Craig - CVD508 CECB - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 08-20-2009, 07:23 PM - Thread Starter
WeThePeople's Avatar
Updates since original post:
1 - It has been pointed Sunkey out by Systems2000 in post #4
that this may also basicly be a SK-801ATSC as well.
I can confirm the exterior to be identical except for the smoked plastic insert.
I have confirmation in POST#8 by NTSC that the board is also the same,
not just the plastic casing.
Seems they chose a different remote control supplier though.
I chose to get a couple of free boxes (with free S&H).
These are the folks that topped Google, so I tried them.
I ordered these two, and they arrived just fine, and free!
*** See model-specific AVSForum threads for info ***
Craig - CVD-508
Artec (Ultima, Jiangsu) - T3AP-LL (LG Tuner)
Note:
They put the two display boxes in a FedEx envelope bare,
they DID NOT provide the display boxes external boxing !
It wasn't even a "Bubble-Wrap" style envelope !
Free-TV Signal -AKA- Cerebral CorTech
Home:
https://secure.freetvsignal.com/index.php
All CECB's:
https://secure.freetvsignal.com/viewAll.php
Website Feedback:
admin@freetvsignal.com
Cerebral CorTech
Mark Bymaster
1718 Corporate Dr
Boynton Beach, FL 33426
561-572-2164
M-F 10A-5P Eastern
CerebralCorTech@gmail.com
Craig - CVD508
External Product Information:
Model Sticker:
Craig
DIGITAL TO ANALOG BROADCAST CONVERTER WITH REMOTE
POWER SUPPLY: DC 12-V, 0.8-A
Craig Electronics International Ltd.
P.O. Box 694650 Miami, Florida 33269, U.S.A.
For Customer Service
e-mail: service@craigelectronics.com
(Un-Labeled White Sticker = Serial Number)
C090531**** (Last four omitted for privacy)
Manufacture Date: May 2009
Wall-Wart Sticker:
(Transformerless Switching-Mode Type)
AC/DC ADAPTER
SWITCHING POWER ADAPTER
MODEL: TP20S1208
INPUT: AC 100-240V ~ 50/60-Hz 0.8A MAX
OUTPUT: DC 12V = 0.8A
WFFICIENCY LEVEL IV
SHENZHEN TOPOW ELECTRONICS CO., LTD.
MADE IN CHINA
Notes:
Mobile-Friendly:
This unit is negative ground
(Some China TV's are POSITIVE ground, ALWAYS measure !!!)
22.09-Milliamp @ 12.21-VDC (0.27-W) - Standby (Wall-Wart)
337.4-Milliamp @ 11.78-VDC (3.97-W) - Running (Wall-Wart)
(364.7-Milliamp max while booting from flash boot sector)
This model Wall-Wart is terrible at voltage regulation...
The collor is negative,
and chassis ground.
The pin (Or center) is Positive 12-VDC.
Disassembly:
The bottom has four fully visable screws.
Various buttons, and the faceplate will fall off.
There is also a data jack cover on the bottom.
They chose to not use the rear tuner screw.
Tuner:
Samsung tuner is mounted sturdy by four shield corners.
Connection is by a row of 16 (5+11) soldered pins.
Active components are visible without removal/disassembly.
Bottom Access Data Jack J101:
Four pins, #1 is closest to PCB corner (Square solder pad)
#1 = TBA
#2 = Chassis Ground (Also 12-VDC supply Ground)
#3 = TBA
#4 - TBA
PCB Solder Side Numbers:
None
PCB Component Side Numbers:
EC
RU94V-0 (Backwards "R")
E188100 (Sunkey - SK-801ATSC = MS-1E1198407)
EC-2 2009
J1C1 = 4-pin Molex male jack on solder side of PCB:
1 - ? (Square Ground-Plane Relief)
2 - Chassis Ground
3 - ?
4 - ?
Notes:
Protrudes through case bottom, comes with plug cover.
Uses same plug as a standard home-PC audio connector.
JD2 = 3-Pin unmarked/unpopulated sodler pads:
1 - ? (Square Pad)
2 - ?
