Need motivation? Get "LOGANED" - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 48Likes
post #2521 of 3746 Old 12-30-2010, 05:37 PM
HeyNow^'s Avatar
You can always tell when Bryan is about to drop a good one on his victims, he becomes calm and straight faced and B A M....
Mike has the earring in the left ear right?
HeyNow^ is offline
post #2522 of 3746 Old 12-31-2010, 10:38 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Holmes commonly has his kids working on the show. Son often says stupid stuff - lacks experience.
Holmes is one of the few shows I watch, so much crap that passes for entertainment.
I've learned a bunch from watching that show. I wish they'd focus more on the LV work.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #2523 of 3746 Old 01-03-2011, 06:47 AM - Thread Starter
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
Right, in the left ear. Is that the "right" ear?
DANG, now I'm confused. But not in "THAT" way. Not that there's anything wrong with that.
Now Holmes has his son AND daughter on the show. Pretty funny watching the son chase the daughter around with a spider. LOGANESS says, "Oh, they're siblings, alright!"
Put a coat of the gray paint over the mud&tape for the inset shelf behind the bar, around the one window and the proscenium. Now the ENTIRE room is gray. Not musch of a pictures, but if you all insist, I guess I can take one tonight.
Also started to make the frames to surround the outlets for attaching fabric. I thought 5/4 stock was actually 1". I was going to make two and attach them on top of each other to get the 2" depth that goes around the stage but the 5/4 stock I bought (5/4 finger jointed & primed) is actually 5/4. Go figure. Would have been easier to just rip a 2X4 down to 2".
SO, can I use this 5/4 stock to make the rest of the frames for the 1" linacoustic, which is really 15/16s or should I rip down to match exactly?
What say you?
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #2524 of 3746 Old 01-03-2011, 08:48 AM
Chiahead's Avatar
Growing up we used to say, left is right, right is wrong...
I am going to use 1/2" ply 15/32, and use 2 layers, so I will be at 15/16 which looked find on the rear screen wall.
Michael
PSN: Chiahead
Chiahead's Man Cave - Indexed
Loganed on 8/29/2008
Chiahead is offline
post #2525 of 3746 Old 01-03-2011, 11:03 AM
hanesian's Avatar
Quoted: 36 Post(s)
Liked: 83
Judas H. Priest ... knock off all dat goily chatter about earings already, wud yas ladies!? My stomach is still recovering from New Years eve!
Sheesh-us!
The Un-Theater Un-Build
hanesian is offline
post #2526 of 3746 Old 01-05-2011, 07:25 AM - Thread Starter
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
Shamless bump to see if anyone has additional advice from question buried in post above...
Anyone else?
Tom Logan
post #2527 of 3746 Old 01-05-2011, 07:33 AM
fotto's Avatar
Quoted: 21 Post(s)
Tom, if I'm understanding your question correctly, the 5/4" stock you have is 1.25" thick, which you are planning on using for framing around linacoustic, which is 15/16" thick.
If that's the case, then your linacoustic would be under the thickness of the stock by about 0.25". I personally wouldn't have an issue with that as you wouldn't need to worry about the linacoustic possibly "bulging out" your fabric.
Although there may be some downside to that .25" gap, I can't think of one.
fotto is offline
post #2528 of 3746 Old 01-05-2011, 07:36 AM
AndreasMergner's Avatar
4/4 stock is 1".....but a 1x is not.
Sure, you can use wood that is 1.25" deep to cover something that is 15/16" thick. Am I missing something?
Current HT: HTPC-->Epson 5010 projector-->135" screen, BFM TLAHs x7 & THT
Build log: DIY rotary sub for contemporary HT in 100 year old house?
Andreas' Slow Rotary Sub build
AndreasMergner is offline
post #2529 of 3746 Old 01-05-2011, 07:52 AM - Thread Starter
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
THERE'S the crux of the question. Is there a downside to that 1/4" gap?
Tom Logan
post #2530 of 3746 Old 01-05-2011, 07:55 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
The frames I made for my linacoustic panels are made from ripped 1x material. I would normally get 1X10 stock and rip it down to as many pieces that I can get out of it. The 1x side is nicely flush with linacoustic and the fabric has no issues holding in place.
oman321 is offline
post #2531 of 3746 Old 01-05-2011, 08:08 AM
I think the downside is that you will lose 1/4" from the inside of your room.
post #2532 of 3746 Old 01-05-2011, 08:21 AM
fotto's Avatar
Quoted: 21 Post(s)
Ok, here's a possible downside that I just thought of. With tightly stretched fabric covering a gap of 1.25" (with 15/16" of that being linacoustic) to the hard wall, if someone pushes their finger or other object into the fabric to the wall surface, MAYBE the fabric will stretch enough to hold the indent and subsequently look bad until when and if it stretches back out. If the gap were say an inch instead, the linacoustic would re-expand pushing the fabric back out??????
