Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-17-2013, 03:40 AM - Thread Starter
otrimm's Avatar
Hello i own a sony bravia kdl-40xbr4 had it for 3 years now. Just recently i started getting 2 white fuzzy lines going across my tv and as time goes by it gets stronger. Eventually the whole tv turns green in color which your still able to see the characters on the tv but very hard to watch. I left it unpluged for 10 min or so and once turn on again it was gone. After 5 minutes of viewing it started doing samething all over again. Tried different hdmi cables, RCA cable and different inputs but all the same. Also tried it with a different receiver thinking it was my comcast box but no luck. Does anyone know what this can be? Can it be the tcon board or possible the lcd panel? Please any help will be great.
otrimm is offline
post #2 of 3 Old 03-17-2013, 11:48 AM
SonyListens's Avatar
Good afternoon otrimm!
I'm very sorry to hear that about your Television. I would recommend visiting this link to our esupport site: http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C390835&sliceId=2&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=240185472&stateId=0 0 240189012. If this doesn't fix the problem then service may be required. Please let us know if you have further questions/concerns. We will try our best to get back to you with a response shortly. Thank you!
-Amanda Maffei
Sony Support USA
SonyListens is offline
post #3 of 3 Old 03-18-2013, 07:56 AM
Floydage's Avatar
Quoted: 158 Post(s)
Liked: 69
Also, you're way off on forum category on AVS, this one is for DTV converter boxes (which sort of implies most of these posters have/had CRT TVs). Try backing up in the forum categories and searching for a more relevant category or even do an AVS keyword search for your TV model.
Floydage is offline
Reply Coupon Eligible Converter Box (CECB)
