just for 7 sounds (speakers), but for every individual sound object in the program.
This makes me realize I'm not at all clear on just what a sound object is; is it a sound or group of sounds which always emanate from the same location (relative to each other, not space)?
Noah
noah katz is offline
post #183 of 1405 Old 05-02-2012, 11:37 PM
markus767's Avatar
Quoted: 4071 Post(s)
Liked: 1489
A sound object is simply a sound file with additional meta data. The meta data defines where the sound should emanate from within a three dimensional space.
The renderer decides how that data is used within a given speaker layout. It could use the nearest speaker or try to build phantom sources between two and more speakers or use more advanced techniques that try to create a wave field.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #184 of 1405 Old 05-03-2012, 02:10 AM - Thread Starter
Liked: 871
What I meant by "there is no encoder" is there's no tool or algorithm to create encoded dynamic spatial signals for a Trinnov renderer. All the other 3D systems have renderers designed and in operation.
Deadwood II Theater
post #185 of 1405 Old 05-03-2012, 10:29 AM
FilmMixer's Avatar
Quoted: 1925 Post(s)
Liked: 2389
To elaborate for Noah....
The metadata isn't static.... it does define where the sound emanates within the listening environment, it can dynamically change (for an easy example the object could be a helicopter sound effect that flies all across the room...)
You can also use, for example, 5 objects that would be a 5 channel music spread that you you can put on the walls and in the overhead ceiling speakers and you can plea them there as a static object that doesn't move over time.
What's important in Marcus' point to understand is that this metadata information can then be used by the renderer to "map" the original intension of the mixers when playing back in a system with less (or more) speakers than it was originally mixed on..
As Roger noted, if the system has better resolution than what the content was created on, you will get a better resolution (i.e. more pinpointed and/or refined pans, greater accuracy, etc..) upon playback.
As you can see, it's an entirely different thing than speaker remapping as employed by Trinnov...
FilmMixer is offline
post #186 of 1405 Old 05-04-2012, 03:42 PM
noah katz's Avatar
Liked: 364
thanks for the explanations
Noah
post #187 of 1405 Old 05-12-2012, 05:14 PM
SoundChex's Avatar
Quoted: 368 Post(s)
Liked: 311
As only an observer mostly trying to infer the longer term impact on Home Theater, I was interested to read this 5/8/2012 screendigest article "Cinema sound becomes a competitive environment again" (link). It seems to suggest there is (about to be) more of an "audio oriented" struggle for the hearts, minds, ears, and wallets of the high street movie-going public than I had heretofore believed . . . and that we might soon expect to be making our movie and|or theater choices by considering the availability of Dolby Atmos, Immsound, Iosono, Auro 11.1, and Illusonic 3D sound as an additional characteristic.
[I have to wonder just how capable is the average theater goer to make a critical discrimination between these five 'enhanced sound' technologies...?! ]
[Home Office system schematic]
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is offline
post #188 of 1405 Old 05-12-2012, 08:09 PM
Wireless member
pepar's Avatar
Quoted: 1044 Post(s)
Liked: 544
Maybe Smell-o-Vision will make a comeback in commercial cinemas?
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #189 of 1405 Old 05-12-2012, 09:34 PM
filecat13's Avatar
Quoted: 41 Post(s)
Liked: 105
I experience Smell-O-Vison every time I got to the cinema, and it is not an attraction.*
*Major exceptions are Arclight cinemas.
What I can afford, when I can afford it...
filecat13 is offline
post #190 of 1405 Old 05-13-2012, 06:11 AM
Wireless member
pepar's Avatar
Liked: 544
pepar is offline
post #191 of 1405 Old 05-16-2012, 02:30 PM
StevenLansing's Avatar
Yeah,I don't think I want to know what an ogre smells like,best left up to the imagination.
By the way,on the subject of Trinnov,isn't it going to be part of the Doremi DCI equipment package?
StevenLansing is offline
post #192 of 1405 Old 05-16-2012, 02:46 PM - Thread Starter
Liked: 871
Originally Posted by StevenLansing View Post
By the way,on the subject of Trinnov, isn't it going to be part of the Doremi DCI equipment package?
Here's the PR from 2010. It appears to focus on EQ, but I do not see evidence of it in their current products.
