The "NOT HERS" HT/Basement Build - The Suffering Begins - Page 19 - AVS Forum | Home Theater Discussions And Reviews
Old 03-04-2009, 08:04 AM
hanesian's Avatar
Quoted: 36 Post(s)
Liked: 83
I hear ya, brother. Take it from me: you do NOT want her to start shopping at Sam's Club either. Talk about buying in bulk ...
The Un-Theater Un-Build
hanesian is offline
Old 03-05-2009, 09:14 PM - Thread Starter
Staffy's Avatar
All Nighter!! (Not the good kind)
Today after working late at the office, I still had to prep for the painters that were going to be there in the morning.
After sweeping and cleaning up, I had to get started on mounting all of the can lights so I would not jack up the nicely painted ceilings when trying to do it later.
The tools I used were a 90 degree drill, 2 bits, an adjustable square, drafting compass, and a nut driver.
After thinking for a while about the best way to drill new holes in the cans to lower them down, I started with the adjustable square and drew a disecting line up 3" through the existing adjustable hole slot.
I then used a drafting compass to draw an intersecting line about 3" up. I had determined this by experimenting with another light can. (Crappy pic)
I then drilled the holes and screwed them in. This worked sweet and I was on my way to finishing in an hour or so when I hit a snag... I dropped my drill bit. OMG I was pissed, I looked for it for at least 30 minutes. I then swept the area again looking for the bit. After another 10 minutes of swearing and checking my socks, pants, under the riser lip... I spotted it. Damn thing fell in the drill case in the tiny slot that holds the manual. I mean seriously, what are the odds?
I finally finished 12 of them, and was off to bed around 4 AM. &$#&&
Before:
After:
I am such a NOOB at A/V..
The "Not Hers" Build
Staffy is offline
Old 03-05-2009, 09:20 PM
smakovits's Avatar
Quoted: 30 Post(s)
I hate to say it, but I am confused as to what you did...you lowered the lights inside of the can? What did this gain you?
smakovits is offline
Old 03-05-2009, 09:29 PM - Thread Starter
Staffy's Avatar
8 AM -- Painters arrive!
I was working from home today as I had a ton of work to catchup on, so I let the painters do their magic. At the end of the day, they got everything completed and I was extremely pleased!
Office area:
Rear of theater:
Front of theater:
That big mofo in the picture is ME, Smakovits... you better be looking out over your shoulder at work....
Just kidding, that is my painter pal, Steve. He trains for mixed martial arts, and is almost too wide to paint my hallways..
So I am stuck doing piddly lil junk until carpet gets installed in a week. So I will take pics and probably not post unless someone pisses me off... at home or here on the forum
Oh!
TIP FOR PREPAIRING TO PAINT TRIM - After you attach/nail all of your trim and get ready for your final layer of paint. Instead of using wood putty, use recently dried chunks of drywall mud.. let it dry in the mudpan and smack it on the ground to pop it out. Then break off a chunk and rub it in the nail holes and it fills it right up and you are able to paint right over it minutes later after you wipe off the extra and verify it is flush!!
Saved me hours of work..
Staffy is offline
Old 03-05-2009, 09:32 PM - Thread Starter
Staffy's Avatar
Well without it, the can light is 2 inches above the drywall and looks funny. I am not sure how evereyone else does it, but I attached the lights to the ceiling joists, but then later decided to do hat channel, so this way I did not have try and mount them lower. Since they free float other than 3 scres holding the center to the ring, I just slid them down and remounted them and will silicone between the drywall and the can.
Make sense?
Staffy is offline
Old 03-05-2009, 09:47 PM
RPh Drew's Avatar
You rang???
2010 - The year of the Shed
RPh Drew is offline
Old 03-05-2009, 09:49 PM - Thread Starter
Staffy's Avatar
Hahah what's up pimp. Too tired to whoop on your butt tonight, go change two crappy diapers and call me in the morning.
Staffy is offline
Old 03-06-2009, 06:25 AM
RPh Drew's Avatar
Hahah what's up pimp. Too tired to whoop on your butt tonight.
I don't doubt it.
With your little Man Crush there you have to be exhausted.
RPh Drew is offline
Old 03-06-2009, 09:03 PM - Thread Starter
Staffy's Avatar
Keep it up ballgag... I even posted something nice on your thread, and you wanna start in on me again?
When your kid is 2, I am going to send you a carload of the noisiest, most annoying toys that China makes... you will only have yourself to blame.
