New Barco 4K Projector LX 5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 54 Old 01-16-2008, 10:10 AM - Thread Starter
W.Mayer's Avatar
Quoted: 220 Post(s)
Liked: 264
seams barco is first out with the new jcv 4k pr.
form the pictures you can see its the jvc pr. but it has some
diferences like the light out.
jvc still say 3500 lumen barco say "till" 4500 lumen?
NO HDCP
for more infos see this link or down.
http://www.barco.com/Presentation/en...p?element=4068
LX-5 technical specification
Light output
4,500 lumens
Contrast ratio
> 10,000:1 contrast ratio
Resolution
4,096 x 2,400 pixels (10Mp)
Display technology
LCoS
Lamps
Lamp
800W Xenon
Lamp lifetime (typical)
Warranted 750 hrs - max 1,500 hrs
Dimensions
Weight
Body only: 50kg / 110 lbs
Height - width - length
390 x 660 x 830 mm
15.35 x 25.99 x 32.67
Lenses
Available zoom lenses
TLB HB (1.5 - 1.9:1) included
Available fixed focal lenses
TLB HB (1:1)
Features
Special features
Up to 4 picture-and-picture data and images
Adjustable color temperature
High dynamic range compatible
Inputs and outputs
Inputs
4x dual DVI-D (up to 12 bit)
Communication ports
RS232 in/out on D9
RJ45 (10/100 Base-T Ethernet)
USB port
Compatibility
Data
Computer graphics formats VGA, SVGA, XGA, SXGA, UXGA,
1080p HD, 2K up to 4K and 10MP
Safety
Safety regulations
UL 60950
CE compliant
RoHS and WEEE compliant
Power
AC power
100 - 240 VAC/50-60 Hz
Max. power consumption
1500 Watt
Order info
Order info
LX-5 R9011220
W.Mayer is offline
post #2 of 54 Old 01-16-2008, 10:33 AM
Art Sonneborn's Avatar
Quoted: 238 Post(s)
Liked: 295
NO HDCP
Light output
4,500 lumens
Contrast ratio
Resolution
Display technology
LCoS
Lamps
Lamp
800W Xenon
Dimensions
Weight
390 x 660 x 830 mm
Lenses
TLB HB (1:1)
Features
Special features
Inputs and outputs
Inputs
Communication ports
RS232 in/out on D9
USB port
Compatibility
Data
Safety
Safety regulations
UL 60950
CE compliant
Power
AC power
1500 Watt
Order info
Order info
LX-5 R9011220
Sounds promising but the lack of HDCP is a problem. Guessing it will be at CEDIA ?
Art
My HT
iRule rules my theater
Art Sonneborn is online now
post #3 of 54 Old 01-16-2008, 07:02 PM
ciputra's Avatar
Since this is meant as a simulation projection, doubt Barco will care to add on HDCP, well unless NEC do make that input
ciputra is offline
post #4 of 54 Old 01-17-2008, 05:56 AM - Thread Starter
W.Mayer's Avatar
Quoted: 220 Post(s)
Liked: 264
no you can purchase it now.
no need to wait art
i call barco and they tell me if i order one i will get it next month.
price is very high.
barco also confirm the 4500 lumen.
jvc say only 3500 till today.
i will get a demo in my rooms very likely in febr.08
W.Mayer is offline
post #5 of 54 Old 01-17-2008, 06:46 AM
Quoted: 238 Post(s)
Liked: 295
no need to wait art
price is very high.
Wolfgang,
Please be sure to give us your impressions and some measurements. Are you at liberty to say how high regarding the price ?
Art
My HT
post #6 of 54 Old 01-17-2008, 07:04 AM - Thread Starter
W.Mayer's Avatar
Quoted: 220 Post(s)
Liked: 264
hi art
please pm me but after this post i am some days not here.
have to leave now....
wolfgang
W.Mayer is offline
post #7 of 54 Old 01-17-2008, 09:48 AM
donaldk's Avatar
Quoted: 407 Post(s)
Liked: 83
It is listed under corporate AV on the link Wolfgang provided, not Simulation. Still no incentive to add HDCP.