Deadwood II Theater
post #193 of 1405 Old 05-16-2012, 05:04 PM
SoundChex's Avatar
Quoted: 368 Post(s)
Liked: 311
By the way, on the subject of Trinnov, isn't it going to be part of the Doremi DCI equipment package?
Perhaps Doremi has decided on a different "audio partner": This 12/5/2011 Barco Press Release "Barco and Doremi partner to develop industry's first DCI-compliant next-generation 3D sound system" (link) states:
"Kortrijk, Belgium, 5 December 2011 - Barco, a key player in digital cinema technology, has teamed up with media block technology leader Doremi to bring the first DCI-compliant 3D sound system to the cinema market. Auro-3D®, powered by Barco and Auro Technologies, is an audio system that creates true 3D sound. Doremi will integrate the Auro-3D® codec in their Integrated Media Block (IMB) to create the first DCI-compliant multi-channel audio format for cinema exhibitors. [. . .]"
post #194 of 1405 Old 05-18-2012, 11:14 AM
Jay G.'s Avatar
Does anyone know what sample rates Atmos works with? I can't find this information online.
The recent announcment of the Dolby TrueHD upconversion of 48 kHz material to 96 kHz prompted me to think of this. Will movies still be mastered largely in 48 kHz, or will Atmos encourage higher sample rates?
Jay G. is offline
post #195 of 1405 Old 05-18-2012, 12:30 PM
FilmMixer's Avatar
Liked: 2389
DCP supports 48k or 96k..
I don't think Atmos has any bearing on what sample rate we choose to use.
It's harder to implement on the production side of thing for many reasons, but more pertinent is that it cut's all of your audio resources in half.. half the channel count, half the DSP..
In addition, on the venue side, you run into the same issue... doubled processing power needed for EQ and delays..
On the subject of Dolby's new 96k up sampling tech for TureHD..
Color me skeptical..
post #196 of 1405 Old 05-18-2012, 01:41 PM
Jay G.'s Avatar
It's harder to implement on the production side of thing for many reasons, but more pertinent is that it cut's all of your audio resources in half.. half the channel count, half the DSP...
So you're saying going over 96k would be difficult?
From what I can tell, DCP has the bandwidth to support 16 channels at 96k. From the system spec:
The Media Network is required to support sustained rate of 307 Mbits/sec for compressed image (250 Mbits/sec), audio (37.87 Mbits/sec - 16 channels, 24 bit sample, 96 KHz) and subtitle data (subpicture 20 MBits/sec) for each screen.
Audio - This interface is required to stream multiple digital audio channels to the Cinema Audio Processor. This is required to be in an AES3 format. For worst-case audio bandwidth, 37 Mbits/sec is required (16 channels * 24 bit sample * 96 kHz = 37 Mbits/sec).
Bandwidth
The storage system is required to provide enough output to support a continuous stream of 307 Mbits/sec for compressed image, uncompressed audio (16 channels, 24 bit sample, 96 kHz) and subtitle data to allow for non interrupted Digital Cinema playback.
It seems to me that you could fit 8 channels of 24-bit 192k audio in the same bandwidth, but it wouldn't be backwards compatible with existing DCP spec.
Dobly has stated that Atmos will be delivered in a "Backwards-compatible" DCP, but it will have 128 channels, well above the 16 allowed in the standard. I'm guessing this means they employ the standard 8 channels in the DCP, and the Atmos is an extension of the format?
Jay G. is offline
post #197 of 1405 Old 05-18-2012, 02:45 PM - Thread Starter
Liked: 871
Dolby has stated that Atmos will be delivered in a "Backwards-compatible" DCP, but it will have 128 channels, well above the 16 allowed in the standard. I'm guessing this means they employ the standard 8 channels in the DCP, and the Atmos is an extension of the format?
The new Atmos files are carried as separate file on the DCP, and thus is not constrained by the 16-ch standard.
