Big CECB Missing Feature: AUTO-TIME - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 10-26-2008, 02:07 AM - Thread Starter
6volt's Avatar
Quoted: 51 Post(s)
One of the few "luxuries" of the analog system was the time code broadcast by local public television stations to automatically set the timer on VCR's.
I'd bet big money there is a time code embedded in the digital signal and that it is off the table for analog conversion.
I have never heard this topic discussed. Perhaps it has been already in which case apologies.
Tom
6volt is offline
post #2 of 12 Old 10-26-2008, 06:04 AM
biker19's Avatar
Quoted: 23 Post(s)
Been talked about many times - it's built into the PSIP data stream of every ATSC signal.
biker19 is offline
post #3 of 12 Old 10-26-2008, 06:45 AM
electrictroy's Avatar
Read the DTVpal or TR-40 threads, and you'll see that autotime is a *lousy* feature. In fact it was a lousy feature on the PBS analog channels too.
Why?
Because the time is almost never right. My local PBS station (MPT) ignored daylight time, leaving my VCR an hour off, and when they eventually got around to fixing it, the time was still off my several minutes.
The DTV clocks are no more accurate. Auto-clock is a lousy feature and I stopped using it years ago. MANUAL clock is the best feature, and it should be provided with every box.
electrictroy is offline
post #4 of 12 Old 10-26-2008, 12:26 PM - Thread Starter
6volt's Avatar
Quoted: 51 Post(s)
I admit there can be problems with the maintaining of the autotime, however, I have found that the PBS stations are quite responsive if you call them up and ask them to correct the problem.
I've done this a few times and I've always, eventually gotten satisfaction.
While the station can screw your clock up, power outages while on vacation you can absolutely count on.
Right now, I run my A/V and computer of a 2200 v-a (1600watt) Tripp lite server rated UPS.
That also solves the problem of the Philips HDD DVDR buffer which dumps when there is a power outage.
What is really bad is that the digital time code will probably be spot on. I would guess it is synced with GMT like those cheap "atomic clock" clocks.
6volt is offline
post #5 of 12 Old 10-26-2008, 12:39 PM
Scooper's Avatar
Supposedly - the stations are SUPPOSED TO keep their PSIP time within a minute (or is it a second ?) - the reality is that not enough are paying that much attention right now. I would hope that after analog is shutdown - getting these details "right" will become more important.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #6 of 12 Old 10-26-2008, 03:16 PM
It's faster and easier to just set the clock yourself. time.gov provides the precise time down to the second, and I set my VCR and DTV tuner accordingly.
post #7 of 12 Old 10-26-2008, 05:52 PM
biker19's Avatar
Quoted: 23 Post(s)
Not for the the great numbers of folks whose VCR time still blinks 12:00.
biker19 is offline
post #8 of 12 Old 10-26-2008, 07:55 PM
systems2000's Avatar
The FCC doesn't care about the disparity in time syncs of the broadcast stations and considers it a problem that the viewer needs to contact the station to resolve. That's what they told me.
systems2000 is offline
post #9 of 12 Old 10-27-2008, 01:57 AM
Rammitinski's Avatar
My analog PBS time has never been anything but spot on.
Rammitinski is offline
post #10 of 12 Old 10-27-2008, 04:36 AM
Even after the Daylight Savings Time ends? My MPT station could go weeks before it finally got corrected.
Really. It's just easier to set the clock myself.
post #11 of 12 Old 10-27-2008, 05:25 AM
It's fine right now on my Panny EH75V. It's an hour off on my older E85H, which I've been setting manually more recently since I've been using it with the CM7000.
Our time station here has traditionally always stayed right on top of things.
post #12 of 12 Old 10-27-2008, 07:22 AM - Thread Starter
6volt's Avatar
Quoted: 51 Post(s)
Definitely sounds like nothing but problems.
I have to laugh, my PBS station keeps setting time codes as follows (they change every few days(!)):
Correct, Off by 1 hour, Off by 1-2 hours and some random number of minutes!
My guess is the signal strength is and issue since I do a 4-way split of my incoming cable. But still, these results are definitely wacky.
6volt is offline
Reply Coupon Eligible Converter Box (CECB)
