Zenith (LG) DTT900 CECB - Page 88 - AVS Forum | Home Theater Discussions And Reviews
 54Likes
post #2611 of 2617 Old 09-02-2015, 11:08 AM
Bismarck440's Avatar
Quoted: 754 Post(s)
Liked: 143
Originally Posted by Floydage View Post
Hey I was able to combine two antennas with a simple two-way combiner (a splitter in reverse). Loses about half my signal for each antenna but I have plenty of signal to spare. Sure beats flipping a switch but in my case it was the NBC station. .
You really arent suppose to be using a splitter in reverse though? On paper looks like that would work.
If & when I put the attic antenna down to my living room line I'll split in the attic, but before I do this I'm going to run a worst case with a splitter in the bedroom, & just drop a long line to the living room to see what indeed happens.
Really, I haven't had the time to call anyone on a new roof set yet.
Bismarck440 is offline
post #2612 of 2617 Old 09-02-2015, 01:09 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Bi-directional as long as a 'standard' passive type . Now say if had a built-in amp or some kind of filtering (ex: diplexer) then no; although a passive diplexer could be used in reverse but with the same frequency dependency on each port.
Now if for some reason a device had an isolator or circulator on some ports then it would be directional. We would do this for amplifiers to maintain the proper impedance and have a dummy load for protection (ex: microwave oven so a bad condition doesn't reflect the power back into it and fry itself).
Good idea. Don't even need to run a line to the living room, just test both sides in the bedroom. Of course maybe it's just easier that way...
Floydage is offline
post #2613 of 2617 Old 09-03-2015, 10:55 AM
Quoted: 754 Post(s)
Liked: 143
Actually worst case since I'll be using the existing RG59 in the wall (strain reliefed somewhere in the wall), I wanted to try a run of cheap cable laying around... if it works with that, I'll know to expect better, & always leave an option to go back to the roof.
post #2614 of 2617 Old 09-03-2015, 03:00 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Cable doesn't have much loss unless reeeeeal long. If you really want to worst case it, add in an extra two-way splitter to that side.
Floydage is offline
post #2615 of 2617 Old 09-03-2015, 04:36 PM
Jim1348's Avatar
Quoted: 114 Post(s)
Actually, that sort of begs the questions of what your definition of "reeeeeal long" is. My experience has been that I had the best results with RG-6. It has less loss than RG-59. On the other hand, since you have existing feedline, try it and see what happens. With digital, you pretty much have a great picture, or not. Just know that if you don't have a great picture, it is time to look at the antenna system. Think of it as a system and closely examine every part of the system, if you have problems.
ATSC behaves differently than NTSC did. Remember, this ain't your grandfathers TV set that he bought from Montgomery Wards 40 years ago!
Jim1348 is offline
post #2616 of 2617 Old 09-04-2015, 09:33 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Something like 3 dB for 50 feet. Splitter...
Floydage is offline
post #2617 of 2617 Old 09-11-2015, 10:59 AM
Quoted: 754 Post(s)
Liked: 143
From the attic to the living room, & down 2 doors about 35 feet across & 16 feet down (roughly 50 feet) of 59 gave me a great picture on digital, but I do not know what amplification they were using... the new setup will be no linger than 20 feet of RG59... now the antenna will be in the attic though. The builder left absolutely no slack, in the living room wall, it was like a banjo string when I examined it & the crimped end came off on the Blonder Tounge wall plate it was so tight.
Reply Coupon Eligible Converter Box (CECB)
