Need some advice... - AVS Forum | Home Theater Discussions And Reviews
Old 11-03-2009, 03:17 PM - Thread Starter
ydk1's Avatar
Hi everyone,
Can anyone provide some advice on which converter box to purchase? My sister will be ending her cable service soon. Her govt coupon will be expiring soon and she's not sure which two to purchase. Most of the local stores no longer carry any of the converter boxes.
Below are the 3 CECB I found Amazon currently selling and problems I have read from the posts
Zinwell ZAT-970A (timer problem)
Digital Stream DSP7700P (runs hot...overheat)
Tivax STB-T8
Anyone know what is the difference between the Digital Stream DSP7700P vs DTX9950F?
ydk1 is offline
Old 11-03-2009, 04:01 PM
systems2000's Avatar
Take a look through the associated threads.
The Zinwell is a very good unit overall. The Tivax owners in the associated thread seem to have good results with the units.
systems2000 is offline
Old 11-03-2009, 05:40 PM - Thread Starter
ydk1's Avatar
Yeah...mostly like the Zinwell will be a recommend CECB. It now a toss between the Digital Stream DSP7700P and Tivax STB-T8.
I think most of the posts I read on the Tivax with good reviews refers to the STB-T9. Is there a big difference between the Tivax STB-T9 and STB-T8 model? I have read that Digital Stream's boxes tend to burn out and also a few cases of the Tivax STB-T8 being short lived. Not sure which of the two to recommend to my sister...
ydk1 is offline
Old 11-03-2009, 06:12 PM
yrog's Avatar
yrog is offline
Old 11-04-2009, 09:22 AM
According to WIKI, the 1009 has APT and the 2009 has S-Video (no APT?).
NOTE: EZDigital.com info on the 2009 shows that it does have APT, along with Smart-Antenna, and something called "Auto Time setting" - Timers?
Old 11-04-2009, 11:58 AM
Rammitinski's Avatar
How about the Artec? Isn't that supposed to be a virtual clone of the #1 recommended CECB, the Zenith?
Any of those to be found anywhere?
Rammitinski is offline
Old 11-04-2009, 10:14 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Artecs are available at Meritline.com and digital-tv-converter.net. Same decoder and tuner (Sanyo or LG depending on model) as the Zeniths. Also has the same real low power consumption as the Zenith.
I never heard of a TRT until now. Fantastic EPGs per those links. Wiki claims smart antenna. I wonder how much they cost? (seller website?).
Floydage is offline
Old 11-05-2009, 07:28 AM
I'm surprised I hadn't seen them until now too. I think I would have tossed a coupon at one too. Why would they come to the party so late?
Old 11-05-2009, 10:45 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Me too and good question. Is there a way to tell when it was listed on Wiki? There's so many on their list that I easily miss the more obscure ones. I suspect the TRTs just weren't marketed to the resale market very well.
Floydage is offline
Old 11-05-2009, 09:27 PM
pm3839's Avatar
Originally Posted by ydk1 View Post
Hi everyone, Can anyone provide some advice on which converter box to purchase? .......Below are the 3 CECB I found Amazon currently selling and problems I have read from the posts
Tivax STB-T8......
i have the ZINWELL...it works well overall....the timer issues are minor....just check it occasionally to make sure its still what u programmed it as...sometimes it gets corrupted....it has no other real problems and very good pic quality...
also, the ARTEC and the TR40 aka DTVPAL are good units.... consider them if u can still find one....
all these units have some kind of minor issues....none are perfect....
edit> i havnt tried one but the MicroGEM MG2000 might be ok....and its totally free at >
https://secure.freetvsignal.com/viewAll.php
*** its high time to go back to OTA antennas and CANCEL our cable/satellite pay tv services! their greed is totally & insanely out of control! ***
pm3839 is offline
Old 11-06-2009, 12:51 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Check out my Zinwell post:
http://www.avsforum.com/avs-vb/showt...3#post17401173
If you use Favorites it's worth a shot as I suspect that may be what corrupts channel settings.
Floydage is offline
