Total Recall (Blu-ray) Official AVSForum Review - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 245 Old 12-24-2012, 01:29 PM
darthray's Avatar
Quoted: 1181 Post(s)
Liked: 1084
Add me to the list of Multiple audio dropouts, 8 of them in 22 minutes.
At this point, I turn it off.
Did retured it today but only to get an exchange.
I guess I will be back and foword untill they got tired of seeing me or get my money until a new version come out.
Relevant equipment is
Oppo BD83
Onkyo PR-SC886
Ray
darthray is offline
post #92 of 245 Old 12-24-2012, 02:29 PM
BrolicBeast's Avatar
Quoted: 1388 Post(s)
Liked: 1440
What a great a/v ride this film was. I experienced audio delay, but this is due to my Oppo (The firm somehow still hasn't worked out the syncing issues with this cadre of players). Overall, this left movie-night attendees with jaws dropped!
Merry Christmas to all.
BrolicBeast is offline
post #93 of 245 Old 12-24-2012, 03:14 PM
jevans64's Avatar
Quoted: 208 Post(s)
Liked: 162
I had problems with audio the first time I played the disc. Switched the audio stream from Auto to Bitstream and had no problems on the 2nd run-through. Seems everyone is having problems WITH Bitstream instead of LPCM. I'm not sure if I want to sit through it a THIRD time in LPCM mode.
Player -- Oppo BDP-103 w/ latest firmware.
AVR -- Denon AVR-5308ci(a) with 3D/DSX upgrade.
Surround Mode -- Audyssey DSX to 9 speakers.
At least the last firmware update Oppo did for the BDP-103 allowed me to play previously-unplayable Alexander Jero BD-9 audio discs that use AVCHD. LOL
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #94 of 245 Old 12-24-2012, 03:25 PM
MAZMAN808's Avatar
Yep, watched an Australian copy (so seems its all over the world ) of it last night and had about 3 drop outs within 15min on bitstream, switched to PCM and had no issue after that.
Oppo 93 player
MAZMAN808 is offline
post #95 of 245 Old 12-24-2012, 03:27 PM
TheGigaShadow's Avatar
Liked: 24
I used bitstream. Only one dropout occurred about one hour and twenty minutes in. It lasted less than a second. Hardly worth mentioning much less complaining about considering how good the audio was on this disc.
Edit: Should have mentioned player used was a PS3.
TheGigaShadow is offline
post #96 of 245 Old 12-25-2012, 12:46 AM
fmalczewski's Avatar
Quoted: 131 Post(s)
Liked: 50
I have two players, Panasonic BD-35 and Oppo 93, both of which do the lossless decoding to PCM for my system (so no bitstreaming).
Panny is my goto Region A player, it started acting up (audio dropout or two, an apparent increased framerate, along with some video stuttering (from recollection)) around 43 minutes in, while playing the extended cut. I went back and replayed that bad section, and the same approximate behavior repeated itself, so switched players.
Started it on the Oppo from about 40 minutes in, and it was smooth sailing. (Again, PCM is my only option.)
I thought Dolby TrueHD was supposed to be bulletproof. (Just kidding.) Anyway, I suspect some firmware updates will be coming out shortly, but mostly just a guess.
Edit: And, my workhorse Panny seems to be the only player mentioned so far that has issues while decoding audio to PCM. (The receiver is a Denon 5805mk2, which is HDMI 1.1.)
fmalczewski is offline
post #97 of 245 Old 12-25-2012, 12:02 PM
SmokenAshes's Avatar
Liked: 53
Same problem here on PS3 and Yamaha AVR. Switched to PCM and drop outs are gone but the sound is quite different. I have to raise the volume substantially to get it even somewhat close. But it sounds as if the music over powers the sound effects. As soon as there is action on screen the sound effects volume dwindles. Out of all the blurays I own thus is the first.
SmokenAshes is offline
post #98 of 245 Old 12-26-2012, 07:50 AM
Emaych's Avatar
Quoted: 478 Post(s)
Liked: 229
Went through a period of just buying every blu-ray I might possibly want to see. Got expensive, not to mention felt the money wasted in many many cases. Tried reviews to give me an idea if a given release would have what I was looking for -- mostly awesome audio. I generally know the type of film I'm going to like, and read very sparingly about plot, etc. to avoid ruining it for myself. I swear, just about every place you are going to look, you find these glowing appraisals of soundtracks I wasn't hearing when I bought these blu-rays.
The one exception here seems to be you Ralph Potts -- may I express my appreciation for your insights? We are attuned, and hearing the same things.
I had high hopes for this flick, and expected it to be good. Wasn't sure about the AV -- sometimes it can end up being pretty lackluster in spite of every reason to make it exceptional -- sci-fi action expensive remake, the whole nine yards -- still, others of that type have been botched.... This soundtrack ROCKS! One of the best of many years.
