Consumer Reports posts results of converter box tests - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 65 Old 10-16-2008, 08:13 AM
CasualOTAer's Avatar
Originally Posted by medoug View Post
I have concluded that Consumer Reports is choosing to ignore the CECB reception issue to limit the amount of testing required and to avoid admitting that they were wrong to not include reception sensitivity in their previous tests. Unfortunately, no matter how many times you repeatedly say that there is no difference between CECB reception sensitivity, it won't make it so.
Doug.
[/indent]
Zing!
Unfortunately, I have friends who picked their CECB based on CRs' report without consulting me first. They've relied on CR for years, so why not trust them now? Well, they are paying the price with spotty reception even though they are well situated in the suburbs between two major markets.
But, as has been pointed out many times on AVSForum, for many folks, it will come down to the antenna set up they use. Even more than CECB sensitivity variation.
CasualOTAer is offline
post #62 of 65 Old 10-16-2008, 03:48 PM
medoug's Avatar
Agreed. You need both a good antenna setup as well as a capable CECB. Digital signals alone won't insure a perfect picture....(though the governmental commercials concerning the digital transition may lead you to think otherwise.)
medoug.
medoug is offline
post #63 of 65 Old 10-17-2008, 04:28 AM
electrictroy's Avatar
Yeah. Anybody who's tried a DISH DTVpal versus a Zenith converter box *knows* there's a difference in reception. The DTVpal only brings-in about two-thirds as many stations as the Zenith box, and the DTVpal experiences tons of dropouts while the Zenith remains rock-steady.
I've come to the conclusion that "everett whitney" does not know much. He thinks a HDTV will have a better tuner, but the truth is that HDTVs don't have to pass FCC testing, so in reality they are inferior to the Coupon-eligible boxes.
electrictroy is offline
post #64 of 65 Old 10-18-2008, 12:53 AM
Rammitinski's Avatar
I actually find them to be pretty even in my situation. In fact, I think the PAL holds on to some of my fringe stations slightly better.
Now, if you're talking multipath, that may be a different story - but I don't really have that problem much so I can't tell.
And the tuner in my little cheapo 19" Dynex LCD is every bit as sensitive and holds onto weak stations as well as my CM-7000's. Probably depends on the TV.
Rammitinski is offline
post #65 of 65 Old 11-09-2008, 08:46 AM
DigaDo's Avatar
Quoted: 22 Post(s)
Liked: 27
On November 1st a Consumer Reports poster inquired about updated converter box ratings. Consumer Reports November 8th response puts their next update in late December or January 2009:
http://discussions.consumerreports.o...03eltelevi#a13
That's just swell . . .
"A ROSE BY ANY OTHER NAME WILL SMELL AS SWEET. BUT IT DOES NOT FOLLOW THAT WHATEVER WE CHOOSE TO CALL A ROSE WILL POSSESS THE ROSE'S FRAGRANCE."
--Benjamin Breckinridge Warfield (1917)
DigaDo is offline
Reply Coupon Eligible Converter Box (CECB)
