Insignia NS-DXA1 (Zenith DTT900) factory infrared commands - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-08-2010, 09:32 PM - Thread Starter
Bavi_H's Avatar
I discovered some special infrared signals that my Insignia NS-DXA1 converter box responds to: one brings up a factory mode menu, and one preforms a factory reset. I assume the same commands will also work on the Zenith DTT900, Zenith DTT901, and Insignia NS-DXA1-APT converter boxes.
Factory Mode Menu
Warning: Using the factory mode menu erased the channels on my converter box. (It left one valid channel and one invalid channel in memory, and also turned on the "Analog" CC1 closed captions in the menu.)
To get to the factory mode menu, start with the converter box on, then send the Factory Menu infrared signal (see below).
The menu displays two version numbers with time stamps and a checksum. It has items for front key test, NVRAM test, factory reset, service mode, and start download. The service mode item only has one option to change which rating systems are shown in the lock menu: US, Canada, or Both.
Factory Reset
To preform a direct factory reset, start with the converter box on, then send the Factory Reset infrared signal (see below). The box will put a FACTORY OK message on the screen, and the front panel LED will turn purple. You can then turn the box off and back on, and the initial setup screens will start.
Infrared Signals
If you are familiar with the NEC infrared signal protocol, the converter box uses address F7. The Factory Menu signal is command EA. The Factory Reset signal is command EB.
If you use LIRC or WinLIRC, You can start with this configuration file and uncomment the factory commands at the end of the codes section.
If you have a Pronto remote, a Palm handheld computer with OmniRemote, or another device that uses Pronto hex codes, here are the codes for the factory commands.
Factory Menu: 0000 006D 0022 0002 0156 00AB 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 05F2 0156 0056 0015 0E5F
Factory Reset: 0000 006D 0022 0002 0156 00AB 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 05F2 0156 0056 0015 0E5F
Bavi_H is offline
post #2 of 4 Old 04-09-2010, 06:46 AM
zaphod7501's Avatar
Quoted: 78 Post(s)
Liked: 65
There is also a JP-1 upgrade with the commands if that's your remote system of choice. I built that one about 2 years ago. There is also a discrete "off" command but no matching "on" signal.
Sturgeon's Law: "Nothing is always absolutely so."
Sturgeons Revelation: "Ninety percent of everything is crud."
My Thoughts: "A reasoned argument must share some basic common points."
zaphod7501 is online now
post #3 of 4 Old 04-09-2010, 07:06 PM - Thread Starter
Bavi_H's Avatar
I thought I found something exciting and new, but it sounds like you already knew about it? Is this factory menu already mentioned online somewhere? I must have been searching for it the wrong way.
I was really excited about the factory commands, but I did also find the "off" command. I thought it was odd I couldn't find an "on" command, so it's good to know other people didn't find one either.
Bavi_H is offline
post #4 of 4 Old 04-10-2010, 06:42 AM
zaphod7501's Avatar
Quoted: 78 Post(s)
Liked: 65
I know that I posted about it and probably a link also but I couldn't find it either on a quick search. After so long, memory fades. It could have been here or at the JP-1 site or even on the Home Theater Forum. Your info adds other remote types and brands that I could not include.
A discrete "on" command could be generated with a macro that sends "off" followed by "on".
JP-1 is handy for searching for hidden commands but there is always the danger of "bricking" the unit with a lethal signal.
Reply Coupon Eligible Converter Box (CECB)