Deadwood II Theater
post #198 of 1405 Old 05-18-2012, 03:01 PM
Originally Posted by SoundChex View Post
Perhaps Doremi has decided on a different "audio partner": This 12/5/2011 Barco Press Release "Barco and Doremi partner to develop industry’s first DCI-compliant next-generation 3D sound system" (link) states:
This is the link to Trinnov's site that mentions them and Doremi and Trinnov's EQ tech being utilized.I don't know how old the info is.
http://www.trinnov.com/products/digi...se/?lang=en_us
Sorry about that Roger.I couldn't click the link you referred,so I didn't know it was the same as the one I posted.lol!
post #199 of 1405 Old 05-21-2012, 12:26 AM
sdurani's Avatar
Quoted: 4959 Post(s)
Liked: 3427
Looks like AMC, the theatre chain working with Dolby to help test Atmos, will have new owners.
Sanjay
sdurani is offline
post #200 of 1405 Old 05-21-2012, 08:11 AM
pokekevin's Avatar
Quoted: 12 Post(s)
Liked: 102
Wow
pokekevin is offline
post #201 of 1405 Old 05-22-2012, 03:17 PM
So much for trying to curb piracy!
post #202 of 1405 Old 05-22-2012, 03:18 PM
Wireless member
pepar's Avatar
Liked: 544
Maybe it will behoove them to reevaluate their stance on that.
pepar is offline
post #203 of 1405 Old 05-23-2012, 07:01 AM
markus767's Avatar
Liked: 1489
Attended a Dolby presentation yesterday and it looks like channels will stay with us for much longer than I had hoped for.
One interesting tidbit: There's a feature "snap to nearest speaker" which probably prevents the unwanted phantom imaging issue that came up earlier in this thread.
Markus
post #204 of 1405 Old 05-23-2012, 09:35 AM
FilmMixer's Avatar
Liked: 2389
Please explain.
post #205 of 1405 Old 05-23-2012, 10:45 AM - Thread Starter
Liked: 871
^^ To save posts, we can revisit #141-146.
Deadwood II Theater
post #206 of 1405 Old 05-23-2012, 12:58 PM
FilmMixer's Avatar
Liked: 2389
I still don't understand what is a new revelation about how these systems work, that's all... and just curious.
Why is it "surprising" that channels are still with us?
Maybe I'm misunderstanding Markus' disappointment, but this isn't a new way to reproduce sound, ala Iosono...
Even with that system, they found it very difficult to move away from having "channels", especially behind the screen, due to the fact that film, as we know it today, will always be a 2D image projected onto a flat wall, and the audience will always be focused, and facing, forward...
post #207 of 1405 Old 05-23-2012, 06:30 PM
Jay G.'s Avatar
I emailed Dolby asking about the sample rates Atmos supports. This is the response I got:
Thank you for contacting Dolby and for you interest in Dolby Atmos.
The current implementation of Dolby Atmos supports sample rates up to 24bit / 96kHz. However, at this sample rate you would be limited to 64 object / channel streams (still with 64 speaker feeds / rendered outputs), as apposed to 128 object / channel streams when operating at 24bit / 48kHz and (again with 64 speaker feeds / rendered outputs).
Jay G. is offline
post #208 of 1405 Old 05-23-2012, 07:37 PM
markus767's Avatar
Liked: 1489
Zactly.
Dolby is very much listening to what content creators have to say and in the end this will not be a revolution but an evolution.
Markus
post #209 of 1405 Old 05-23-2012, 08:25 PM
FilmMixer's Avatar
Liked: 2389
Zactly.
What do define as a revolution?
post #210 of 1405 Old 05-24-2012, 07:00 AM
markus767's Avatar
Liked: 1489
Objects only mixes could be a real revolution but that's probably not feasible for various reasons. For example, Brave is mixed in 7.1 and then gets the Atmos treatment.
Let's see how everything develops (especially now that AMC got sold). After the presentation I had the feeling the whole system is still under development.
On a side note, I believe the built-in room correction is a big step forward. Currently the whole X-curve correction is based more on beliefs and not on proper science. I've seen frequency response curves from different theaters and they showed such huge variations (even after 1/3 octave based correction) that it really didn't matter much what the underlying curve was. With Atmos any target curve can be closely matched. This makes it much easier to reveal the underlying parameters for timbre and loudness.
They could also apply something similar to Dolby Volume because it's common (bad) practice for theater owners to arbitrarily change playback volume based on consumer reports ("The movie was too loud" vs. "I couldn't understand the dialog").
Markus
Reply D-cinema Equipment and Theaters