Unfortunately of course, I have the dropouts -- probably hundreds. At one point it was dropping every half-second and likely would have continued just that way until I cycled through the audio choices -- FRENCH, SPANISH etc., then back to TRU HD. It stabilized, but kept intermittently doing it throughout the watch. Read about "the fix" to PCM -- seemed like it cured the dropouts, but sound not at all the same. Some of the transparency and expansiveness gone, some of the crisp singing highs stolen away, low end not as round, full, rich, ROUND. So I prefer the TRU HD with dropouts -- but really want the NO dropouts, of course.
As to the movie -- when I read your reviews Ralph, I just go to the audio, then buy or not. After viewing, come back and see what you thought of the flick. Time and time again, we are in synch there as well. I had started reading some not too in-depth comments about this film from AVS posters -- worst ever, vapid soul-less, pointless exercise. I thought it was terrific entertainment. Everything I wanted. Money all over the screen. Wicked beautiful execution from start to finish, and that killer killer track. It's what you want, it's what you expect, given the talent and all the other factors that serve to inform judgment.
Contrast to another recent purchase: FAST FIVE -- available cheap on Black Friday. Did not find the Ralph review, so relied on someone else -- booming fresh track, plenty of rocking LFE, experience every crash as if there, blah blah blah. Waste of money, did not deliver.
So all of that AV acumen AND a not quite EX police officer as well? -- you are a man of many talents, Ralph, I thank you for the reliance I can place on you. In my case at least, you are steering me toward purchases that I don't regret. Studios should give you a commission.
Don't even regret TOTAL RECALL 2012, though contemplated a return of course, since I think it quite obvious that something is going on with this release, but the freshness of that track made it very very hard to part with, so I guess my hand is pat for now. Would like a handy way to contact the studio to lodge my complaint about the encoding though....
Emaych is online now
post #99 of 245 Old 12-26-2012, 11:54 AM - Thread Starter
Blu-ray Reviewer
Moderator
Ralph Potts's Avatar
Quoted: 1134 Post(s)
Liked: 3605
Greetings,
Emaych, thanks so much for your post. It is always rewarding to hear that your work is valued and appreciated. smile.gif
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
My DVD/HD DVD/Blu-ray Collection
Follow me on Twitter @RalphAVSreviews
Ralph Potts is offline
post #100 of 245 Old 12-27-2012, 03:45 PM
Liked: 53
Has anyone tried the directors cut to see if there is any dropouts as well?
post #101 of 245 Old 12-27-2012, 06:33 PM
livingproof73's Avatar
Mine dropped out on both versions when using bitstream, but PCM is fine... Just much lower volume. Using PS3 and Pioneer Elite amp. Hope Sony recalls this with fixed copies. And when the drop out happens the lip sync goes WAY off!
livingproof73 is offline
post #102 of 245 Old 12-27-2012, 06:34 PM
detroit1's Avatar
Quoted: 118 Post(s)
Liked: 36
I have had both Directors Cut and a Redbox Rental of of this, which is about 12 minutes shorter. The Directors Cut from BB had audio problems. The Redbox one had less but still there is some dropout
regarding the Elevator Explosion at 1 hour 20 min, did that sound a little thin? meaning it had less bass than what it should have
did anyone else notice this? overall, the movie has good sound
detroit1 is online now
post #103 of 245 Old 12-28-2012, 10:40 AM
cinema13's Avatar
Quoted: 177 Post(s)
Liked: 139
My rental of the DC (also from BB) played fine...not a single audio problem.
cinema13 is offline
post #104 of 245 Old 12-28-2012, 11:40 AM
RMK!'s Avatar
Quoted: 1698 Post(s)
Liked: 1630
What A PITA. Watched it with some friends last night and the drop outs were frequent and in some cases of fairly long duration. Good thing dialog is secondary in this film ... rolleyes.gif
BTW, I was bitstreaming via HDMI to an Oppo BDP-83 (one of the original beta test units).
Anxiety is contagious, please keep yours to yourself.
RMK! is online now
post #105 of 245 Old 12-28-2012, 01:14 PM
Retired flyer's Avatar
Multiple drop outs on 2 separate players. Netflix rental.
Retired flyer is offline
post #106 of 245 Old 12-28-2012, 04:31 PM
wingnut4772's Avatar
Liked: 29
I wonder if they will have a total recall of the blu ray. He he he.
Kaboom.
wingnut4772 is offline
post #107 of 245 Old 12-28-2012, 08:03 PM
Liked: 53
post #108 of 245 Old 12-29-2012, 07:18 PM
DarkVenture's Avatar
No audio drops whatsoever out on a PS3 slim with audio connected via optical and direct bitstream enabled. However, that is with the Canadian version of the Bluray.
DarkVenture is offline
post #109 of 245 Old 12-29-2012, 09:30 PM
Liked: 53
I found a fix (I think) as soon as you hear the audio drop out hit the on screen menu button, select scene selection then select the scene closest to where the audio dropped out. Then fast forward to where you were at. For me this worked great and it only dropped out twice but the sound sync was fixed with this method. The last time I watched it I had multiple dropouts and was unwatchable for me.
post #110 of 245 Old 12-30-2012, 02:35 AM
[KYA]Mega's Avatar
If you're using optical then you're not using Dolby TrueHD. You are "falling back" to Dolby Digital. So I guess the problem is only with the Dolby TrueHD track. I was excited about getting this movie, but I think I'll wait for a fixed version to be released.