3 - Chassis Ground
JD3 = 20-Pin (10x2) unmarked/unpopulated solder pads:
J1 = 10-pin marked/partilally populated solder pads:
Silkscreened Information:
01 - Power - Power Button
02 - Down - Channel Down
03 - Up - Channel Up
04 - LED 1 - Green Power-On LED Indicator D8 (Diode-8) Anode
05 - LED 2 - Green Power-On LED Indicator D8 (Diode-8) Cathode (Chassis Ground)
06 - IRE_VCC - Infrared B+ (+3.12-VDCmeasured)
07 - IR_DAT - Infrared Senser Data
08 - Gnd - Ground
09 - IRE_VCC - Infrared B+ (+3.12-VDCmeasured)
10 - Gnd - Ground
Notes:
Pins 7, 8, 9 currently populated by an IR-Detecter hanging long-lead style.
PCB-Mounted microswitches still leave room to use all 10 pins.
D9 - Red Power Off LED Indicator:
1 - Red Power-Off LED D9 (Diode-9) Anode
2 - Red Power-Off LED D9 (Diode-9) Cathode (Chassis Ground)
SoC (System-on-Chip):
Realtek "RMC" Logo
RTD2885S
89F00S1
G838C Taiwan
Info:
!!! Has heatsink on it from factory !!!
MPEG Decoder SoC
Two transport processors
Digital audio decoder
Post-processor
High-definition (HD) MPEG video decoder
2D graphics engine
Digital video processor for both analog and digital video sources
NTSC/PAL TV encoder with Macrovision
Six high-quality video DAC's
Stereo high-fidelity audio DAC's
270-MHz Lexra processor
Peripheral control units for TV control functions
2TS demux
CCIR656 input
PCMCIA/Smartcard for CI/CA
MPEG MP@HL
2D graphic engine
Multi-layer OSD
CCIR656/BT1120 output
CVBS/S-video/Y/Pb/Pr out
I2S, SPDIF out
Stereo audio output
NAND/NOR IF
PCI
Reference Links:
http://www.realtek.com.tw/products/p...n=4&ProdID=134
RAM Memory:
Hynix 909AA A
HY5DU561622ETP=D43
KOR NAEE0849RG1
Info:
16-M x 16 DDR SDRAM
268,435,456-bit CMOS Double Data Rate(DDR) Synchronous DRAM
Reference Links:
http://www.hynix.com/datasheet/eng/g...U561622ETP.jsp
http://www.hynix.com/inc/pdfDownload...TP(Rev1.1).pdf
Samsung Tuner Housing Sticker (White):
SAMSUNG
DTVS22DPH261D
090515 EEC
Info:
Reference Links:
Tuner Numbers - Component Side:
Not observed,
solder side was visible without removal/disassembly.
Component Numbers - Solder Side:
32-Pin DIP Surface Mount IC
NXP
TDA6509ATT
CM9691 15
TPD09173
Info:
NXP is founded by Philips Electronics...
3-band mixer/oscillator and PLL for terrestrial tuners
Reference Links:
http://www.nxp.com/search/?query=TDA6509ATT
http://www.nxp.com/acrobat_download/...09_6509A_3.pdf
16-Pin DIP Surface Mount IC:
A77000
8XN3
Info:
Sanyo Semicon Device LA77000V
Monolithic Linear IC VHF Band RF Modulator USA CH-3,4
Reference Links:
http://www.alldatasheet.com/datashee.../LA77000V.html
http://pdf1.alldatasheet.com/datashe.../LA77000V.html
http://www.datasheetcatalog.com/data...LA77000V.shtml
http://www.datasheetcatalog.org/data...ksz4w1tgyy.pdf
8-Pin DIP Surface Mount IC:
8123
8XX2
Info:
Reference Links:
CraigElectronics.com Info:
http://www.CraigElectronics.com/
http://www.craigelectronics.com/contact_us.php
Not Working:
http://www.craigelectronics.com/prod...ne/CVD508.html
Previous Model:
http://www.craigelectronics.com/manu...E0OU1-B0RA.pdf
Craig Electronics
International Ltd
FL 33269-4660, USA
Tel: 1-866-321-7191
Email: service@craigelectronics
TinyPic.com Pictures:
http://TinyPic.com/WeThePeople
01 Craig - CVD508 - Display Box Front
02 Craig - CVD508 - Display Box Features
03 Craig - CVD508 - Formed Packaging
04 Craig - CVD508 - Remote Control
05 Craig - CVD508 - Connection Options
06 Craig - CVD508 - Transformerless Wall-Wart
07 Craig - CVD508 - PCB Component Side
08 Craig - CVD508 - PCB -Heatsink -Shield
09 Craig - CVD508 - PCB Solder Side
James Clerk Maxwell spins in his grave,
not along his long axis,
but head over heel
We The People
Doppler Effect: Effect of stupid ideas appearing smarter when they come at you rapidly!
