Dish DTVPal / Echostar TR40 digital to analog converter - Page 226 - AVS Forum | Home Theater Discussions And Reviews
post #6751 of 6754 Old 04-30-2013, 08:03 AM
Beeper's Avatar
Quoted: 158 Post(s)
Liked: 109
New issue with DTVPAL / TR-40 they lose audio on some stations. I've had these up and running for years without this issue.
Sometime in late 2012, I lost just the audio on one station only. All of the other stations had audio.
Tinkering with it in Setup/Audio Setup, I changed the Audio Language setting to Alternative and selected Done.
The audio immediately returned. This particular station does not have any sub-channels.
I then changed the audio setting back to the default Primary setting.
Sometime later the same thing happened with the same station.
Sometime later the same thing happened with a different station.
This station has sub-channels and the sub-channels had audio while the main channel did not.
Again, all of the other stations in town had audio.
Using the procedure above that cured the problem before, did not cure the problem on this station.
The only thing that fixed the problem was setting the box to factory defaults and doing the installation procedure.
My neighbor had the same issue with is converter box, so the issue was not isolated to my unit.
What I started doing is not leaving the unit tuned to either of these stations when it is shut off and the issue hasn't occurred since.
The affected stations are the Milwaukee stations 6 and 58.
My firmware is what I believe is the latest available, F105 and the unit is a TR-40.
Disclaimer: I don't endorse any particular brand. Purchasing electronics is a compromise.
Brand selection may not be a main consideration.
Beeper is offline
post #6752 of 6754 Old 10-04-2013, 07:08 PM
Jim1348's Avatar
Quoted: 126 Post(s)
No, it has the red/white/yellow composite jacks. You may want to consider an adapter.
http://www.ebay.com/itm/like/370821380138?lpid=82
Jim1348 is offline
post #6753 of 6754 Old 10-05-2013, 11:42 AM
hardly's Avatar
hardly is offline
post #6754 of 6754 Old 10-05-2013, 12:20 PM
phildaant's Avatar
Quoted: 906 Post(s)
Liked: 329
He was replying to my question that I deleted last night because I posted in the wrong forum thread (this is not for DVR). I was too late.
phildaant is offline
Reply Coupon Eligible Converter Box (CECB)
