RF A/B switch box recommendations, please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-24-2008, 11:02 AM - Thread Starter
Aside from the Radio Shack unit, which has very poor reliability reviews on the RS site, can anyone recommend an A/B switch with good quality? We have one TV with only a single RF input so I need to switch between the DTT901 and a Leap Frog.
aka N0NB
Nate_KS is offline
post #2 of 10 Old 10-24-2008, 12:16 PM
golinux's Avatar
Liked: 29
I have a Radio Shack A/B with remote and it works fine. It does take up another outlet but well worth it to be able to do everything from 'command central'. I previously had the manual A/B switch and it sometimes it produced an interference pattern that required a little voodoo to correct. No problems with the remote version (so far).
May the FORK be with you!
golinux is offline
post #3 of 10 Old 10-25-2008, 12:21 AM
Rammitinski's Avatar
Originally Posted by Nate_KS View Post
Aside from the Radio Shack unit, which has very poor reliability reviews on the RS site..
I've had the remote version for over a couple of years, and have never had a problem with it.
Rammitinski is offline
post #4 of 10 Old 10-25-2008, 08:06 AM
SoonerTheBetter's Avatar
Quoted: 21 Post(s)
Liked: 26
Me too. No problems with mine whatsoever.
SoonerTheBetter is offline
post #5 of 10 Old 10-25-2008, 02:19 PM
dattier's Avatar
Quoted: 127 Post(s)
Liked: 55
Originally Posted by golinux View Post
I have a Radio Shack A/B with remote and it works fine. ... No problems with the remote version (so far).
I had one, but it bit the dust after a few years.
dattier is offline
post #6 of 10 Old 10-25-2008, 04:57 PM
ihlite's Avatar
There's one with remote available online at mcmelectronics.com ; part number 32-4425, for less $$ than Radioshack, but I don't have one.
ihlite is offline
post #7 of 10 Old 10-25-2008, 05:05 PM
golinux's Avatar
Liked: 29
And this is a user comment left on that item:
I haven't done a full test of this item. An obvious flaw, however, is that the switch does not terminate the unused input. The unused input is left open.
Not quite sure how that would effect things.
golinux is offline
post #8 of 10 Old 10-26-2008, 07:47 PM - Thread Starter
I guess I wasn't thinking about the model with the remote as we have enough remotes already and this is on a TV that gets used about once per week and I'm usually within reach of it.
aka N0NB
Nate_KS is offline
post #9 of 10 Old 10-26-2008, 10:20 PM
300ohm's Avatar
I use an old Channel Master A-B switch and its always served me well. Its a well built push button model. I think they are still available for less than $10. I also have some sliding A-B switches that came with some video game consoles. They are not as well built.
300ohm is offline
post #10 of 10 Old 10-30-2008, 03:43 AM
norbert26's Avatar
I just picked one up a GE manual one at local store on clearance for $2.00 . I use it to switch from basic analog cable to OTA DTV. No problems and its no bulky like the big thing radio shack wanted $16.99 for. I passed on the remote one at radio shack as i don't need another plug taken up.
norbert26 is offline
Reply Coupon Eligible Converter Box (CECB)
