How do I program DTT900 to turn tv on/off - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-18-2008, 04:42 PM - Thread Starter
HillsdaleBob's Avatar
My mom has a DTT900 that works great. But, she wants to use it with a different tv and can't remember how to program the DTT900 to turn the tv on/off. And, of course, the owner's manual has been misplaced. I notice the owner's manual is not on the Zenith website. There are a couple other items, but they don't tell how to do this.
Can anyone tell me the steps to do this?
THANKS in advance.
HillsdaleBob is offline
post #2 of 9 Old 05-18-2008, 04:50 PM
Malouff's Avatar
Malouff is offline
post #3 of 9 Old 05-18-2008, 05:16 PM - Thread Starter
Thanks Malouff! The quick set up guide didn't include instructions for using the remote to control tv power, but the Insignia user manual did. You just gave me a nice present to give my mom.
post #4 of 9 Old 05-18-2008, 05:19 PM
Malouff's Avatar
You should also post the answer for others
I know not everyone will look and others will ask.
Malouff is offline
post #5 of 9 Old 05-18-2008, 05:27 PM - Thread Starter
Good idea. You turn the converter box on, hold down the tv power button on the remote control and repetedly hit the channel up (or down) key. Eventually the tv will turn on/off. When it does - you've programmed it.
They also have a list of the brands of tv that this will work with in the manual.
post #6 of 9 Old 05-18-2008, 08:37 PM
Rogee's Avatar
After programming the remote, do the volume buttons control the actual TV's volume, or does it only control the box's volume?
Rogee is offline
post #7 of 9 Old 05-18-2008, 08:40 PM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
The converter box remote controls the converter box volume only.
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
post #8 of 9 Old 05-18-2008, 09:11 PM
TalkingRat's Avatar
If the first code she finds doesn't turn the tv back on again, have her keep going through the codes. I had to, to find the right one that did both. I'm also much happier now that I've programmed it into my learning remote.
TalkingRat is offline
post #9 of 9 Old 05-18-2008, 09:39 PM
Malouff's Avatar
It probably depends on if the remote codes required by the Zenith Converter Box and your TV are shared like they are for Nightowl4 if you can control the volume on your TV.
Originally Posted by Nightowl4 View Post
The Gridlink codes are the same as Toshiba TV which I have so if you change volume with the Toshiba remote it changes it on the TV and the box.
Malouff is offline
Reply Coupon Eligible Converter Box (CECB)
