RCA DTA800B1 code - AVS Forum
post #1 of 3 Old 04-22-2014, 09:14 AM - Thread Starter
frstbass's Avatar
I have a visually  impaired mother who uses a large remote.  He cable company recently went all digital so we dropped her plan and I bought her an RCA DTA800B1 Digital converter box to get her signal directly off the airwaves.  The small remote that comes with the box is not usable for her so she needs to continue using her old remote.  I can't seem to find the correct code to make her remote work with the RCA converter box.  Does anyone know what code(s) work with this particular box?
frstbass is offline
post #2 of 3 Old 04-22-2014, 04:47 PM
Floydage's Avatar
Liked: 35
Codes are dependent on remotes, not the stuff they work on. You'll need the remote's code info assuming it is even modern enough to have control capability of a converter box. You could also try the remote's code search function although this can be time consuming and tedious. If it doesn't have a converter box mode button I'd try cable then satellite modes.
Floydage is online now
post #3 of 3 Old 04-23-2014, 10:41 AM
peggy1's Avatar
I can control the RCA converter box with my old Panasonic TV remote with satellite code 106.  Code 808 may work with a Sony remote.
peggy1 is offline
Reply Coupon Eligible Converter Box (CECB)
Gear in this thread - DTA800B1 by PriceGrabber.com
