Rca Dta800b1* - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 116 Old 12-28-2008, 08:58 PM
dealerloot1's Avatar
I was searching for this product based on reviews on cnet. Lot of people have been searching for this product or at least seemed that way from a lot of requests for this product. Walmart is carrying this product. You will have to purchase it "IN-STORE". Please note that not all stores have them. I had to go to a 2nd store to find it.
Also there was some confusion about model number. The sticker on the counter shows DTA800 but the cover on the RCA retail box clearly indicates the model number for DTA800B1.
The price for the product is about $50 here in Baton Rouge, LA. But, with tax it comes to about $55. If you have a $40 government coupon it's about $15 to shell out of your pocket.
Good Luck and Happy New Year to All !!
dealerloot1 is offline
post #92 of 116 Old 01-19-2009, 01:06 PM
jamesrday's Avatar
I have the DTA800B1 with a Panasonic CT-27G22UV TV. I get the 'instruction' video, but I can't get the box or TV to get any channels.
The manual says to go to the 'No signal' screen and punch in 562. What or where is the 'no signal' screen?
thanks,
Jim
jamesrday is offline
post #93 of 116 Old 01-19-2009, 03:54 PM
cri123's Avatar
I had/have both the RCA DTA800B and the RCA DTA800B1 and I can confirm that the tuner is a little more sensitive w/ the newer DTA800B1 version given the EXACT same setup. I also have the Zenith DTT901 and I think the tuner of the DTA800B1 may not be quite as sensitive, but I can not be sure. I'm not worried enough about it to check it. For certain, the tuner w/ the Zenith is top notch even if some of the other parts of its design are not the most thought out (on box volume, for example).
cri123 is offline
post #94 of 116 Old 01-19-2009, 09:35 PM
Mikp's Avatar
I have a dta800b1 but am wondering if I should get a dta809. On widescreen mode on some stations I get black bars on the sides and top and bottom of the tv not just top and bottom!, switching to another station is quite slow, the color is a bit off and I can't delete useless stations. Did they improve these flaws with the dta809?? I'm going to get a smart antenna because I have lots of weak stations from differnt directions.
Mikp is offline
post #95 of 116 Old 01-19-2009, 10:34 PM
Todd76's Avatar
I'm assuming the sales tax rate is closer to 10% and not 50%. So why do you have to pay sales tax on the $40 the government is paying?
Todd76 is offline
post #96 of 116 Old 01-20-2009, 11:51 AM
JoeM's Avatar
The DTA800B1 only has two aspect ratio settings, letterbox and zoom, even though the government requirements indicate it should have a third full or partially zoomed ratio. Switching speed depends on what you are comparing it to. I think no two boxes are indentical in color. In the Channel List you can set it to skip a channel. I don't have a DTA809. All these boxes have their pluses and minuses. Do you presently have an exterior antenna ?
JoeM is offline
post #97 of 116 Old 01-20-2009, 03:51 PM
Mikp's Avatar
Does the partial zoom only letterbox 16:9 and not letterbox + pinstripe 4:3? Thsts really annoying Does it also take going through 5 menu to change? The channel switching is slow compared to analog. I have an internal antenna and can't change that. You're right about the channel skipping method.
Mikp is offline
post #98 of 116 Old 04-11-2009, 03:59 PM
Doc Sief's Avatar
Location: Eagan, MN, southern suburb of St. Paul, 16mi from TV Towers
Hit the menu button, get the channel line up (screen that shows station, what's showing, what's coming up) just to the right of the channel numbers it says 'Stored'. Using the center 4 way rocker on the remote scroll down to the station you want to delete, move to left to high-light 'Stored', hit the center button, and that item changes to 'Skip'.
I personally like the DTA 809 better with the analog pass through.
Doc Sief is offline
post #99 of 116 Old 04-11-2009, 09:22 PM
JoeM's Avatar
Originally Posted by Doc Sief View Post
... I personally like the DTA 809 better with the analog pass through.
The DTA800B1 also has analog pass through.
JoeM is offline
post #100 of 116 Old 04-24-2009, 04:29 PM
yrwei52's Avatar
Originally Posted by DTV Reviewer View Post
I see on the approved government list the RCA DTA800B1L and DTA809 listed. Does anyone have any initial information on these units - differences from the current DTA800B1 model?
