Help With Setup!! - Just got a Digital Analog Converter - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 31 Old 02-17-2011, 09:52 AM
Floydage's Avatar
Quoted: 158 Post(s)
Liked: 69
Originally Posted by JSS12 View Post
Should i try Post #26 or #28??
I just don't want to make another foolish error... these both sound good to me. Is one better?
I would go with the BNC adapter.
You can't get something for nothing - passively converting composite, that lacks all of the signal necessary to generate true s-video, will give you the same quality at best but most likely degrade the signal. Maybe an active device (plugged in wall) could do it but those cost $100 of dollars.
http://en.wikipedia.org/wiki/S-Video
If I was going to throw any significant money at it I would buy a ChannelMaster or one of the few other converter boxes that put out s-video (I use a ChannelMaster for s-video and a Zinwell for my VCR (Zinwell has timer function)).
BTW, do you plan on using a recorder in your setup?
Floydage is offline
Reply Coupon Eligible Converter Box (CECB)
