Barco-Folsom Image Pro HD Processor? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-02-2008, 05:47 PM - Thread Starter
fastl's Avatar
Quoted: 22 Post(s)
Anyone have any hands-on experience with this VP. Expensive, but can basically do everything. Barco obviously bought Folsom Research to get a hold of their video processing expertise. They are touting their "Athena" motion adaptive per-pixel de-interlacing, so I am interested to see how it compares to the Realta.
fastl is offline
post #2 of 13 Old 02-02-2008, 09:56 PM
Alan Gouger's Avatar
Quoted: 38 Post(s)
Liked: 71
What is expensive?
Alan Gouger is offline
post #3 of 13 Old 02-02-2008, 10:02 PM
Art Sonneborn's Avatar
Quoted: 348 Post(s)
Liked: 469
Any links ?
Art
Art Sonneborn is online now
post #4 of 13 Old 02-03-2008, 06:26 AM - Thread Starter
fastl's Avatar
Quoted: 22 Post(s)
Ok, here the vendor's link:
http://video.folsom.com/products/ind...70327722_18404
and here's an idea of what one would cost ($8K):
http://www.avmediadepot.com/product_...oducts_id=2174
I have seen its sibling Presentation Pro in operation more than once - very nice. Was hoping that one of the Barco fans here has actually used one and can comment on its de-interlacing quality. From what I know so far, the Realta is still the best at de-interlacing until you get into something like a Snell & Wilcox Quasar. Most of the VPs dynamically decrease bandwidth during fast motion de-interlacing to conceal artifacts, unlike the Realta.
fastl is offline
post #5 of 13 Old 01-07-2009, 08:40 AM
Ccronks's Avatar
I work in the event staging industry, and we use Barco products all the time. I love the Image Pro for it's complete range of capabilities. We call it the "swiss army knife" of video. Feed it anything, it spits out anything. And their athena scalers (which is in the Image Pro, Screen Pro II, and Encore VPs) always deliver great quality. If you like the Presentation Pro, you'll like the Image Pro as well (probably more).
Ccronks is offline
post #6 of 13 Old 01-07-2009, 09:26 AM
Curt Palme's Avatar
Quoted: 34 Post(s)
Liked: 61
Folsom is also the company that makes the processor for blending two projectors side by side. Haven't seen it firsthand, but about 1/2 dozen CRT guys have this in their home. Tim MArtin sells them.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #7 of 13 Old 01-07-2009, 11:37 AM
LICENSED TO THRILL
CINERAMAX's Avatar
Quoted: 2111 Post(s)
Liked: 1199
Send a message via Skype™ to CINERAMAX
I have seen better video processing than that of the acs-2048, made by folsom for the Barco, but this thing is designed for cinemas from the ground up so ...
For example the dvi equalization boost (with which the unit comes in set at 12 for a 12 meter input compensation boost) is for the input cables, if you dont set it at 3 the image blooms like crazy. You cannot scale to 1920 x 1080 only to 2048. There is only brightness contrast and gamma adjustment for dvi in.
Not very transparent...
CINERAMAX is offline
post #8 of 13 Old 01-07-2009, 12:03 PM
coldmachine's Avatar
Originally Posted by Alan Gouger View Post
What is expensive?
I'll wager its far less expensive than your last one.
"Wow, do you think you are Adonis"...... "Baby, I'm not A-donis, I'm THE-donis"
coldmachine is offline
post #9 of 13 Old 01-07-2009, 03:05 PM
donaldk's Avatar
Quoted: 461 Post(s)
Liked: 111
The Blendzilla's are made by Analog Way. Softedge blending is practically standard on higher end rental & staging processors. TVOne is working its way into this market and has been gaining ground with the CRT folks as it starts at a far lower price point, and developers seem keen to address their needs. The higher end models also start around 8K, all HD-SDI I/O will add considerably to this.
At the beginning of the century Barco also acquired a German Blending specialist, whose boards were included in Barco CRTs, but can't think of the name right now. A few years later Barco acquired Folsom, the release is still online for those who care.
donaldk is offline
post #10 of 13 Old 01-07-2009, 04:36 PM - Thread Starter
fastl's Avatar
Quoted: 22 Post(s)
According to Barco, the acs-2048 is designed specifically with a dual-link output to drive 2K resolution projection, so you typically wouldn't want to use one in a home system. They recommend the Image Pro instead. I wound-up purchasing a Calibre PVPRO instead, because it had certain filters and other processing features that weren't available in the Image Pro. However, I haven't ruled the Image Pro out yet and may purchase one in the future.
fastl is offline
post #11 of 13 Old 04-26-2009, 07:38 AM
Mr.D's Avatar
I wasn't very impressed with the Folsom. Its quite aliased and yet mushy at the same time. Seen better scaling on HTPCs.
When I put 1080p through a DP100 I bypassed the Folsom to get true 1:1 with a small border down the left hand side. deinterlacing seems okay though.
digital film janitor
Mr.D is offline
post #12 of 13 Old 05-02-2009, 05:03 AM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1199
This mirrors my experience and assessment of the picture quality, mushy is dead on Mr.D.
I reported this to Barco Technical support, they called Folsom, Folsom got all up in arms that the TI SCALING ENGINE IN NO WAY COULD BE BETTER THAN THEIRS.
Folsom is setting up a system to seriously optimize their scaler with dual link connectivity to the Barco's.
post #13 of 13 Old 05-02-2009, 07:42 AM
Quoted: 38 Post(s)
Liked: 71
I see Calibre has a new commercial VP call the VideoExcel
Duel link 3G HD SDI in/out.
I have to say I am very impressed with their PVPROHD. Thanks for the heads up fastl.
Reply D-cinema Equipment and Theaters
