AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Coupon Eligible Converter Box (CECB) (http://www.avsforum.com/forum/186-coupon-eligible-converter-box-cecb/)
-   -   Zinwell ZAT-970A? (http://www.avsforum.com/forum/186-coupon-eligible-converter-box-cecb/1048100-zinwell-zat-970a.html)
vwilliams322 07-11-2008 01:03 PM
Does anyone have this box? Does it have timers like the DTVPal?
Couldn't find it on the website:
http://www.zinwell.com.tw/index.php
Lmvine 07-11-2008 02:52 PM
Check this site & look at runner. All I know.
http://www.watchdigitaltv.com/
biker19 07-16-2008 12:38 PM
Let the comparisons with the DTVpal start......
biker19 07-16-2008 12:46 PM
From their web site:
Product Features
· Terrestrial 8-VSB demodulation
· ATSC 18 video formats decoding
· ATSC HDTV complaint MPEG2 MP@ML/ MP@HL decoder
· Compatible with HDTV, EDTV and SDTV displays
· User-selectable CH3/CH4 NTSC RF output
· ATSC AC3 audio decoding
· Modern design with user-friendly OSD interface.
· Aspect Ratio 16:9/ 4:3
· Multilingual support
· Automatic and manual channel scan
· Closed Caption, V-Chip and EAS (Emergency Alert System) Support
· Support Advances Rating (Rating Region Table downloadable)
· Software upgrade
Operation 120VAC, 60Hz, 8W max.
Standby <1W
Dimensions 175 x 135 x 33 mm
Weight 0.98lb.
External power adaptor
biker19 07-16-2008 12:47 PM
The unit supposedly has an 8 event timer but it's not listed in the features.
vwilliams322 07-16-2008 02:13 PM
They are not available until mid August and my last coupon expires 7/31. I guess I'll get the DTVPal
avnstf 07-16-2008 02:22 PM
it also only mentioned an rf output, which probably implies only mono audio, judging by the other boxes
rrrrrroger 07-16-2008 02:33 PM
WHY on earth do they have 3 separate models??? If there's a difference between the 3, it's not apparent to me.
Do any of these have Separated-video?
TalkingRat 07-16-2008 02:55 PM
The 970 has RCA connectors, and apparently an external power adapter:
http://www.zinwell.com.tw/Products/pdf/CECB.pdf
biker19 07-17-2008 07:27 AM
Their HD STB sells for as low as $70 so I can see this unit retailing for well under the $60 norm.
rperlberg 07-17-2008 11:05 AM
All CECB's are required by the NTIA to have both RF and A/V (stereo) outputs.
gastrof 07-17-2008 11:16 AM
The website watchdigitaltv.com has this message up-
The Zinwell ZAT-970A with Analog Pass Through and 8 Event Timers, Has Passed All of Our Tests ((( ETA second week of August )))......
They'll be selling the box, apparently.
trp2525 07-18-2008 09:55 AM
Here's the link to the full Zinwell ZAT-970A User Manual: http://www.zinnetusa.com/download/za...l-20080603.pdf
It is software upgradeable by either RS-232 or by air as referenced here in the user manual:
"Software Upgrade
On the Software Upgrade menu, press to
select an upgrade method and press ENTER
into the menu. You need to input the default
password 0000 " to enter each item as
follows:
Upgrade By RS-232
On Upgrade By RS-232 menu, press to
select the All/ Code/ Logo/ Database upgrade
item. Then move highlight to Start on master
receiver and press ENTER to start upgrade.
This function is reserved for factory s upgrade
currently.
Upgrade By Air
This function can upgrade the software
through signal from the cable. Input the
frequency value and download PID, and select
bandwidth."
You can also manually modify the clock setting as referenced in the section on setting up your program timers:
"Current time information will display on the first row; if
the current time is incorrect, please modify the time
information in Time item"
In addition to 8 program timers there is also a sleep timer which can be set to off, 1 hour, 2 hours, 4 hours or 8 hours.
This box looks really good on paper and also in the online review I read. For those of you who haven't seen the hands-on online review yet, you can read it here: http://www.king-cart.com/18inch/prod...ct_match=exact
visualsensation 07-18-2008 01:41 PM
It looks like this one will be everything that we had hoped the DTVPal would be. I just hope it becomes available before my next coupons expire on 8/15.
Malouff 07-18-2008 06:59 PM
I don't get digital but was wondering if the station is sending the wrong time for the clock
is the PSIP guide correct and independent of the time the station is sending?
If not then I don't see a manual clock setting helping anything.
Beeper 07-18-2008 09:03 PM
The timers have two distinct external issues. The manual clock setting would somewhat help one of them.