Our local Walmart stores (North Texas area) just received fresh shipment of RCA DTA800B1L which has been out-of-stock of 3 months. The S/N label is different from before and it included the manufacture date (February 2009) on the bottom of the converter box. They also put a "DTA800B1/DTA800B1L" sticker on the manual to cover up whatever the model number was on there. Don't know what has been changed on DTA800B1L from DTA800B1.
The box is manufactured by AVC Multimedia at Markham, Ontario L3R 1E3. The price is $49.87.
yrwei52 is offline
post #101 of 116 Old 04-02-2013, 01:10 AM
See The Light's Avatar
Quoted: 45 Post(s)
Liked: 59
I picked up a DTA800B1 at Wal-Mart for $49.87. It was Mfg. in Jan. 2013. It has the code BE3.
AVC Multimedia, Markham, Ontario -- Made in China
The bar code on the box is 0-62118-48003-7
My LCD flatscreen TV has only one 75ohm input and only one RCA input (this is, Yellow-Red-White), which are both already being used.
I wanted to use the VCR to watch OTA channels, so I needed a DTV Converter box.
So far no complaints, except that I would prefer the display that comes up each time you change the channel, to be see-thru, or, for the display to go away much quicker, on it's own.
Picture and sound is good.
I didn't want to spend big bucks on a DVR/VCR with tuner.....
Cable Channel Choice is the only choice I want to make !!
See The Light is offline
post #102 of 116 Old 04-02-2013, 10:38 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Surf through the menus as some boxes have settings for those features.
Floydage is offline
post #103 of 116 Old 04-03-2013, 11:11 AM
Rammitinski's Avatar
Doesn't that box have a guide of some sort?
If so, how is it?
Can you add single channels manually, or does the box need to be re-scanned?
Rammitinski is offline
post #104 of 116 Old 04-06-2013, 04:25 PM
Quoted: 45 Post(s)
Liked: 59
If so, how is it?
The RCA box shows what's on now, but I can't find a guide on the box for programs coming up later.
The B1 model does indeed allow you to a channel "add" scan vs. a complete re-scan.
post #105 of 116 Old 07-22-2013, 03:20 PM
seatacboy's Avatar
Quoted: 46 Post(s)
Liked: 29
I'm moving to a different home and may need one or two converter boxes for older SD televisions. This RCA box is readily available at Wal-Mart for $49.97. I realize a couple of other boxes are available through Amazon, like the Zinwell as well as some used Zeniths, but my big question here: what is the reliability of these boxes? Is the RCA DTA-800B1 any more or less reliable than the other CECBs, most of which have been out of production for some time?
One thing which I learned from looking at recent posts is that the most recent version, the DTA-800B1, does in fact allow a channel "add" scan in addition to the standard auto-scan. This makes the unit more attractive than it was previously.
Another thing I've read is that unlike a few other CECBs, the DTA-800B1 only offers the 4x3 aspect ratio, not 16x9. (Of course, it's also SD output).
If anyone here can answer these questions - particularly regarding whether the unit will still be working and functional one year from now - please chime in here or PM me. It's nice to see our old posts on this forum - and to be honest, it's unfortunate that LG terminated production of the Zenith DTT-900/901 CECBs.
seatacboy is offline
post #106 of 116 Old 03-28-2015, 03:34 PM
Quoted: 45 Post(s)
Liked: 59
My Zenith DTT900, that I got in April of 2008 died today. The Power does not come on.
So, I have put the RCA DTA 800 B1, that I had purchased at Wal-Mart in April of 2013, back in service.
I had preferred the on-screen displays of the Zenith, but will now go with the RCA!
post #107 of 116 Old 03-29-2015, 01:26 PM
jvvh5897's Avatar
Quoted: 36 Post(s)
Liked: 25
A lot of work has been done on the RCA box in this thread in last couple of pages:
RCA DTA800 Digital to Analog TV Converter Box
The box flash has been dumped, the code disassembled and a number of modifications can be done to it. There is a serial port along the back wall that is TTL, but easy to get it to work with a PC. All work on the box can be done through that port.
jvvh5897 is offline
post #108 of 116 Old 05-06-2015, 04:02 PM
Quoted: 45 Post(s)
Liked: 59
Question connecting RCA DTA 800 B1 using RCA cables to a Vizio E291-A1 LED flatscreen using the TV's Composite inputs....
I connected the yellow RCA cable from the DTA to the Y/V input on the Vizio TV.
But, I do not get a good picture. The picture is black & white for what I know is a color broadcast.
I'm assuming that the Vizio should accept the yellow RCA cable in that Y/V input and process a good picture with it.
