OTA to CRT TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-09-2011, 12:29 PM - Thread Starter
Mamba's Avatar
Hope this is the right forum area, so....
We have no cable provider, all live TV reception is OTA from rooftop UHF antenna.
Works fine for our bigscreen LCD with ATSC built-in, and for our HTPC server with external USB ATSC tuners.
However, we have an old cable-ready analog 27" CRT TV in another room that I'd like to somehow utilize if affordable/possible, and if so, wireless would be first choice. Thoughts, ideas?
TIA,
M
Mamba is offline
post #2 of 10 Old 01-09-2011, 02:20 PM
Ken H's Avatar
Moved to proper forum.
You'll need a CECB. See the sticky topics at the top for details. Wireless does not come into the picture; no pun intended.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #3 of 10 Old 01-09-2011, 07:11 PM
BCF68's Avatar
I've notice my local wal-mart has started to sell converter boxes again. I can't speak for other wal-marts or the quality of the boxes they sell. I think they're RCA.
BCF68 is offline
post #4 of 10 Old 01-10-2011, 07:09 AM - Thread Starter
Mamba's Avatar
Thanks, read the FAQ, seems like the ticket. The "wireless" query was concerning avoiding having to run cable to the other room from the antenna splitter. Any options there?
Mamba is offline
post #5 of 10 Old 01-10-2011, 09:44 AM
arxaw's Avatar
Depending on your signal strength (check tvfool.com) and building materials, you may be able to just use a separate indoor antenna on that old TV, (plus a digital converter box, of course). I would avoid RCA converter boxes. Their reliability is spotty and so is the reception, unless you have a really good signal. Two good converter boxes are Zenith & Insignia.
arxaw is offline
post #6 of 10 Old 01-10-2011, 12:41 PM
DragonLoaf's Avatar
Just to add to this good advice, the Zenith DTT-901 & Insignia NS-DXA1 CECB have the same excellent LG tuner guts and the only exterior difference of any note is the brand name. I don't know where to buy them retail, but I do see them available on craigslist from time to time. Actually the tuners in my 2 Zenith DTT-901 boxes are better than the ones in my 2 big screen televisions.
I also recommend trying one of these boxes with an indoor antenna to see if it works. If you know someone with a CECB, maybe you could talk them into letting you borrow it for a test run?
DragonLoaf is offline
post #7 of 10 Old 01-10-2011, 12:58 PM
arxaw's Avatar
The two models DragoLoaf posted can usually be found for sale on eBay by searching for the model numbers or Zenith or Insignia Converter Box.
arxaw is offline
post #8 of 10 Old 01-10-2011, 11:03 PM
Rammitinski's Avatar
Or, if you don't want to buy used or pay what will most likely be a pretty exhorbitant price if you're able to find one new, this is basically the same tuner in a different chassis:
http://www.tvconverterboxstore.com/f...On_Screen.html
Rammitinski is offline
post #9 of 10 Old 01-10-2011, 11:23 PM
Check out Amazon under "wireless video senders".
Bunch of them listed there.
post #10 of 10 Old 01-24-2011, 12:58 AM
mirayge's Avatar
Also, if recording is needed, check out the thread on DVD recorders. Many are available online with ATSC tuners. The tuners may not be as good, but I never noticed a difference if at least an attic antenna is used.
mirayge is offline
Reply Coupon Eligible Converter Box (CECB)
