Insgnia: Video goes dark at times - AVS Forum | Home Theater Discussions And Reviews
Old 10-14-2008, 09:47 PM - Thread Starter
Dr Becker's Avatar
At times, the video goes out on the Insignia. For all channels. This lasts for 10 minutes or so then comes back. Turning the unit off and on again does not fix it.
Anyone else having this problem?
Dr Becker is offline
Old 10-15-2008, 09:05 AM
CasualOTAer's Avatar
Just curious, does it only happen on the composite outputs, or on the RF, too?
CasualOTAer is offline
Old 10-15-2008, 10:21 AM
systems2000's Avatar
systems2000 is offline
Old 10-15-2008, 11:00 AM - Thread Starter
Dr Becker's Avatar
This is the APT model. Good question about RF or composite. I don't have the RF connect set up so can't comment. I think I'll try that. TV screen just goes dark for long time, then eventually comes back. Seems to happen maybe 1-2 times a week.
Old 10-16-2008, 08:37 AM
If it doesn't happen on the RF output, consider trying a new composite cable on the composite connections. One of the simplest things to try next.
Old 10-16-2008, 08:47 AM
Also, make sure you have a clean solid connection on the TV. Many RCA connections will build up dust and oxydation over the years from non-use. I've also seen loose connection boards in some TV's.
Old 11-10-2008, 07:35 AM - Thread Starter
Dr Becker's Avatar
I thought I should update this entry. The problem was in the TV, not the set top box. Turns out that dust had accumulated inside on the chassis and caused something to overheat. It just needed a good vacuuming.