WeThePeople is offline
post #2 of 17 Old 08-21-2009, 11:52 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Thanks again for the thread start and info!
Your answer to my question over yonder Artec thread doesn't sound too promising (sort of my fear with my previous brand/drug store comments).
I noticed they state "Stereo Audio Output" rather than the typical Dolby Digital Audio. I also don't see the Dolby Digital symbol in any of the pics.
Thumbs up on the heatsink unless the IC is inefficient. I see you got the heatsink to come off. Nice ventilation on the top of the box, looks like Ron gave contracting advice.
Floydage is offline
post #3 of 17 Old 08-21-2009, 05:36 PM - Thread Starter
Sadly, I have absolutely nothing good to say about this box,
so I'll just refrain from saying anything.
If I hadn't gotten it for free, I'd...
Anyway, back to the technical aspects of it.
The Realtex SoC with the heatsink works well within expected thermal boundries.
The IC does not run hot.
I ran the unit (to get the current draw numbers) with the heatsink off and monitored it for excessive heat while doing so,
in my opinion the heatsink has been added as a precaution only.
Although while googlin' around I did find a post out there on the World-Wide-Wait about a person that pulled the heatsink, then reapplied it with CPU paste.
He was commenting that it sizzled when he turned it on.
I suspect he used Arctic Silver paste which is conductive ...
With the ventalation holes too, there are no worries with this box, unlike that 9950 that went up in flames because the tuner sparked-out...
(In theory that was resolved, people stopped saying the F-Connector's were pistol hot after a while...)
On the "Dolby" topic, yes the SoC does support it. It would not run if it didn't. Those are just the bullet-points from the IC manufacturers webpage...
And what is it with manudacturers and "Mute" buttons???
If you have to uncomfortably wretch your finger,
or completely relocate your hand to get the "Mute" button,
your remote control design is a total failure!
Some make you use the other hand it is so far up (or down) in the corner, Grrr.
To me, it is the most used button, especially now that commercials have crossed the 50% mark of the amount of time they occupy in one hour's worth of "Commercial" (Pun intended) programming.
but head over heel
We The People
post #4 of 17 Old 08-21-2009, 08:14 PM
systems2000's Avatar
Is there a recall button on the remote? What information does the EPG supply?
This unit appears to be a clone of the Sunkey SK-801ATSC. I believe this was discussed before.
systems2000 is offline
post #5 of 17 Old 08-22-2009, 01:37 AM - Thread Starter
I hazard a guess you mean last channel recall to swap between two channels.
Nope
I Google'd up that unit and all is the same except for the smoked plastic insert on the front.
That is the "Branded" item they swap-out.
Oh, crud, I was hoping to do a tear-down technical review then throw it off a cliff as a frisbie or something...lol.
Um, when I pressed "EPG" (@2:18AM) I was presented with a tri-color vertical list starting at 02:00 and ending at 04:30 comprising of six entry lines.
So far so good, right?
1 - It is limited to 12 characters plus the obligitory elipse (...)
so most programs were undiscernable unless you knew them already.
Paid Prodramming... - Nice gow they made sure THAT fit fine...
Delicious Foo... - Gives you a general example of the problem I describe
2 - I was on a channel that was having a run of a particular show,
so the entries were all the same as the episode name is totally cut off.
3 - You are not allowed to change the channel while viewing your EPG
4 - When you repress EPG on the remote it disappears, then reappears.
It seems that you need to utilize a completely different button to eliminate this thing from your viewing screen.