In the Sanyo DP42840 TV, I used a similar hook up with good success.
Is there something I'm not doing in this hookup with the Vizio???
post #109 of 116 Old 05-07-2015, 10:50 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Y/V has me thinking it's a dual-mode input - Y for component and V for Video (composite); Vizio saving a few bucks, I've heard of this before on other newer TVs. Dig through the menus for a selector, probably in a video setup sub-menu.
Floydage is offline
post #110 of 116 Old 05-07-2015, 09:25 PM
Quoted: 45 Post(s)
Liked: 59
Yes, it's supposed to be a dual mode, they call it hybrid. I had the same thing on a Sanyo TV, but as a second Video plug in. The 2nd set of Component inputs would not work as a composite. There was a setting in the Sanyo Menu. (So, the Sanyo had 1 set of compsite inputs, and 2 sets of component imputs.)
But I have found no such setting in the Vizio, and assume it's an "auto" feature if I plug in a yellow cable.
post #111 of 116 Old 05-08-2015, 08:25 AM
crackedscreen's Avatar
Why are you connecting a converter box to a HDTV? It should already have a built in ATSC tuner.
crackedscreen is offline
post #112 of 116 Old 05-08-2015, 10:48 AM
Quoted: 45 Post(s)
Liked: 59
That's a Good question crackedscreen! And the answer is, that I have the 75ohm connection of the TV taken up by the connection from the wall, from Time Warner Cable. So, the only way to get the OTA signals is by way of the RCA connections from the converter box, as most TVs have only -one- tuner, either for cable, or for OTA, but not for *both*.
post #113 of 116 Old 05-08-2015, 10:59 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
B&W makes me think it's stuck in component mode. Page 18 of your manual shows a sub-menu title "Input Source Selection" with buttons for TV, AV, Component, and HDMI. Should be under "Settings" but I see there's also an "Input" button in the main menu. There's also an Input button on the remote but I don't know if that works 'deep' enough.
I didn't see any mention of an "auto" feature, not that I read the manual in great detail. But if it is I'd try another video cable, then another composite video source.
Floydage is offline
post #114 of 116 Old 05-08-2015, 11:27 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Sounds like more cheapening as I've seen both connectors on some TVs. Could use a switch. Maybe a two-way combiner (splitter in reverse) if isolation/interference isn't an issue, this method would lose half power for either signal though. Now you would have to toggle back and forth via the Tuner sub-menu for cable vs. OTA, and hopefully it has the smarts not to lose each one's scan settings after toggling.
I figured you were using the converter box because the Vizio tuner wasn't as strong, or for PIP. I just had to use one of my converter box/recorder setups for one channel that's recently given me bad reception since my older generation HD tuner box "can't handle the truth." SD beats erratic HD anytime.
P.S. Page 43 of the manual (specs) shows "Composite Inputs: 1 (Shared with Component)"
Floydage is offline
post #115 of 116 Old 05-08-2015, 11:32 PM
Quoted: 45 Post(s)
Liked: 59
Smile
I figured out where I got it wrong. I "assumed" that the "AV" was the CEC linking to the Receiver, as a Audio/Video "Receiver". But "AV" means one video and the left and right inputs.
I was looking at the DTA 800B1 through the "Component" Input on the Vizio. But I should have been looking through the "AV" input on the Vizio.
I now have the DTA 800B1 plugged into a Samsung TV. The Samsung also displayed an "AV" input, and the DTA 800B1 picture came in clear there. The Samsung, different from the Vizio, would not display any picture from the Component Input, because, for the Samsung, unless you have all three component video inputs plugged in, it shows no picture.
post #116 of 116 Old 05-09-2015, 12:18 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Glad it worked out.
Me, I'd try combining the coaxes like I mentioned above. I'd try the splitter first but chances are some frequencies will overlap. The switch will work but needs to have decent isolation (I mention that because I have an old worn one that I can tell is leaking signals across its ports). Of course the switch method may be too much of a pain for you unless you transitioned to a remote control type after determining if it works. But if it requires a fresh channel scan every time you change the TV's input mode then I would blow the whole thing off (you can test this manually before trying any combining tests).
Now if that cable is SD you might have a device like a VCR that could tune it and spit out the A/V to the TV on a different input, leaving your Vizio RF input open for OTA antenna. Some converter boxes 'might' have had that capability too.
Floydage is offline
Reply Coupon Eligible Converter Box (CECB)
