dtx9950f - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-21-2013, 12:06 PM - Thread Starter
hardwotker's Avatar
I have a dtx9960F and I need to know what universal remote works with it. I called the converter box people and they want me to order it and I need one asap. is there someone out there that can help
hardwotker is offline
post #2 of 2 Old 08-21-2013, 02:05 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
I believe most of the more recent u-remotes can accommodate most of the boxes, especially the more common ones. Just ask the store if you can check the manual for the list or look up the manual online. I have cheap Philips versions and that brand is listed. Old u-remotes sometimes work if the box utilizes a legacy code like that of a cable box.
If there's any 'special functions' on the remote for that box you may not get them on a u-remote though, usually no biggie from my experience.
Floydage is offline
Reply Coupon Eligible Converter Box (CECB)
