Sunkey SK801ATSC, how to remove programmed channels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-18-2009, 07:54 PM - Thread Starter
chas2003's Avatar
I have a Sunkey SK801ATSC. I programed the channels with auto scan. It included some channels that don't exist and missed some that do. I tried manual scan it added some of the channels auto missed. But it also added some channels that come in too poorly to be of use. I can't figure out how to remove programmed channels. Does anyone here know?
Chas
chas2003 is offline
post #2 of 2 Old 11-19-2009, 09:35 AM
systems2000's Avatar
The Sunkey SK-801ATSC thread is located here: http://www.avsforum.com/avs-vb/showt...ghlight=sunkey
I will check my units, but I don't remember if there is a way to remove channels.
systems2000 is offline
Reply Coupon Eligible Converter Box (CECB)