They were kind enough to place said "Exit" button at the other end of the remote for pure convenience of their customers...how nice...
5 - You are locked out of all other functions of this remote by the EPG,
so when your trying to read it and one of those oh-so-nice ubber-loud commercials comes on in the background you can't even "Mute" it or use the two volume buttons.
In fact, except for the intangibly placed "Exit" button (At the other end of the remote),
no other button seems to do anything.
Are you feeling the love yet?
For the love of pizza, ask me any technical question you would like people.
I'll rip 'er apart and get the data.
(My o-scope's are packed at the moment due to additional construction to my house)
Just dont ask me to turn this friggin thing on again,
or I'll need spackle for the hole in my wall.
This was representitive of almost any and all of several functions I "Endured" during the FOUR minutes I managed to stand poking around functions of infuriating mis-design until I pulled the plug (OK, Wall-Wart..) vowing never to run this again except for tech-tests.
Gosh I hate this box!
Got an in-law you want to drive stark raving nuts?
This might fit the bill, give 'em one for free and see.
...The DT502 is very similar to the SK-801ATSC, except it has a metal case and includes many more desirable features and S-Video.
I have all three and prefer the DT502, with the SK-801ATSC a very close second.
Ouch, I find that frightening.
Perhaps I should mail you this clunker for direct comparison?
but head over heel
We The People
post #6 of 17 Old 08-22-2009, 08:58 AM
jjeff's Avatar
Quoted: 690 Post(s)
Liked: 246
This has got to be the most technically complete review of the worst box I've ever seen
Going off a point you made, I gave my least favorite CECB (A original DS-9900 I think) to my inlaws for a xmas present. I thought I had the last laugh....until they died and I got it back What goes around, comes around
I'm guessing you don't like this box
jjeff is offline
post #7 of 17 Old 08-22-2009, 12:57 PM
vwoom's Avatar
Remote layout looks better than the CM's...
vwoom is offline
post #8 of 17 Old 08-22-2009, 06:41 PM
NTSC's Avatar
I await someone to look inside and compare to my photo's as confirmation
that the PCB is the same production run as well.
Not just a re-used box for another brands PCB.
I can confirm that your CVD508 board is absolutely identical to the Sunkey SK-801ATSC board, both front and back. (Well except for the IR detectors.) My board is about 10 weeks older then yours and has MS-1E1198407 silk-screened on the front. Tuner is a Samsung DTVS22DPH261D. The remote however is entirely different.
NTSC is offline
post #9 of 17 Old 08-23-2009, 12:35 AM - Thread Starter
Thank you NTSC,
I have added a fair amount of additional data to this section of my teardown:
"PCB Component Side Numbers:"
The tuner number is the same on both brands.
Board Silkscreen Numbers:
E188100 = WeThePeople's Craig - CVD508 board number
MS-1E1198407 = NTSC's Sunkey - SK-801ATSC board number
They both are the same EC class of RU94V-0 (Backwards "R")
They both also seem to have the same:
J1 - UnUsed solder pads for a button array connected by ribbon cable.
JD2 - Unused 3-Pin solder pad set.
JD3 - Unused 20-Pin (10x2) solder pad set.
J1C1 - 4-Pin Molex Male Jack through case bottom.
Interesting about the remote though.
They have the exact same number of functions,
just a way different layout.
Wonder why they chose different suppliers for them?
but head over heel
We The People
post #10 of 17 Old 08-23-2009, 12:39 AM - Thread Starter
Why half-ass something that is already half-assed,
when one can make a complete ass of one's self? ...
To be fair, I was doing the same teardown on two CECB's I got for free (Coupon + Free-S&H).
The Artec/Ultima/Jiangsu T3AP-LL was the one I felt worthy of all the work really...
but head over heel
We The People
post #11 of 17 Old 08-23-2009, 12:59 AM - Thread Starter
Couldn't agree more.
It is the winner of putting the "Mute" button the farthest away possible.
(For a right-handed/thumbed) person I meant.
Bunch of communist lefties must make these?
