Can Magnavox TB100MG9 decode 5.1 audio?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-04-2008, 08:15 PM - Thread Starter
NickG's Avatar
Just got this today.
Can someone tell me if the Magnavox TB100MG9 decodes 5.1 audio, either thru RF or the audio out jacks. The manual really says nothing about audio.
Plus when I use the audio out jacks to my receiver the gain is considerably lower than going thru RF.
Picture wise though, combined with the Radio Shack "UFO" antenna, the video quality is very good!
Thanks!!
I may be wrong but I'm not wrong long.
NickG is offline
post #2 of 8 Old 10-04-2008, 08:18 PM
Scooper's Avatar
It is a REQUIREMENT of ATSC tuners that they decode 5.1 audio. It is ALSO a requirement that there audio output is limited to 2 channel stereo (maybe Prologic encoded? ). Having a digital audio output makes them ineligible as a CECB, as does including any video output beyond composite/S-Video that could enable HD Video.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #3 of 8 Old 10-04-2008, 08:51 PM - Thread Starter
NickG's Avatar
So, in other words, NO...right??
NickG is offline
post #4 of 8 Old 10-04-2008, 10:56 PM - Thread Starter
NickG's Avatar
one more thing....how is this box as far as running it with a universal remote?
NickG is offline
post #5 of 8 Old 10-05-2008, 09:25 AM
dattier's Avatar
Quoted: 127 Post(s)
Liked: 56
Just to clarify: Scooper's second sentence (about the requirement), like the third, applies only to the ATSC tuners in CECB's.
dattier is offline
post #6 of 8 Old 10-05-2008, 10:46 AM
Scooper's Avatar
ok - to clarify -
HDTV ATSC tuner -
CAN have Dolby Digital 5.1 output (HDMI / TOSLINK / digital coax)
CAN have HDTV capable outputs (component, DVI, HDMI )
Can also have NTSC video and stereo analog audio outputs.
CECB ATSC tuner
can ONLY have analog stereo RCA or RF outputs
can have only NTSC capable video outputs (RF, composite, S-Video)
Scooper is offline
post #7 of 8 Old 10-05-2008, 07:27 PM - Thread Starter
NickG's Avatar
what about using a universal remote with it. yay or nay?
also, right now i have a splitter going into my tv, one for the antenna/converter and one for my sat. is there a way for this setup to be used to avoid splitting and hopefully avoid the signal loss from splitting it?
thanks.
NickG is offline
post #8 of 8 Old 10-06-2008, 09:39 AM
CasualOTAer's Avatar
thanks.
I don't have the Magnavox box, but I've had good luck using this remote from Target http://www.target.com/GE-5-DeviceLea...0remote&page=1 with my Zenith and DS CECBs. I've used the learning feature to add some of my favorite functions from the CECB to the remote. I haven't seen a universal remote that has buttons set for all the CECB functions...
If your TV has multiple inputs (RF in and Composite, at least), you can run the satellite receiver into one and the OTA converter into the other.
If not, some folks use switchboxes instead of splitters to reduce the loss.
Also, depending on how you hook it up, you may need to use a diplexer, rather than a splitter to keep the CECB from seeing the DC voltage your satellite receiver sends up the line to the dish. If your OTA antenna isn't hooked to the cable that runs to your sat. receiver, this shouldn't be a concern for you.
CasualOTAer is offline
Reply Coupon Eligible Converter Box (CECB)
