sylvania TB100MG9 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 04-25-2008, 07:24 PM - Thread Starter
lexus2108's Avatar
sylvania TB100MG9
Would someone have the SEARS link for the sylvania TB100MG9
I found it yesterday and I thought i saved it but I can no longer find it.
I searched and searched. Did Sears and Kmart remove it?
If someone saved the link please post it
ty
lexus2108 is offline
post #2 of 16 Old 04-25-2008, 07:58 PM
dagger666's Avatar
http://www.kmart.com/shc/s/p_10153_1...e=Televisions&...
Sylvania DTV Digital-To-Analog Converter - Model TB100MG9 at Sears.comSylvania DTV Digital-To-Analog Converter TB100MG9 at Sears.com.
http://www.kmart.com/shc/s/p_10153_1...e=Televisions&... - 100k - Cached - Similar pages
but it comes up not found
dagger666 is offline
post #3 of 16 Old 04-25-2008, 09:47 PM
TalkingRat's Avatar
Liked: 32
Yeah, this is the second time it has disappeared. It was back a couple days ago, and KMart search forwarded me to Sears. But it's gone again. Sears is improving, at least the futile search no longer pulls up womens undergarments.
TalkingRat is offline
post #4 of 16 Old 04-25-2008, 09:52 PM - Thread Starter
lexus2108's Avatar
ok
post #5 of 16 Old 04-25-2008, 09:52 PM - Thread Starter
lexus2108's Avatar
thanks it might come back then
post #6 of 16 Old 04-26-2008, 03:17 AM
Malouff's Avatar
dagger666 you have to click on Cached link
I am also attaching an image in case Google changes it's cache.
Malouff is offline
post #7 of 16 Old 04-26-2008, 05:43 AM
dagger666's Avatar
the image is small but don't see any air holes
post #8 of 16 Old 05-06-2008, 11:22 AM
tvdavid666's Avatar
It just has some small vent holes on the bottom side edges.
tvdavid666 is offline
post #9 of 16 Old 05-06-2008, 12:22 PM - Thread Starter
lexus2108's Avatar
mine did not even get warm in 4 hours.
post #10 of 16 Old 05-17-2008, 10:06 PM
avsfuser1's Avatar
Could someone who picked it up at Sears please post Sears item number (can't make it out on the jpeg posted and can't find the page itself anymroe)? Would make it easier to call and check inventory before driving to the store. Interested in digits after 057.
Also, those who have it - still no regrets getting it, right?
avsfuser1 is offline
post #11 of 16 Old 05-17-2008, 10:19 PM
Malouff's Avatar
Sears item# 05757778000 Mfr. model# TB100MG9
The link is to another Google cache and I don't know how long it will remain.
Malouff is offline
post #12 of 16 Old 06-17-2008, 12:58 PM
DTV Reviewer's Avatar
Has anyone ever found a universal remote code from any universal remote manufacturer that will operate the Magnavox TB100MG9 CECB) of any of its other clones - Sylvania, Philico, etc.). As we all know - the remote that comes with the unit is really cheap and will fail.
Other than using a learning remote I have never found any code from any inexpensive universal remote manufacturer (RCA, GE, One-for-All, Sony, Philips, Magnavox, etc. - the most commonly available) to operate any function on the Magnavox box - even the simple on and off function.
DTV Reviewer is offline
post #13 of 16 Old 06-17-2008, 04:37 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
Perhaps the new Funai converter boxes use newer control signals not activated by older remote codes used with universal remotes.
A quick look at the twelve pages of codes supplied with Philips universal remotes lists three codes (0259, 0862, 0565) for Magnavox under SAT/DTV/WebTV; whereas an older RCA universal remote lists one code (5085) for Magnavox (the same for Philips) under Satellite; and one code for Magnavox (5025) and three codes for Philips (5025, 5011, 5012) under Cable (perhaps a cable converter box).
Have you tried the search function on your universal remote?
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
post #14 of 16 Old 06-18-2008, 11:25 AM
Yes, I have tried every code for every device for every manufacturer and came up empty handed. Search function - same result. A learning remote which of course costs as much - or more - than the CECB itself with government coupon - does work if you program it. I'm returning the Magnavox units and buying the RCA DTA800B which works with any universal remote I have laying around the house. Makes life a lot easier for me and the wife. After all, all the CECB needs to do is replace the analog tuner in the TV - it does not have to tell me the time, what channel I'm on, what's on, what's next, cook breakfast, or answer the phone. Just tune the channel and they will all do that. For the $10 plus some tax at Wal-Mart the RCA is the best of the best. Simple - works - no problems.
post #15 of 16 Old 06-18-2008, 11:30 AM - Thread Starter
lexus2108's Avatar
Only bad part is you will lose the 4 hour epg and get the RCA NOW and next
post #16 of 16 Old 05-12-2011, 03:13 PM
tcblackcat's Avatar
STB UNIVERSAL REMOTE CODE = 4737 (from Magnovox 1-800-605-8610)
tcblackcat is offline
Reply Coupon Eligible Converter Box (CECB)