Problems is, the Zinwell manual clock has already flunked a power disruption test and resets to 00:00 internal clock time. You would also need a backup power supply, which would also cure one of the issues with the Pal's timer.
Six to one, half dozen to the other.
Beeper
Malouff 07-18-2008 09:23 PM
So the Zinwell's manual clock was just letting you set a manual time that it kept so long as it had power.
Even if they did add the extra cost for the parts for a true manual clock that can also drift it would not give any additional benefit other then keeping the clock during a power outage that you could not see or use.
Like you said you would need a power supply for both the converter and the recorder during the power loss.
I wonder how accurate it's manual time is then?
What is it using to keep time, probably something like a click count.
So do you think the manual time would fix anything if the Guide is also dependent on the station's time?
I know that power supply is one external issue with the timers.
What is the other one that you are thinking of?
How would the manual clock setting help somewhat with the other?
visualsensation 07-19-2008 07:43 AM
Most VCR's in the homes of people who need a converter box don't retain their time or timers long after a power outage. I have had about 10 different VCR's over the years and none did. The newest ones automatically set the clock, but the timers are always gone. Of course they were all low to mid range models. The very expensive VCR's might, but most people who own those don't need a converter box because they don't get their signal OTA.
It is an inconvenience, but most people can live with it. But it is much, much better than having to check the timers each and every day just because at least one or two stations' time is or eventually will become inacturate.
Beeper 07-19-2008 09:20 AM
And letting you use it for the timers? I haven't personally tested it.
It's already been determined that the Zinwell manual clock will not keep time during a power disruption. It would still be an option to be used for the timers.
Correct.
I haven't the foggiest.
Yes. When the user chooses to set the internal clock manually, the manually set time would replace what the timer was using. (PSIP time.)
The other external issue is the possibility of inaccurate individual station PSIP clock time.
The manual internal clock (if chosen as an option by the user) would fix that issue, since the box's timers would no longer find the PSIP clock time.
Beeper
Beeper 07-19-2008 09:23 AM
Hi neighbor!
Go Brewers!
Miller's gone, Bud is gone, whos' next?
Beeper
visualsensation 07-19-2008 06:31 PM
Ya, Sabathia has been lights out so far....Just need the Cubs and Cardinals to cool off a little.
DigaDo 07-21-2008 11:59 AM
My familiy's last remaining coupons expire 8/18.
Here we go again!
Beeper 07-21-2008 12:24 PM
Yeah, and Poovantage is taking pre-orders...................................................... ....................................................... Not.
Malouff 07-21-2008 12:34 PM
Here we go again!
Did you ask Zinwell who will be selling the converter?
So far only one retailer has been mentioned Bruce's Antenna Systems
Have you tried to ask FreeDTVShop if they will sell the Zinwell?
DigaDo 07-21-2008 05:26 PM
Perhaps we shouldn't get too excited just yet . . .
We'll just have to wait and see . . .
TalkingRat 07-21-2008 05:39 PM
There is one Zinwell model on the NTIA approved/available list and three more Zinwell models on the approved/unavailable list, none of them the ZAT-970 or ZAT-970A.
Actually, there are 3 Zinwell models on the approved and available list -- the NTIA just needs someone who knows how to alphabetize. The first two Zinwellls, the 970 and 970A, appear on the list ahead of Zenith, that's all.
ownersedge 07-21-2008 05:47 PM
Notice the Zinwell as NO EPG apparently, so timers will mean little to me. TitanTV.com excellent Guide is on my computer away across the house; any way to feed it to my TVs?
How long should I hold out before buying? I mainly want the D2A tuner to bring EPG to my RCA HDTV. And for my analog TVs in my motorhome. So is there a history of these boxes being significantly updated by download?
The Gemstar Guide+ EPG has very limited subchannels in its platform, and no ability to add any subs as they become available. Like it is a hard-wired 2005 model; I am on a budget.
All suggestions welcome !
DigaDo 07-21-2008 09:06 PM
Whew! Fix the font size.
Malouff 07-21-2008 09:14 PM
I don't want the Zinwell.
I thought you did and was trying to help you.
I think it won't have a EPG and will work like the Gridlink, Lasonic, and Sansonic category of boxes.
I do admit I am curious but have a full plate with a DTVPal in hand a waiting for my beloved MicroProse
TalkingRat 07-21-2008 11:33 PM
Yes, the lack of EPG would make it less useful. I'm not sure why the Lasonic/Sansonic got such fantastic reviews by Consumer Reports. Microtune may mean it does well with adjacent channel interference, which they probably had where CR was testing.
Powered by vBulletin® Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
