can I use a digital converter box as a tuner? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 05-19-2010, 07:33 PM - Thread Starter
airtas's Avatar
If a TV has no tuner can I use the digital converter box as the tuner?
or would that not work?
airtas is offline
post #2 of 15 Old 05-19-2010, 08:45 PM
Scooper's Avatar
Assuming your "monitor" has audio / video inputs it can (and it can process NTSC signals going into the inputs). The CECB (converter boxes) were speced to have at least the following outputs
1 RF coax with a channel 3/4 modulator
1 set audio (red / white RCA connectors) and
1 composite video (yellow RCA connector).
They were also allowed to have S-Video video outputs, but that was not a requirement.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #3 of 15 Old 05-19-2010, 11:00 PM
txrose's Avatar
You do know that these boxes only provide 480i video output.
If it isn't 720p or 1080i/p it isn't HD. If it is 720p or 1080i/p it may not be HD content.
txrose is offline
post #4 of 15 Old 05-20-2010, 12:07 AM
BCF68's Avatar
Yes but it won't be in HD. Unless the converter box has HD outputs. Those are typically expensive. What type converter box do you have and what kind of TV do you have and we can bettter answer the question.
BCF68 is offline
post #5 of 15 Old 05-20-2010, 08:33 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Yet another thread started on this subject, well kind of. Check out this thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1245502
Floydage is offline
post #6 of 15 Old 05-20-2010, 08:42 AM
Ken H's Avatar
The term converter box refers to the specific non-HD boxes the government was issuing coupons for.
New HD boxes start at $100. http://www.avsforum.com/avs-vb/showthread.php?t=179095
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #7 of 15 Old 05-21-2010, 06:31 AM
BCF68's Avatar
Of course it does but not everyone means that when they ask questions. Many people ask questions here about "OTA channels" when they actually are asking about HD locals from their cable company. Or as another poster pointed out a "TV" without a tuner is actually called a "monitor". Not everyone that posts questions here is up to the latest technology and terms. So some are not aware that government coupon eligible converter boxes are not capable of passing a HD signal. I see nothing wrong with making them aware of that.
which is twice the price of the SD boxes
BCF68 is offline
post #8 of 15 Old 05-21-2010, 08:50 PM
Ken H's Avatar
Neither do I, but the term converter box does not apply to HD STBs.
Ken H is offline
post #9 of 15 Old 05-21-2010, 10:27 PM - Thread Starter
airtas's Avatar
this is the scenario my uncle had a 37 inch Viore piece of garbage HDTV Ready TV with no tuner
He ended up upgrading and I wanted to hook up the TV
I know the "free boxes" only do SDTV but I was curious on if this box would constitute as a tuner for the cable feed
airtas is offline
post #10 of 15 Old 05-22-2010, 09:25 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
I don't think any of the CECBs have cable tuners. the only brand I can think of that might include it would be the TRTs (check out the TRT thread further down the CECB main list).
Floydage is offline
post #11 of 15 Old 05-22-2010, 11:26 AM
BCF68's Avatar
Those "free" converter boxes typically don't have QAM tuners in them. A box that does would also most likely have HD outputs. Those types of boxes are about $100 or more.
Your TV still should be able to handle the analog signal from the cbale company without any sort of box. Who is your cable company? If you're looking to get digital signals you'll need to get a digital box from your cable company. Even if the covnerter box had a QAM tuner you'd only get Clear Qam signals.
BCF68 is offline
post #12 of 15 Old 05-22-2010, 11:51 AM
Ken H's Avatar
None of the CECBs (converter box) have a QAM tuner (that works). It was part of the spec not to have that feature, even though the chip sets used had the ability to tune QAM.
I don't know of an SD QAM tuner box.
Ken H is offline
post #13 of 15 Old 05-22-2010, 01:36 PM - Thread Starter
airtas's Avatar
Time Warner.....I was just wondering if you could use the Analog boxes as a tuner since the TV had no Cable tuner
When you say clear QAM signals do you mean just local hd?
airtas is offline
post #14 of 15 Old 05-22-2010, 01:43 PM
Rammitinski's Avatar
Basically, yes. And SD. Also, maybe a few public access channels or others thrown in there.
Like was said, only an HD ATSC(/QAM) tuner can tuner those in, and the cheapest is about 100 bucks.
Not to confuse you any further, but just in case you have any analog signals you still want to watch, too: if your cable company is still sending any analogs on the line, some of those HD tuners have an "RF pass-through" feature, where it will pass the signal through and they can be picked up on your TV's analog tuner (or any other standalone analog tuner in-between, like an old VCR's - then you could just switch inputs to watch them. But none of the newer HD tuners actually have an NTSC tuner in them themselves anymore).
Rammitinski is offline
post #15 of 15 Old 11-26-2010, 06:27 PM
HGN2001's Avatar
Quoted: 13 Post(s)
Liked: 26
My sister-in-law reported that their Sony Bravia TV had lost its digital tuner - that it just stopped working one day and that they really didn't have any live TV capability. They only ever used an antenna for OTA TV as that's all they ever wanted.
Since they were hosting Thanksgiving, I volunteered the use of a set-top converter and brought over an old Magnavox box I'd bought when the things first came out. My brother in-law was quite surprised at how decent the picture was - it wasn't HD, but we were able to keep an eye on the football games and so forth all afternoon.
He had an old converter for a a long-gone tube set, but had lost the remote - AND he was unaware of the red-white-yellow connectors for a Video input.
Harry
HGN2001 is offline
Reply Coupon Eligible Converter Box (CECB)