Hard to say for sure unless someone has same set-up and tested.
fotto is offline
post #2533 of 3746 Old 01-05-2011, 08:36 AM - Thread Starter
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
Yeah, actually 1/2"...TWO sides to the room! At this point I just want to get done. What's a 1/2" here or there?
THERE are the kinds of things I'm looking for. THANKS! Anything else anyone can think of?
Tom Logan
post #2534 of 3746 Old 01-05-2011, 08:54 AM
Small animals and ghosts may be able to nest in that 1/4" space.
post #2535 of 3746 Old 01-05-2011, 09:12 AM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
That 1/4" may be enough to set up a resonance with the subwoofer and cause them to vibrate like a drum head at certain frequencies. Probably more of a visual distraction than an audio one.
jayn_j is offline
post #2536 of 3746 Old 01-05-2011, 09:22 AM - Thread Starter
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
hmmmm....what if the linacoustic was pushed forward to he fabric side and the 1/4" was in the back (the wall side)? Seems like that would fix it.
Am I in an analysis paralysis, here?
Tom Logan
post #2537 of 3746 Old 01-05-2011, 09:28 AM
Chiahead's Avatar
place a 1/4" board behind the lincoustic.
Michael
PSN: Chiahead
Chiahead is offline
post #2538 of 3746 Old 01-05-2011, 09:35 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
You could probably add 1/4 inch batting material to either the front or backside. Shouldn't have any acoustic affect either way.
Problem with pushing the linacoustic to the front of the frame with nothing else is that there is nothing to keep there. It become a problem if someone presses into any of it.
http://www.joann.com/joann/search/se...uestid=6824728
oman321 is offline
post #2539 of 3746 Old 01-05-2011, 09:37 AM
fotto's Avatar
Quoted: 21 Post(s)
I believe you would see some incremental increase in absorption due to the air gap behind the linacoustic. To what degree, and whether you will benefit from it is beyond me.
fotto is offline
post #2540 of 3746 Old 01-05-2011, 09:42 AM
It won't matter at all. If you have no gap, you'll see the lincoustic pushing slightly into the fabric, so you need some gap. .25" seems like a perfect gap. The fabric won't move much with bass since it should go right through it (it IS AT, right?). If you are vibrating all of your panels, your head is probably vibrating too and your vision will be blurry. You won't be able to watch the panels and the movie at the same time. If you can make dents in your fabric, you'll dent your lincoustic too, so it won't bounce back anyway.
Maybe if you think about it for a few more weeks you will come to a greater understanding of the gap and its ability to trap spirits.
post #2541 of 3746 Old 01-05-2011, 11:03 AM - Thread Starter
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
Might be a nice side benefit....
We HAVE had two occasions of the stereo turning on by itself and one of a full jug of laundry detergent flying off the middle of a shelf while nothing else around it was disturbed and no one was in the room....we just heard the crash. And Monday morning the dog was sniffing, snuffling and barking at SOMETHING around the front door and entryway. And every once in awhile in the morning I notice my computer screen is on when it should be asleep, like when you bump the mouse or hit a key and it wakes up.
Tom Logan
post #2542 of 3746 Old 01-05-2011, 11:13 AM
Now you know how your basement REALLY was flooded.
post #2543 of 3746 Old 01-05-2011, 11:17 AM
Chiahead's Avatar
Did you build your theater over an old graveyard?
Michael
PSN: Chiahead
Chiahead is offline
post #2544 of 3746 Old 01-05-2011, 11:51 AM
hanesian's Avatar
Quoted: 36 Post(s)
Liked: 83
Happy new year to you and your spirits, Tom!
hanesian is offline
post #2545 of 3746 Old 01-05-2011, 12:19 PM - Thread Starter
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
Not knowingly, but there WAS a lot of Civil War activity around the area and the 150th anniversary is coming up fast. Not that I was THERE or anything. Maybe Big was, though.
Hanes--- my spirits and I thank you.
Tom Logan
post #2546 of 3746 Old 01-05-2011, 12:28 PM
BritInVA's Avatar
Smart move - biting the hand that helps you
BritInVA is offline
post #2547 of 3746 Old 01-05-2011, 01:08 PM - Thread Starter
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
Well, I threw the softball up there figuring there would be 20 jokes about my build starting back then.....so it was a pre-emptive strike.
Tom Logan
post #2548 of 3746 Old 01-05-2011, 05:59 PM
HeyNow^'s Avatar
I lost my bat.....
HeyNow^ is offline
post #2549 of 3746 Old 01-06-2011, 07:38 AM - Thread Starter
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
Sounds like personal problem....they have a pill for that, you know.
Tom Logan
post #2550 of 3746 Old 01-06-2011, 07:55 AM
HeyNow^'s Avatar
If you cut them in half they last three times longer.
HeyNow^ is offline
Blu Ray Movies , Blu Ray Players
