how to fix no sound or incorrect sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-07-2010, 12:48 PM - Thread Starter
scandi's Avatar
I have an analog tv and am using a philco converter box; up until now all has worked fine. Now I am getting a pbs "reading for the blind" audio on one of the other pbs channels, and periodically no sound or spanish on the cbs station. I can't figure out what has happened. Any ideas or info would be helpful.
scandi is offline
post #2 of 8 Old 07-07-2010, 12:58 PM
Theo1080's Avatar
Quoted: 69 Post(s)
Liked: 34
Change the audio to English...(Audio 1)..you are listening to Audio 2 or 3
Ted Hand, CPBE. 8VSB, DRB, AMD
I was there on July 23, 1996...First DTV broadcast in the US..WRAL-HD
Amateur Radio - W9SOC
Theo1080 is offline
post #3 of 8 Old 07-07-2010, 01:07 PM - Thread Starter
scandi's Avatar
Thanks for the reply, but all the other channels are in English, and two others intermittently also receive the reading for the blind audio, or nothing at all. I'm stumped. I will look for the language choice and see if it fixes it. thanks.
scandi is offline
post #4 of 8 Old 07-07-2010, 01:17 PM
bdfox18doe's Avatar
Quoted: 203 Post(s)
Liked: 111
Yep.. what Theo said..
Bob
The views expressed here are my own and do not necessarily represent those of ABC, CBS, CW, FOX, MeTv, or AntennaTv; my employer; or its parent company.
Nor my wife for that matter!
bdfox18doe is offline
post #5 of 8 Old 07-07-2010, 01:58 PM
Trip in VA's Avatar
Quoted: 545 Post(s)
Liked: 145
Send a message via AIM to Trip in VA
If your TV is set on secondary audio and you tune to a station that does not transmit secondary audio, it will give you the main audio. What you describe is entirely consistent with you being on secondary audio.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #6 of 8 Old 07-08-2010, 03:43 AM - Thread Starter
scandi's Avatar
okay; I checked in the setup, and there is no language choice on the philco converter box; it can't be that. Next, the evidence that one time it can be in Spanish, and then the commercial comes on and it is in English seems to prove that the choice is not a language one, but something ielse. I thought at first the signal wasn't strong enough, or the rabbit ears aren't picking up a signal, but then they worked for almost a year, and now all the sudden it can't work? mYSTERIOUS.'
So now I am thinking I need a new box. The tv works fine in receiving dvd or vhs tapes. The commercials often come in, but the program doesn't. One time there will be no sound, but then all the sudden one commercial will come with sound, and then without touching anyting, another will be silent. And why would pbs 's original channel have a perfect picture, but play the sound of another pbs channel's sound? It is in English, and it's own channel also has sound, but I can't seem to find the problem? There are no language choices on the box, and I haven't touched the tv, which would seem logical to me, since all the other channels come on in English. It is strange.
scandi is offline
post #7 of 8 Old 07-08-2010, 10:49 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
I'm not sure but I thought the gov't madated that option for CECBs. Check your remote for any buttons labeled audio, CC, CS, subtitle, text, etc. GL!
Floydage is offline
post #8 of 8 Old 07-11-2010, 10:56 PM
keyboard21's Avatar
Yes EVERY BOX should have this choice. Government Mandated
He needs to look better
keyboard21 is offline
Reply Coupon Eligible Converter Box (CECB)
