Serial control CECB - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-05-2008, 02:10 PM - Thread Starter
jhfry's Avatar
Anyone know of a CECB that can be controlled via a serial connection of some sort... preferably with passthrough and S-Video out as well.
I am hoping to use 2 of them to feed my mythtv server's tuner cards. I realize I could just get more HD tuners, but I intend to leave my SD tuner cards connected to cable anyway and I thought it might be nice to get my broadcast channels in crystal clear downscaled HD rather than noisy cable when my HD tuners are in use.
Anyway, I have no interest in dealing with ir blasters... they too flaky.
jhfry is offline
post #2 of 4 Old 06-05-2008, 02:33 PM
pixelation's Avatar
See the Tivax STB-T9 thread.
pixelation is offline
post #3 of 4 Old 06-06-2008, 03:15 AM
whitis's Avatar
FCC ID UVD20071228001 Shenzen MTC AT2016, Also known as Alpha Digital AT2016, AMTC AT2016, RJ-900ATSC, Mustek MAT-K50, an dTivax STB-T9.
This box has a serial port "for factory use only". If you connect a PC at 115200N81 you get a ZMon> prompt. Using the zir command, you can simulate the pressing of any button on the remote control.
Look in the Tivax STB-T9 EPG thread, starting around message #90.
You will need to hack your TiVo (get a shell prompt and all that) and figure out a way to get the tivo software to call a script when it needs to change channels or otherwise get control of which commands it sends (there may be a data file you can modify) or insert a programmable gadget between the two serial ports.
whitis is offline
post #4 of 4 Old 06-06-2008, 07:51 AM - Thread Starter
jhfry's Avatar
Thanks guys... I'll investigate those devices. Any recommendations? Any of them have svideo out?
jhfry is offline
Reply Coupon Eligible Converter Box (CECB)
