2k4k - 3840 x 2160 @ 60Hz with DisplayPort - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-30-2013, 02:03 AM - Thread Starter
FlorianARPCI's Avatar
Hello !
I am new on this forum, I hope that is the good section for my question.
My question :
Is there possible to obtain the resolution 3840 x 2160 @ 60Hz with only one display port connection ?
Is there a standard for this app ?
Precisly, is it possible with this display : http://www.sharp-world.com/products/professional-monitors/products/pn-k321/specifications.html ?
I don't know where and how to search this information.
Thank you for help !
Florian
FlorianARPCI is offline
post #2 of 7 Old 05-30-2013, 09:57 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Probably not as this is within the dusty ol' DTV converter box forum. Try digging around in the pull-down menu where it shows "Forum Nav:"
Floydage is offline
post #3 of 7 Old 05-31-2013, 07:12 AM - Thread Starter
Hi,
I don't find about DTV Converter box.
But I find a information that you may be able to confirm : it's possible with MST function which is a part of DisplayPort version 1.2.
Anybody can confirm that ?
Thank you !
Bye
post #4 of 7 Old 05-31-2013, 07:23 AM
zaphod7501's Avatar
Quoted: 78 Post(s)
Liked: 65
Is your source a computer? Then HTPC might be the best place to ask.
http://www.avsforum.com/f/26/home-theater-computers
If you are looking for monitor specific info, then go here.
http://www.avsforum.com/f/9/display-devices
If you are looking for general computer info, then Audio Video Science might not be the place to be.
http://www.avsforum.com/a/about-us
Sturgeon's Law: "Nothing is always absolutely so."
Sturgeons Revelation: "Ninety percent of everything is crud."
My Thoughts: "A reasoned argument must share some basic common points."
zaphod7501 is online now
post #5 of 7 Old 05-31-2013, 10:14 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Originally Posted by FlorianARPCI View Post
Hi,
You posted in it:
AVS Forum
>HDTV
>>HDTV Technical
>>>Coupon Eligible Converter Box (CECB)
Hence you're in the wrong sub-forum for most folks here to see and help you...
Floydage is offline
post #6 of 7 Old 06-03-2013, 01:16 AM - Thread Starter
Ok, thank you all !
But I found the response.
this high resolution is possible with DP 1.2 standard.
I note your advises for my next post.
Thank you again.
post #7 of 7 Old 12-11-2013, 05:57 AM
thuput's Avatar
Dear Florian
I am having a similar problem. DP1.2 support 3840x2160 @ 60Hz on one channel. To do this the transmitter and receiver have to support 5.7GHz (600Million pixels per second). There are a lot graphics card that support this on the transmitter but no one has a DP sink receiver chip yet. The details of DP receiver chips is on VESA site.
I am designing a monitor for Air Traffic Control where I want a single feed.
All of the current 3840x2160 and 4096x2160 monitor use a minimum of 2 inputs to fool the graphics cards it has two monitors and the controller card puts them back together.
I may have to design a DP interface which has 2 lanes in the same cable both at 3.4GHz using the DP1.2 display daisy chain feature. It will still look like 2 monitors but at least it will be only one cable.
Any consolation is that the current generation of UHD monitors are using 30Hz panels so a 60Hz controller is not of much use. I am designing using the new 60Hz panels being driven by 8 lane V-by-One.
I am looking for a COTS LCD controller board that has DP1.2 input and will drive a 8 lane V-by-One output !!!!
Mike
thuput is offline
Reply Coupon Eligible Converter Box (CECB)
