Zenith DTT901 - Page 77 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #2281 of 2296 Old 10-31-2014, 01:58 PM
jvvh5897's Avatar
Quoted: 36 Post(s)
Liked: 25
I've been trying to figure out why the converter boxes do some of these strange things, as most of them do lock up in various ways. In most cases it seems to be that the signal gets corrupted and the PIDs that the box sees do not match the channel info that they have for the channel and that gives them trouble--usually just requires changing channels to fix. But sometimes the signal get so corrupted that the boxes go into an error mode and rather than reboot under that condition the box just stays in the error mode.
jvvh5897 is offline
post #2282 of 2296 Old 10-31-2014, 03:01 PM
SFischer1's Avatar
Quoted: 492 Post(s)
Liked: 62
They were designed to government specifications and to be produced for as low a cost as possible.
That means lower cost parts which will mean a short intended life span and many problems.
When I ordered my top of the line RCA last analog NTSC TV the sales person explained that the set I ordered was built on the same production line as a cheaper model, but with better components.
Spending top dollar paid me back a huge amount in enjoyment. It controlled my VCR almost as well as I control my HTPC with a program I just reinstalled as the paid listings server will change at midnight.
http://www.avsforum.com/forum/26-hom...-new-post.html
SHF
SFischer1 is offline
post #2283 of 2296 Old 11-01-2014, 11:03 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Yeah that is the case on my CM, changing the channel and powering off then back on didn't work. It seemed to do the interline bit the most when watching football on certain stations, maybe something with the football field grid lines; I think NFL Monday Night Football when it was on NBC was the most common for me.
I've read of other boxes with the potential PID problem you mentioned.
One model of Zinwells gives me a pixelation problem when there's noise on the same AC line like a fan turning on. Retuning the channel cures it. Looks like insufficient power supply filtering inside as these use a simple wall-wart. I have another model of Zinwell that doesn't have this problem yet it uses the same wall-wart, but it uses a different tuner and maybe a different MPEG decoder IC.
I think these type of problems have more to do with lack of thorough software testing&debug than cheap parts. Parts are parts for the most part in this day and age (although some of the more complex ICs could be the same software culprit if they were designed only for these inexpensive tuner boxes - ex: if they weren't produced for HD output use too). It takes a lot of engineering resources and time to thoroughly test modern digital electronics, plus when these were designed there wasn't a lot real world and finalized infrastructure to system test.
Floydage is offline
post #2284 of 2296 Old 11-03-2014, 08:44 AM
jvvh5897's Avatar
Quoted: 36 Post(s)
Liked: 25
I've had rca, channel master, and higher end digital stream boxes to play with and all had the trouble that seems to be PID corruption during signal acquisition trouble. All seems to have the error on other corruption issue too--at least all seem to have to be rebooted by a power cycle. My best guess is that since they are diff platforms and diff processors, that the only common element is the code that came from the ATSC format owners--I'm guessing that they supply flow diagrams or sample code for various core functions (like signal acq) and the box programmers just wrap that in the user interface as is (maybe they are prohibited from changing the core functions as part of license). If that is true then all of the boxes and TVs that follow the ATSC format have built in bugs.
jvvh5897 is offline
post #2285 of 2296 Old 11-03-2014, 10:09 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Never had these kind of problems with my Zinwells, Artecs (although my Artecs haven't been used much), and HD tuners. My HD tuners are from way before CECBs; One is a Hughes DirecTV right before they started requiring sat. subscription for the ATSC to function 'freely' and one is Motorola's first HD tuner.
What's odd on the CM is that I have to pull the plug live to fix it. When I plug it back in it goes through some kind of unique display cycle that I don't see on normal power on, kind of lack they do out of the box but without any setup screen.
Floydage is offline
post #2286 of 2296 Old 12-03-2014, 03:35 PM
Bismarck440's Avatar
Quoted: 786 Post(s)
Liked: 147
Guide Limitations on the 900/901?
What are the guide limitations? Always thought it was 2 pages, but on one of my PBS subs I noted 7 pages of program summary on certain programs.
My Westinghouse TV only gives 2 lines, then cuts it off, shows an arrow but no way to scroll down.
I've been trying to figure out why the converter boxes do some of these strange things, as most of them do lock up in various ways. In most cases it seems to be that the signal gets corrupted and the PIDs that the box sees do not match the channel info that they have for the channel and that gives them trouble--usually just requires changing channels to fix. .