Barco sourcing OEM projectors where has the world come to;-).
donaldk is online now
post #8 of 54 Old 01-18-2008, 12:19 AM
ciputra's Avatar
Well this is not the first time Years ago there's Graphic4000 which is OEMed from panasonic and after that Barco built their own two lamp projector's design. I believe the next LCOS series projector will be based from the SIM7 series
ciputra is offline
post #9 of 54 Old 01-18-2008, 12:08 PM
donaldk's Avatar
Quoted: 407 Post(s)
Liked: 83
Will Gemedis come-up with a higher res panel? The current one used by Barco and SEOS is uxga.
post #10 of 54 Old 01-18-2008, 08:56 PM
ciputra's Avatar
QXGA you mean - SIM7D and SIM7Q 2048x1536 . SIM7H - 1920x1080
ciputra is offline
post #11 of 54 Old 01-18-2008, 09:18 PM
donaldk's Avatar
Quoted: 407 Post(s)
Liked: 83
Yup, didn't want to look it up, and probably wasn't quite awake either. Hmm, 05.17 already, better shutt down this computer;-). How's breakfast in +7 hours territory, LOL.
post #12 of 54 Old 01-20-2008, 09:16 AM - Thread Starter
W.Mayer's Avatar
Quoted: 220 Post(s)
Liked: 264
Wolfgang,
Art
yes art.
i can say that list price is almost double the sim2 5000 list price!
but that can be diferent in us and i never pay list price
for my last 5 pr.
W.Mayer is offline
post #13 of 54 Old 01-20-2008, 09:20 AM
Quoted: 238 Post(s)
Liked: 295
yes art.
for my last 5 pr.
I understand Wolfgang, it does help to have a starting point for reference though.
Art
My HT
post #14 of 54 Old 01-20-2008, 12:25 PM
donaldk's Avatar
Quoted: 407 Post(s)
Liked: 83
yes art.
for my last 5 pr.
The list price on those Christies seemed inflated to me, as the HD 8K 'maximum price our sellers may ask' at introduction was (well) into the D-Cinema range pricing. The 5K (6K) was 20K Euro less, and the notch filter would add either 5K or was it 8K to the regular projector's price. All ex-VAT.
post #15 of 54 Old 01-20-2008, 12:28 PM
donaldk's Avatar
Quoted: 407 Post(s)
Liked: 83
yes art.
for my last 5 pr.
Would that 80-90K euro be in or excluding VAT? Barco would list their products excluding VAT, but you might have already added it in you mind.
post #16 of 54 Old 06-11-2008, 05:44 PM
pavr's Avatar
Well.....have you gotten the Barco LX-5 to test yet? I am anxious to know the findings....
pavr is offline
post #17 of 54 Old 06-11-2008, 09:29 PM
donaldk's Avatar
Quoted: 407 Post(s)
Liked: 83
Anybody got any further info on that 5K x 2K Meridian branded projector that was supposed to be demoed in Seattle. http://www.avsforum.com/avs-vb/showt...#post13996834?
This seems to be it http://www.definitive.com/, yet to take place, I see. Accroding to the wording on the website it seems to be the same (little over) 4K chip as used by JVC/Barco, so nothing extraordinary there.
post #18 of 54 Old 06-12-2008, 06:26 AM
LJG
LJG's Avatar
Quoted: 329 Post(s)
Liked: 142
Art:
I wouldn't get too excited, if the Barco LX5 is the JVC4K then it will be useless for home theater applications. For home or personal use, the JVC 4K is available exclusively from Meridian Audio. The Pro JVC 4K is calibrated for the simulation market not home theater so it would need to be optimuzed for home theater.
Lastly and most importantly, the JVC4K has only a short throw lens for the 4K, since that's what simulation requires, no other lens option is available. The long throw lens is only available from Meridian.
The Merdian 4K will be optmized by William Phelps
The above may only be for JVC US, it may not be applicable outside the US
LJG is online now
post #19 of 54 Old 06-12-2008, 06:38 AM
PRETERNATURAL IMMERSOPHIL
CINERAMAX's Avatar
Quoted: 1672 Post(s)
Liked: 914
Send a message via Skype™ to CINERAMAX
I have seen the JVC 4k and it cannot hold a candle to the dlp Barco's in terms of image dynamics (ansi), apparent resolution (still a bit on the soft side) and colorimetry.
Where this projector shines is in recreating tiny little runway lights on a flight simulator from 66-7 miles away on a landing.
We did a z lamp adjustment on the barco at helene and it went from 15 foot lamberts to 23, there is tremendous vibrancy to the image . The LCOS does not have that punch.
