Good picture static sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-13-2011, 06:28 AM - Thread Starter
ram1's Avatar
I have an access hd dta1080 converter box that I've hooked up to a few different tvs and it works fine. I have a Magnavox tv with a dvd built in that it will not give sound but a good picture. Any suggestions??
ram1 is offline
post #2 of 2 Old 05-13-2011, 07:08 AM
Floydage's Avatar
Quoted: 161 Post(s)
Liked: 70
Use the composite/RCA out of converter box: video to TV and audio to external amplifier/speaker set. If no composite input on the TV use the RF/coax for the TV and 'dial' the TV's audio off.
The TV's DVD audio is hosed unless the TV has an external audio output that works.
The external amplifier/speaker set can be as simple (cheap) as a set of amplified PC speakers or as complex as a surround sound receiver setup. Of course if you have an ordinary stereo system with an auxiliary audio input you can use that setup.
Floydage is offline
Reply Coupon Eligible Converter Box (CECB)