(Couldn't resist the "Lefty" joke, sorry...)
but head over heel
We The People
post #12 of 17 Old 08-23-2009, 11:51 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Maybe the heatsink is for the 12V and therefore 'potentially' automotive use. Does any of the literature say it is for automotive use?
Yeah some of these remote layouts are bizarre, as if they outsourced the designs to primitive countries.
I'm not sure that it spits out Dolby Digital Audio. Decode the stereo portion, yes. It has to be licensed with the stamp displayed on the product.
That Apex DT502 comparison is "frightening," I 'wanted' to get one because the EPG is supposed to be real good (plus the S-vid and smart ant extras).
Well these boxes can always be used to sell a used TV as a package deal (I see that on Craigslist, looks like a scheme to circumvent the gov't rule not to resell CECB coupons).
You guys are funny. "World-Wide-Wait." I hear ya!
Floydage is offline
post #13 of 17 Old 08-23-2009, 04:10 PM - Thread Starter
That was the funniest thing I've read in a while!
"So simple a caveman could design it"
Sadly, your right, Dolby Digital output is forbidden in the CECB rulings
even though some units have a (Disabled) digital out jack.
They must however do mixdown of the multichannel Dolby stream,
not just peel off (just) the front left/right streams is my understanding.
I point this out because in It's analog form the additional "Suround Sound"
info in quite a few cases was still present before it was encoded.
Many here and elsewhere have been able to use non-digital surround decoding options
in their AV recievers to regain a surprisinglyy listenable surround effect
by just applying old fashioned analog phase encoding surround techniques
to material that was originally was made for the older analog surround decoders.
Sounds like mock reverse-compatibility to me...
Yeah, that was on my short list too, alongside a few that never made it to market/America...
but head over heel
We The People
post #14 of 17 Old 08-24-2009, 02:06 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Here is an example more clearly shown, see the bullet Features:
http://www.jascoproducts.com/hdtv/GE...verter-Box.asp
My Zinwell and CM have the Dolby Digital emblems but are less clear about it. The CM does state on the box "Experience digital quality picture and sound."
Question for ya: Is the RF/coax connector audio signal mono on CECBs?
The CM manual lists that connector as mono.
The Zinwell manuals (950A and 970A) don't say but have an audio selection menu description where they tell you to select Line Mode if using the composite connectors or select RF Mode if using the RF connector (the audio works either way on both connectors but is much louder in RF Mode).
These are the only brands I have thus far but my Artec LL should arrive tomorrow ().
I was being serious ("...outsourced the designs to primitive countries.").
Floydage is offline
post #15 of 17 Old 08-24-2009, 02:48 PM - Thread Starter
Nah, even though they could have implemented stereo modulators with the MTS/SAP format.
They chose not to mandate it, just the RCA jacks instead.
If they had, they would have to pay royalties to both "DBX Inc." and the subdivision (That got the MTS patents from DBX) called "THAT Corp.".
With the already ridiculous royalties already paid for the video and audio hardware/firmware/codec portions of the CECB's, MTS/SAP would break the price point even farther.
I mean, unless the parts of our airwave spectrum that got auctioned off was aportioned into $75 coupons instead that is.
Then we might have had higher standards of box available.
What me catch crap for that remark now...
but head over heel
We The People
post #16 of 17 Old 08-24-2009, 05:14 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
So another lucky option to get a box with stereo on the RF. Doesn't bother me per my setups but I could see having one of those economy TVs with stereo but only an RF input (I have two of these outside of the living room but they're mono).
Not from me. Gov't is throwing money at everything else so why scrimp on this?
Floydage is offline
post #17 of 17 Old 08-26-2009, 11:58 AM
I have already acquired six Sunkey units and they have the same problem with the EPG. I'd still like to try to upload the firmware that came with the first run Sunkeys to get more capabilities.
I didn't mean that the APEX DT502 is a bad CECB (I absolutely love mine (x3)), I was pointing out that the main boards are probably manufactured by the same plant (the APEX having an on-board power supply, while the Craig and Sunkey are bricks). Performance wise, the APEX DT502, Zinwell ZAT-970A, ZAT-950A, and Sunkey SK-801ATSC perform reception about equal and do it better than any other CECB I've used.
Reply Coupon Eligible Converter Box (CECB)