Note, the Zenith has to be on the channel to gather PID
Bismarck440 is online now
post #2287 of 2296 Old 12-05-2014, 01:44 PM
jvvh5897's Avatar
Quoted: 36 Post(s)
Liked: 25
I don't know the guide limits for the Zenith box as I don't own one. I've seen a lot of variability in various other devices and in documentation--limit seems to be what the TV channel operators decide to put on the air. One TV I had would do about 8 hours of guide on PBS, but it took 10 minutes or so to gather the last couple of hours of that.
The RCA DTA800b only does what is on and what is next.
One TV I have now only give what is on--and that is the newest device I own so you would think it would do more than older devices.
The docs for guide data suggest that TV operators send out some data very very often. A 3 hour guide every 3 minutes or so. And more data at longer intervals if they desire, but it is not required.
jvvh5897 is offline
post #2288 of 2296 Old 12-08-2014, 01:13 PM
Quoted: 786 Post(s)
Liked: 147
My bad I meant the program description box in the upper Left corner (which is part of the guide.... well sort of)....
That was one weak point of the Zenith/Insignia/LG, only gives you the next program, where the Magnavox/Sylvania went 6-8 hours ahead in some cases (much like the iView).... forgot how the guide was in the Apex, but believe it was still better than Zeniths.
post #2289 of 2296 Old 01-28-2015, 11:04 AM
Quoted: 786 Post(s)
Liked: 147
That's PBS-Wo (PBS-Word), that gives 7 pages of info, haven't seen this anywhere else.
post #2290 of 2296 Old 10-07-2015, 10:37 AM
Quoted: 786 Post(s)
Liked: 147
I guess I been proved wrong, I obtained another Zenith 901 with a May '08 Production date (used), & this one appears to power up no problem in the cold.
Guess I ended up with a couple of lemons.
post #2291 of 2296 Old 01-31-2017, 04:50 PM
Quoted: 786 Post(s)
Liked: 147
Zenith DTT901 Cold Start Issue Fix
As we venture toward ATSC3, & a need for another converter box.
Seems this is a very known issue with this unit:
http://www.videokarma.org/showthread.php?p=3151678
Replace C123 - 1000uf @ 10v, a thanks to the poster that had a little more time than I did to be hitting these caps with freeze spray, I couldn't quite isolate this on my unit down to a single cap, but this will be a good place to start!
I still have the 2 that need repair, & yes I still use these.
post #2292 of 2296 Old 02-22-2017, 06:49 PM
bdfox18doe's Avatar
Quoted: 213 Post(s)
Liked: 116
Wow..Me personally, I do get the bit about fixing something with just a bad cap..tho when I just got an iKonvert SC-57
from Amazon warehouse for $13 delivered...at what point do point I move on...
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #2293 of 2296 Old Yesterday, 10:36 AM
Quoted: 786 Post(s)
Liked: 147
Point taken, but aside of this cold starting issue there is no tuner like the one in the 901 for picking up stations in my fringe area, beats my iView3500 hands down. When my local surplus store re-opens I'm picking up a few caps, should have them both fixed < $2.00.... I no longer purchase online anymore.
Sure, I'd like the HD capability, I'm currently using one of these boxes where I have rabbit ears & can not accommodate my attic antenna at this time, also use them on the VCR's for time shift.
Your iKonvert, another Homeworx/iView Clone?
post #2294 of 2296 Unread Yesterday, 10:42 AM
bdfox18doe's Avatar
Quoted: 213 Post(s)
Liked: 116
I have not compared directly.. same chipset as one of the small westinghouse tv's I have..tho
I have a large pile of cheeseboxes in the closet.
Bob
post #2295 of 2296 Unread Yesterday, 08:17 PM
JHBrandt's Avatar
Quoted: 1502 Post(s)
Liked: 749
I have not compared directly.. same chipset as one of the small Westinghouse TV's I have..tho
If you post a screen-shot of the iKonvert's menu, we can tell right off. (Either way, $13 is a heck of a deal.)
What chipset does it (and your Westinghouse TVs) use?
JHBrandt is offline
post #2296 of 2296 Unread Today, 10:39 AM
Quoted: 786 Post(s)
Liked: 147
I'm not all that impressed with the tuner on my '12 Westinghouse 40", mediocre with the outdoor antenna, but was sufficient, & useless with bunny ears.
You lost me at Cheesebox?
Westinghouse was using at least 2 types of interface firmware in their sets in '13 or '14.
Reply Coupon Eligible Converter Box (CECB)
