EchoStar TR-40 recording - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-19-2008, 02:01 PM - Thread Starter
gailybug's Avatar
I have an Insignia standard cecb. The longest it stays on is 4 hrs., therefore not allowing me to record something after it turns off. Will the TR-40 allow me to record something after it has turned itself off when I'm at work? Or is there something I can do to use my Insignia for timer recording? I don't want to start panicking yet!
gailybug is offline
post #2 of 3 Old 10-19-2008, 02:56 PM
Scooper's Avatar
On all these CECBs, you should be able to find an "Inactivity Timer" that by default is 4 hours. You should be able to disable this. Start looking in your manual / menues.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #3 of 3 Old 10-19-2008, 09:54 PM
Ken H's Avatar
Use existing topics.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Closed Thread Coupon Eligible Converter Box (CECB)
