Dish DTVPal technical and TVGOS topic - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Closed Thread
post #811 of 822 Old 09-23-2008, 03:25 PM
Rammitinski's Avatar
Yeah, with the Pal you have to set it to special, three-digit numbers. PM me if you want details.
Rammitinski is offline
post #812 of 822 Old 09-23-2008, 04:50 PM
frank70's Avatar
Quoted: 107 Post(s)
Liked: 82
More simply, if you want channel 9.1, you need to tell you unit to ask the DTVPal for channel 191 (100+C*10+S, where C is the channel number, and S is the subchannel number.)
frank70 is online now
post #813 of 822 Old 09-23-2008, 05:43 PM
avnstf's Avatar
forgive me for asking, but what is the point of this if the DTVPal doesn't yet work in the TVGOS mode (since Gemstar isn't yet broadcasting the proper type of TVGOS data for this purpose)?
OTA only. For signal strength at your location: FCC DTV reception map
TVGOS data: Sony 250 from 5.1?, LG3410a from my DTVPal setup here, not any more.
avnstf is offline
post #814 of 822 Old 09-23-2008, 05:53 PM
avnstf's Avatar
on another subject, jut updated the list of digital station known to be broadcasting TVGOS (of course the list is actually much larger):
http://www.avsforum.com/avs-vb/showt...6#post14362176
avnstf is offline
post #815 of 822 Old 09-23-2008, 11:02 PM
You only have to set the recorder's timer, rather than both the recorder and the tuner's timers.
(It's actually a lot more dependable than the DTVPal/TR-40, and you don't have to deal with any military time like on the Zinwell.)
post #816 of 822 Old 09-28-2008, 04:50 PM
Jan J's Avatar
Quoted: 37 Post(s)
Friend called me today. His Chicago Based DTVPAL Guide is running 2 hours ahead of real time.
Set for Central Standard time, and Daylight Savings time enabled.
So I check mine (Also Chicago based DTVPAL Guide).... Same +2 hours difference between Real Time, and Guide time.
So to doublecheck, I called someone that I installed a DTVPAL, and guess what... Their Guide is running +2 hours ahead of real time!
I then go through and do a complete setup on our DTVPAL..... Scan, Zip, and Central Time, with Daylight Savings.... Guess What? +2 hours Guide to real time!!
I'm wondering if it's something in the CBS time setup in Chicago?
Sent email to a 'friend'. Let's see what happens!
Looking for a 1939 Indian Motocycle
Jan J is offline
post #817 of 822 Old 09-29-2008, 12:57 AM
Jan - just checked CBS on my CM-7000, and it's exactly 2 hours ahead. So it's definitely not the Pal.
post #818 of 822 Old 09-29-2008, 12:24 PM
dattier's Avatar
Quoted: 127 Post(s)
Liked: 56
WBBM-DT's PSIP clock has been nearly two hours ahead since the station's move on September 22.  I phoned their engineering department on the twenty-fourth, they said they knew and they were working on it, but now it's even worse and more than two hours fast.
dattier is offline
post #819 of 822 Old 10-02-2008, 08:45 PM
Jan J's Avatar
Quoted: 37 Post(s)
Now one hour behind
Jan J is offline
post #820 of 822 Old 10-03-2008, 12:48 AM
It's correct now.
post #821 of 822 Old 10-03-2008, 01:27 AM
kenavs's Avatar
It's correct now.
It looks like a number of stations around the country were sending out incorrect information in their PSIP data. They were reporting that the transition from DST was on 02, but they set the field too early. It should have been 00 until 10/3/2008 at the earliest, since the transition is not until 11/2/2008. I suspect it was a software bug in software used by a lot of stations.
The transmissions messed up the time displayed on the guide by my Vizio TV. It seems to be OK now. I suspect the stations started sending out the signal that DST is active with a transition date of 00, and the receivers are able to correctly go back to DST since there can be no confusion what that combination means.
kenavs is offline
post #822 of 822 Old 10-03-2008, 09:41 PM
Ken H's Avatar
Please continue the discussion in this existing topic:
http://www.avsforum.com/avs-vb/showthread.php?t=1001979
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Closed Thread Coupon Eligible Converter Box (CECB)