[KYA]Mega is offline
post #111 of 245 Old 12-30-2012, 10:41 AM
wallijonn's Avatar
While it doesn’t quite live up to the 1990 film ...
I disagree. The different ending alone makes it superior to the '90 version. (I found Schartznegger's "Maybe it's all a dream" ending to be very lame.)
I saw no need for the 3 breasted woman scene - put in solely as homage to the Mars colony scenario. Since this time they were not on Mars there was no need for the 3 breasted woman, imo.
The airport face changing scene was superior - no mechanical against-the-wall hide-away.
And for those of us who love Kate Beckingsale it was a delight to be teased with Kate playing the dutiful powerless wife in the first half of the film (which made us feel frustrated that her abilities and expertise weren't being utilized) then turned into the relentless hunter lioness in the second half of the film.
Yes, there were some incongruities, specifically his previous identity. But there were some nice revelations, like the palm bullet holes which cemented the reality of the film.
But wistfully looking back at Schartznegger's campy style as nostalgia is like bemoaning the same antics in the early James Bond movies. Yes, it made for a "cutier" film, making us feel good all over but many of us like more realism. Would we have liked the "cutesy" feel of the Indiana Jones or Star Wars films? Sure. But I doubt that Colin Farrell would have liked to reprise his "Dare Devil" role in a new setting.
wallijonn is offline
post #112 of 245 Old 12-30-2012, 10:53 AM - Thread Starter
Blu-ray Reviewer
Moderator
Liked: 3605
Greetings,
Thanks for offering your perspective. Being that opinions on film are purely subjective you can appreciate my take as simply being my perspective. wink.gif
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
post #113 of 245 Old 12-30-2012, 08:21 PM
Kamikaze13's Avatar
Quoted: 107 Post(s)
Liked: 51
Surprised there is no mention of the amazingly annoying blue, yellow, and purple solar flares across the screen every 10 minutes for the first half of the movie. Very distracting.
VIDEO: JVC DLA-RS57U Projector / 122″ EluneVision Reference Studio 4K Cinemascope Screen - Oppo BDP-103 Blu-Ray Player - PlayStation 3 AVR: Anthem MRX-1120 SPEAKERS: Paradigm Monitor 11 Mains - Paradigm Monitor CC-390 Center - Paradigm Monitor ADP-390 Surrounds x 4 - Polk MC60 Atmos Ceiling x 4 SUBWOOFERS: SVS PB2000 / Velodyne DPS-12
Kamikaze13 is offline
post #114 of 245 Old 12-31-2012, 05:31 AM
Angler55's Avatar
Yeah, I noticed but I'm new to blu ray and thought maybe there's a perfectly good explanation as to why they would put that in this movie. I kept trying to figure out how it could benefit this movie but, you're right, it' is annoying and actually looks like it wasn't intended to be there.
Angler55 is offline
post #115 of 245 Old 12-31-2012, 10:31 AM
Nachosgrande's Avatar
Quoted: 37 Post(s)
Liked: 25
I was just about to post this as well. I see no reason for this, unless it was some clue as to Quaid's memory being wiped and new memories added prior to him being aware of this?
Nachosgrande is offline
post #116 of 245 Old 12-31-2012, 10:58 AM
Liked: 53
Didn't they use the glare technique in the latest Star Trek? I think their using this technique more for Sci-fi films.
post #117 of 245 Old 12-31-2012, 11:47 AM
Angler55's Avatar
If it's a technique I wonder what it accomplishes?
Angler55 is offline
post #118 of 245 Old 12-31-2012, 02:26 PM
Liked: 53
Its just a technique or effect, like a painter painting a masterpiece with only his hands and oil paint. Like a signature of that artist.
post #119 of 245 Old 12-31-2012, 02:26 PM
Kamikaze13's Avatar
Quoted: 107 Post(s)
Liked: 51
For me it was so distracting that at first I wondered if I had a faulty disc but eventually decided it was just an effect they were going for.
If it was more subtle and only done once or twice it may have been ok but for me it really detracted from the scenes.
post #120 of 245 Old 01-01-2013, 09:42 AM
yadfgp's Avatar
Quoted: 67 Post(s)
Liked: 68
For me those lighting effects did add to the movie oddly enough. I guess because the whole thing had a really nice slick look to it and the CGI was incredibly well done I thought. In some scenes, I couldn't help but marvel how pretty it all looked. biggrin.gif
I liked the movie alot overall. Towards the end it did seem to drag a bit and I think maybe they could have cut out 10-15 minutes of it. I liked some of the scenes where they had certain homages paid back to the original flick. Like the scene where Quaid had to sneak through security with that disguise on like the original, with the 1 lady looking around like "hey, what's everyone watching me for?" tongue.gif
Great action also. SQ and PQ were top notch. I have no idea why this got so many bad reviews.
yadfgp is offline
Reply Official AVS Forum® Blu-ray Disc Reviews
Total Recall Mind Bending Edition Blu Ray
