Surround Sound Balance Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 12-06-2013, 12:05 PM - Thread Starter
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
I always notice in theaters that sound effects in the rear are mainly left oriented. In other words to me its seems like the sound mix is slanted toward the rear left speakers more than the right rear channel by a nice margin. I usually sit dead center in movie theaters so I don't have a left or right fixation. I notice the same thing watching movies at home. Is that a true situation or not and have any of you noticed that? I wish it was not like that as I like to hear all the channels being used during the course of a movie.
jbug is offline
post #2 of 19 Old 12-07-2013, 03:24 PM
Reddig's Avatar
Quoted: 162 Post(s)
Liked: 309
I personally havnet noticed this but maybe it is just luck of the draw that the movies you had judged happend to have a lot of content oriented in that direction.
JBL Pro Cinema/PSA subs/Crown power/Sony SXRD
MANCHESTER UNITED!!
Reddig is offline
post #3 of 19 Old 12-08-2013, 03:27 PM
johnty's Avatar
Quoted: 18 Post(s)
Liked: 29
If it happens in multiple movie theaters and on multiple movies at home you might want to have your hearing checked. Your right ear could be down a db or two.
johnty is offline
post #4 of 19 Old 12-09-2013, 08:33 AM - Thread Starter
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
Maybe I am down a quart or so. I'll use that as an excuse the next time my wife calls me to do something though. I saw the latest Hunger Games movie Sunday but didn't notice anything out of the ordinary.
jbug is offline
post #5 of 19 Old 01-03-2014, 12:46 AM
Roger Dressler's Avatar
Quoted: 1528 Post(s)
Liked: 717
Next time you feel the left side bias, turn your head around to face the rear for a moment to see if it stays that way or not.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is online now
post #6 of 19 Old 01-03-2014, 08:23 AM - Thread Starter
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
I'll put that to the test.
jbug is offline
post #7 of 19 Old 01-27-2014, 10:37 PM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 381 Post(s)
Liked: 404
Your brain will fool you if you try it that way.
You can do the same test using an SPL meter and listening for a difference in left and right surround, then verifying with the meter. If you find that your right "sounds" a little lower, then go by ear to raise the right a couple of dB to compensate. No rule says you can't. wink.gif Then listen to a passage or two you know well .
What you describe can also be caused by not having quite the correct relative levels between the side surround and the back surround on the same side. If you simultaneously send both speakers a mono test tone, a phantom image should be centered between the two. BUT, you must evaluate that phantom position while facing the screen. Our perception of location of sound behind us is different than when we face it.
A good test example is from Oblivion. If you use the scene in Oblivion where the bubblecraft lands at the stadium, the sound should move smoothly in a counter clockwise manner to the rear half of the room as the craft leaves screen left. If it sounds like it goes straight to the rear rather than strongly around your left side, then the left surround is too low relative to the back left channel. Check your levels...as described above if necessary. smile.gif Then run the scene again to verify.
When the drone leaves the stadium, it zooms out the right side and rear quite aggressively.
Your back surrounds are not in the back corners, right?
Cam Man is offline
post #8 of 19 Old 01-28-2014, 03:38 AM
Liked: 717
post #9 of 19 Old 01-28-2014, 07:26 AM - Thread Starter
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
No, they are along the sides, just slightly behind the first row of seats. I'll have to try the test with an SACD as I'm in between TVs.
jbug is offline
post #10 of 19 Old 02-06-2014, 10:30 PM
Reddig's Avatar
Quoted: 162 Post(s)
Liked: 309
I have noticed with alot of theaters that if you are left or right of the center line of the theater which ever side is closer with become dominant and slightly or completely drowned out the other side. Theres a scientific term for this effect named after the guy who documented the phenomena. Maybe someone said it in this thread not sure. But I understand what your saying. Ive been to theaters where I could have bet alot of money that the left surrounds where not working at all only to just move a couple seats over and boom you hear them. Happens all the time in home theaters when seats are up against the wall too close to a surround.
MANCHESTER UNITED!!
Reddig is offline
post #11 of 19 Old 02-07-2014, 09:31 AM - Thread Starter
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
I'm going to see that Lego movie (um, taking the grandkids you understand) this weekend. I'm going to pay special attention to that.
jbug is offline
post #12 of 19 Old 02-07-2014, 09:50 AM
Reddig's Avatar
Quoted: 162 Post(s)
Liked: 309
Hey bro no explanation needed I'm a total kid at heart and my buddy and I are going on Sat morning to see it!! Take note of number of surrounds on each wall as will I and let's both try to set left or right from center a few seats and let's compare experiences. Hopefully the movie has an active surround mix and it's a good flick. I heard it is too. 100% positive on Rotten Tomatoes so far
jbug likes this.
MANCHESTER UNITED!!
Reddig is offline
post #13 of 19 Old 02-07-2014, 09:57 AM - Thread Starter
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
That's a deal and I'll report back on Monday. The movie has super good reviews.
Reddig likes this.
jbug is offline
post #14 of 19 Old 02-07-2014, 10:24 AM
Reddig's Avatar
Quoted: 162 Post(s)
Liked: 309
Right on I'll do the same!!
MANCHESTER UNITED!!
Reddig is offline
post #15 of 19 Old 02-10-2014, 02:56 PM
Reddig's Avatar
Quoted: 162 Post(s)
Liked: 309
Man I absolutely loved The Lego Movie!! I havn't laughed so much at the movies in years. Great in everyway that movie was. I really enjoyed the sound mix. I was 4 seat right of what would be the center and I could hear the left and right surrounds evenly creating the desired stereo effect at times. This particular theater actually makes most movies sound great. Uses EV mains and JBL surrounds.
MANCHESTER UNITED!!
Reddig is offline
post #16 of 19 Old 02-11-2014, 07:06 AM - Thread Starter
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
It was good but I want to see it again for the parts that I missed getting popcorn and Icee refills for the two kids we took. I see it did very well at the box office. What did you think of the 3D? As for seating, we wound up on the left side in the back cause the theater had mostly filled up by the time we got there. I couldn't even concentrate on the sound because of interruptions (lol).
jbug is offline
post #17 of 19 Old 02-23-2014, 08:51 AM
Reddig's Avatar
Quoted: 162 Post(s)
Liked: 309
That's too bad man. Kids are definitely big distractions at the movies wether there your own or somebody else's lol. Wasn't blown away by the 3D. Think it's a movie where 2D is good enough and 3D isn't necessary. Seemed way subtle. I loved the movie tho absolutely loved it.
MANCHESTER UNITED!!
Reddig is offline
post #18 of 19 Old 02-24-2014, 07:50 AM - Thread Starter
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
I agree about the 3D in that movie. I haven't been blown away watching a 3D movie in a theater in a long time. At home it's much better though.
jbug is offline
post #19 of 19 Old 02-24-2014, 11:53 PM
Reddig's Avatar
Quoted: 162 Post(s)
Liked: 309
I seem to be the most impressed with animations in 3D, especially DreamWorks and Pixar, although there exceptions. Monster's U impressed me with there 3D as did The Croods. At home 3D is a blast for sure.
MANCHESTER UNITED!!
Reddig is offline
Reply D-cinema Equipment and Theaters
