Casti CAX-03 Opinions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-30-2009, 07:25 PM - Thread Starter
pgtr's Avatar
I did a search and did not find any threads on this particular unit. Nor does it appear to get any votes either way in the best/worst sticky.
I downloaded the manual and it seems to have a number of handy features for my needs including a universal remote that offers basic TV on/off and volume. Has analog pass thru and the manual I downloaded seems pretty straightforward.
Can be had locally for $40 (free w/ coupon).
I would appreciate any comments on this unit - thanks!
pgtr is offline
post #2 of 12 Old 02-01-2009, 09:54 AM - Thread Starter
pgtr's Avatar
Anybody?
Comments perhaps on other CAX-0x models?
pgtr is offline
post #3 of 12 Old 03-09-2009, 07:31 PM - Thread Starter
pgtr's Avatar
One last try... Anybody know anything about this make/model...?
pgtr is offline
post #4 of 12 Old 03-09-2009, 08:17 PM
NaiveMelody -NYC's Avatar
I haven't tried this model, but I did find this - click here > http://www.wvah.com/dtvconverterboxes/casti.shtml < small info/ review. I guess your gonna have to try it out and post back your review.
NaiveMelody -NYC is offline
post #5 of 12 Old 03-09-2009, 08:40 PM
Scooper's Avatar
I'm afraid you're the only one to mention it.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #6 of 12 Old 03-09-2009, 09:55 PM
300ohm's Avatar
Casti Cax sounds like an odd name for a converter box, heh. Do they even have a marketing dept ??
300ohm is offline
post #7 of 12 Old 03-09-2009, 10:16 PM - Thread Starter
pgtr's Avatar
OK Thanks
pgtr is offline
post #8 of 12 Old 03-09-2009, 11:15 PM
pm3839's Avatar
i've done a lot of research on as many cecb boxes i could find but i've never even heard of CASTI....sorry....it might be best to stay away from this one?
if youre looking for $40 (free w/coupon) try the Artec T3AP at
https://secure.freetvsignal.com/viewAll.php
.....'*Artec T3AP converter box $40.00. Free Shipping to all 50 states including Puerto Rico, Guam, and The Virgin Islands. This box is completely FREE when you use your government coupons.'
update>
i looked at the CASTi CAX-03 manual and it does look very good on paper> it has some control buttons on the box, most other cecb's have none....the universal remote is a rare/nice feature and it looks to be well laid out....and the remote has channel FLASHBACK, which i think is essential....etc etc
the screen shots in the manual look identical to my Artec T3AP box....maybe its a clone of it? if so it should be ok.....my Artec T3AP works well.....
so the CASTi CAX-03 looks very promising, on paper anyways....see if u can find a forum where u can read some 'real world' user reviews on it....
*** its high time to go back to OTA antennas and CANCEL our cable/satellite pay tv services! their greed is totally & insanely out of control! ***
pm3839 is offline
post #9 of 12 Old 03-10-2009, 11:14 AM
WeThePeople's Avatar
Well Here is the CASi product page.
It is in Korean (.kr).
I couldn't find this box there though.
CASTi = Cast Information Co.
CASTi makes these for Daytek and Zentech to distribute rebranded
They have a website for just the CECB product line here.
CAX-03 UPC = 8-84372-00503-6
CASTi Service Center
13115 Barton Road Suite E
Whittier, CA 90605
Tel 877-685-8443
Tel 562-941-7001
Fax 562-946-7445
Support@CASTiConverter.com
The stores I found it in mostly listed it as discontinued.
That can't be good...
Various Info:
MPEG Decoder = LG LGDT1111D (CAX-01)
Tuner = LG (Innotek) TDVG-H052F (CAX-01,03)
Tuner = Sanyo UB110AP (CAX-04)
The CAX-02 seems to be a bit of a mystery.
The government lists these like this
Approved & Available:
CASTi CAX-03
Approved & Not Available
CASTi CAX-01
CASTi CAX-02
Daytek CAX-01
Daytek CAX-03
Additional government list
Her is the:
Pic
Users Manual (CAX-01,03,04)
Quick Start Guide (CAX-01,03,04)
Program Code List (Universal Remote)
Reviews:
WCHS-TV ABC-8
Sold At:
$40 - HEB
$40 - HEB Plus
For almost all of us that have never heard of it...
Features:
Analog Pass-Through
Universal Remote Control
Receive DTV (ATSC) Broadcasting
All 18 ATSC Formats Decoding
Closed Caption
Aspect Ratio
Channel Add
Parental Control (V-Chip)
Program Guide
Auto Power off (Sleep Mode)
CH3/4 RF Output for conventional analog TV set Energy star compliant
Fully compliant with CECB requirements
Specifications:
TV System: DTV (ATSC)
Tuning System Type: F/S
Tuner Type: TDVG-H152F/LG Innotek
Program Coverage: DTV2~69
Channel Add, Channel Edit, Manual Scan
Closed Caption, Program Guide, Aspect Ratio
FLASHBK (Previous Channel)
Auto Power Off (Sleep mode)
RF Modulator Output (Ch.3/Ch.4) in On mode
Analog Pass-Through (in standby)
Volume Control
OSD Language: English, Spanish, French
Universal Remote Control (TV: 4keys Box: 31keys)
Antenna In (1)
RF Output (1)
Video Output Video Out (1)
Audio Output (L,R)(2)
Power:
AC 120V, 50/60Hz
Under 8W (on) / Under 1 W (off)
Energy Star compliant Dimensions:
W x D x H: 180 x 171.4 x 38 (mm)
Weight: 1.1 Kg
Accessories:
User Manual (included Program Code List)
Remote controller
Battery
RF cable
Quick Start Guide
Well, thats all I could find in a few minutes time.
Hope it helps form better google search terms for those looking...
James Clerk Maxwell spins in his grave,
not along his long axis,
but head over heel
We The People
Doppler Effect: Effect of stupid ideas appearing smarter when they come at you rapidly!
WeThePeople is offline
post #10 of 12 Old 04-12-2009, 09:07 AM
popoami's Avatar
I bought a CAX-03 analog to digital coverter box in September but it died on me in March. Doesn't work anymore and the power light doesn't even go on. Yes, I tried another outlet that works for something else. So do NOT buy one!
popoami is offline
post #11 of 12 Old 04-13-2009, 11:11 AM
300ohm's Avatar
What did you expect with a name like Casti Cax ?
Casti implies "to cast" and Cax sounds like the ooze Jar-Jar Binks stepped in.
300ohm is offline
post #12 of 12 Old 12-26-2009, 09:23 PM
bored866's Avatar
This unit Really stinks. It cuts power so frequently you can try to watch tv for days on end and you won't be able to. The system work fine at first, but has become a decorative piece of junk.
bored866 is offline
Reply Coupon Eligible Converter Box (CECB)
