Trouble with Zenith DTT901 menu function - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-18-2009, 01:04 AM - Thread Starter
cyrix01's Avatar
Hi all. I just bought a Zenith box, and was playing around with the adjustments. In Setup Menu I changed the Output Channel from 3 to 4, but the reception is not so great on 4 (ghost images). I want to go back to 3. Trouble is, I can't move the menu cursor to make the change. I tried every which way on the remote with no luck. Any ideas?
cyrix01 is offline
post #2 of 4 Old 04-18-2009, 08:09 AM
Dan Kolton's Avatar
Try unplugging and replugging.
Dan
Dan Kolton is offline
post #3 of 4 Old 04-18-2009, 09:32 AM - Thread Starter
cyrix01's Avatar
Thanks. Yes, I tried that but no luck. Maybe I have a defective unit? Can someone get into their Setup Menu, go to Output Channel and see if they can move the cursor for the channel choices (3 and 4)?
cyrix01 is offline
post #4 of 4 Old 04-18-2009, 10:20 AM - Thread Starter
cyrix01's Avatar
Hey, I unplugged/replugged the antenna cables, and the output channel automatically switched to 3. So I'm fine now. Whew.
PS- Before I had only unplugged/replugged the power cord!
cyrix01 is offline
Reply Coupon Eligible Converter Box (CECB)
