Has anyone received (and tested) a "DTV pal PLUS"? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-17-2008, 02:37 PM - Thread Starter
slprp1's Avatar
Quoted: 12 Post(s)
Liked: 49
I was very curious (and I'm sure that others are as well) how the picture quality is (as compared to the mediocre at best PQ on the original models)? ......
and is there a real difference in sensitivity (the original models did very well in this area to begin with!)?
(BTW - The original thread seems to have no comparisons or tests of this new unit)
Also - Have there been any retail (in store) sightings of this new unit?
slprp1 is offline
post #2 of 5 Old 10-17-2008, 02:58 PM
Scooper's Avatar
Should get it Monday - will probably be Tuesday before I can give a report.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #3 of 5 Old 10-18-2008, 07:23 PM
Scooper's Avatar
Came today.
F/W - F106
No better or worse than any other CECB I've had on reception ability at my location.
Haven't tested timers yet, but TVGOS is working in my area (confirmed from stations Engineer), so I don't expect any issues on that score.
Scooper is offline
post #4 of 5 Old 10-19-2008, 02:37 PM
arxaw's Avatar
Originally Posted by Scooper View Post
...No better or worse than any other CECB I've had on reception ability at my location.
Any idea what chipset it uses, or what they are basing their claim of better fringe reception on?
arxaw is offline
post #5 of 5 Old 10-20-2008, 06:00 AM
Ken H's Avatar
Use existing topics.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Closed Thread Coupon Eligible Converter Box (CECB)