Sincerely, GC*
rAVe Best ATMOS DEMO CEDIA 2016. HOARDS AWARDS, ACCOLADES, 1ST ART CREDS.,WLD. RECORDS, & HI PERFORMANCE 16-24-32-48 CH. MIDI-PLF CINEMAS WW. - CUSTODIAN HIGH END IMMERSIVE CINEMAS TO SMPTE & ADV. IMAGING SOC. HELP Combat Channel Insufficiency with Altitude 48!*GC = GANGSTA C. genus: cineramus maximus. GC Twitter (Now staging Humanitarian Relief Aide to Great Bel-Air Circuit B-chain & 6P/HDR Projection Famine of 2017)
CINERAMAX is online now
post #20 of 54 Old 06-12-2008, 06:39 AM
Jim HTPC's Avatar
Quoted: 20 Post(s)
The JVC Pro 4K projector will be available for the US in the home theater market. One well known baseball player in NY is scheduled to be receiving one as soon as it's available.
Jim HTPC is offline
post #21 of 54 Old 06-12-2008, 06:46 AM
LJG
LJG's Avatar
Quoted: 329 Post(s)
Liked: 142
I do not beleive that to be the case, are you sure it is not a Meridian?
LJG is online now
post #22 of 54 Old 06-12-2008, 06:56 AM
Jim HTPC's Avatar
Quoted: 20 Post(s)
Not unless the Manuf. Rep for JVC Pro is incorrect. I'm sure for that kind of money it will happen. Money talks. Maybe JVC Pro will switch it around. Maybe it will be a Meridian modified unit? But there was no mention of it at time. We'll see what shows up.
Jim HTPC is offline
post #23 of 54 Old 06-12-2008, 07:04 AM
LJG
LJG's Avatar
Quoted: 329 Post(s)
Liked: 142
Let us know, I am pretty sure only short throw lens option for JVCPro
LJG is online now
post #24 of 54 Old 06-12-2008, 07:45 AM
Ohlson's Avatar
CINERMAX
Half joking and half seriously I ask what kind of gamma setting the JVC used when you viewed the projector. With all the recent accounts of how much the image changes with the RS2 going from a standard 2.2 to a 2.4-2.5 I thought I should ask.
If William Phelps could provide a custom gamma of 2.4, his known uniformity tweak and calibrated colors it should have potential. Peter it even has a xenon lamp!
Mattias Ohlson
Ohlson is offline
post #25 of 54 Old 06-12-2008, 10:26 AM
Quoted: 238 Post(s)
Liked: 295
Do we know the speced lumens for the Meridian.
art
My HT
post #26 of 54 Old 06-12-2008, 11:04 AM
LJG
LJG's Avatar
Quoted: 329 Post(s)
Liked: 142
art
3000 actual
LJG is online now
post #27 of 54 Old 06-12-2008, 11:24 AM
coldmachine's Avatar
Originally Posted by LJG View Post
3000 actual
Thats 28fL @ 18ft.......not too shabby.
"Wow, do you think you are Adonis"...... "Baby, I'm not A-donis, I'm THE-donis"
coldmachine is offline
post #28 of 54 Old 06-12-2008, 11:27 AM
Originally Posted by Ohlson View Post
CINERMAX
I think we'll be seeing some nice S shaped curve options on some of these new units.
post #29 of 54 Old 06-12-2008, 11:42 AM
CINERAMAX's Avatar
Liked: 914
Yeah Yeah.
But it does not come with one of these:
Sincerely, GC*
post #30 of 54 Old 06-12-2008, 12:43 PM - Thread Starter
W.Mayer's Avatar
Quoted: 220 Post(s)
Liked: 264
its not top priority for me to see this unit side by side with the
big barco dp 2000 because
-i need to solve some problems with the dlp pr. and that can take 4 weeks.
-i need to work bit more with my cinema server i got and all the material i have.
-my doctor told me step down a bit and i know how many action always that tests have
than i also get used to the good 35 ftl on my 7m screen and if the 4k have in best case
3500 lumen i end up with 12 ftl with a new lamp and soon much less than 10 ftl.
when you get used to such a level off ftl i dont know anybody that can go back to a dimm picture and dimm means for me 20 ftl and less.
i thought when i got this big barco cinema dlp it will be to bright for 2d movies because the min.
i can have with a new lamp if i dim the 4000 watt xenon max. down ist about
35 ftl.but now i feel bad if i have not more than 30 ftl!!!
i reach now almost 100 hours and i now increase the lamp power from 2400watt to about 2700 watt to keep it at 35 ftl
and one reason more is for me how good the barco can do in full 2048x1080
my 3d still pictures flicker free at 144hz.
this picture looks so good with the cristal eye shutter that i do not think
only the 4 times resolution makes such a advantages if
you have so many disatvantages if you like to do 3d without the dlp system.
W.Mayer is offline
Reply D-cinema Equipment and Theaters
