CM7000 puts channel 27 on channel 10 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-03-2012, 01:50 PM - Thread Starter
TJonline's Avatar
I just switched out a digital stream box and replaced it with a channel master to get improved reception. I'm using both with a replaytv. The digital stream and my digital tv have channel 27 on channel 27. The channel master puts it on channel 10. This is a problem because the replay only knows it as 27.
I tried the rescan and update functions, and it's staying as 10. Can anyone suggest a solution?
TJonline is offline
Reply Coupon Eligible Converter Box (CECB)