Staffy is offline
Old 03-06-2009, 09:15 PM
Iusteve's Avatar
God I am pleased that the great humor is back to this thread......you guys crack me up. But honetsly I would rethink the harassment as Staffy's painter friend is a Big Ol' Son of a B^#@&!!!!
XBOX Live: Zz NiNj4 D4D zZ
Iusteve is offline
Old 03-06-2009, 09:38 PM - Thread Starter
Staffy's Avatar
Captain Halfass forgot the garbage again...
On this eve before garbage pickup, after reminding my son 3 times to take ALL of the garbage out of the house... At 1 AM, I notice the upstairs garbage cans were full still.
SOB... you would think he would learn...
I am kinda bored of having him beating garbage cans like a drum walking down the street, I figured there must be some sentimental attachment to the garbage that he just cannot part with them..
I figured I might as well cut the kid a break and reunite him with the objects of refuse... So I tied up all the garbage bags and tucked them in with him...
Problem solved... for this week
Staffy is offline
Old 03-06-2009, 09:42 PM - Thread Starter
Staffy's Avatar
Sconces installed!!
Installed a few sconces I got off craigslist for 50$ for the lot.
Staffy is offline
Old 03-06-2009, 10:27 PM
smakovits's Avatar
Quoted: 30 Post(s)
Make sense?
perfect sense, I forgot you did the hat channel, so now I knwo why you had to lower them...
Old 03-07-2009, 07:17 AM
RTROSE's Avatar
Quoted: 192 Post(s)
Liked: 167
3/5/2009
Please tell me there are pictures....and you will post them for our enjoyment.
BTW I have threatened my 13 yr old with the trashcan trick (forgot the garbage once) and has not forgotten again. I figured if the punishment is good enough for Staffy's kid it is good enough for mine!
RTROSE
RTROSE is offline
Old 03-07-2009, 08:07 AM
rattruck51's Avatar
My wife called the other day laughing about using a modified THE FIX on our two middle girls, 8 and 9, who wont stop fighting...
In the background I can hear them screaming "I love my sister, we work together, picking up poop" My wife had them walking up and down the street picking up dog poop and screaming while my two other kids supevised.
So... It works for girls too, and you can use it as a threat. "Do you remember the poop?"
Thanks for the advise, love the garbage inthe bed! This coming Thursday should be interesting.
rattruck51 is offline
Old 03-07-2009, 03:06 PM
czav's Avatar
Hey Staffy,
Thanks for the post you left me the other day about illuminated shelves. I have been looking at your pics of the cabinet you built with the single LED lights in the middle. Man, that is EXACTLY what I'm after. When you get some time, give me all the details about how you did it. What thickness of glass did you use, how is the LED light wired and, did you actually use the hot glue to stick the bulb to the glass?
Everything looks really good in your room, so keep the pics coming. I'm using you and your posts as a reference now because I'm at the beginning stages of building mine. First thing on my list is this equipment rack with the lighted shelves. By the way, I was thinking of experimenting with cold cathode tubes...did you try those before the LEDs?
One last thought here. It looks like your cabinet is closed. If so, did you consider that you may need some venting in there to remove some of the heat generated from the gear.
Thanks man, keep up the good posts/pics and I hope to hear from you soon about the cabinet details.
Czav
czav is offline
Old 03-08-2009, 03:44 AM
joekelli's Avatar
2/17/2009
My son thinks I am an idiot...
In my prework running around and picking up kids, etc. I stopped to grab a quick cup of coffee. My son started drooling on himself and his eyes lit up..
"What is up?" I asked.
"Buffalo Wild Wings...mmmm" He kinda of hinted at in a food addicted trance.
"Today is tuesday you know..." He loves to point out the obvious.
"I know dude, today is tuesday. Tuesday is 50% off wing day. I am not dumb, I know exactly what you are thinking about!" I say, trying to show him I know the 411.
"NO! NO! NO!, you are almost right dad.. That is on thursday. Today is tuesday, so however many wings you buy, they GIVE YOU THE SAME AMOUNT FOR FREE!!!" He halfway yelled with some sort of jacked up tone of expertise..
At this point I started to look at him like he was retarded....but to my astonishment, the lil wanker was giving me the SAME LOOK!
I fought back a grin, and asked him to clarify.
Again he repeats the same damn sentence, but this time, he used HAND GESTURES. Then to further shock me he said, "DAD, seriously, I would expect this from Mom, but you are supposed to be a genius, how hard is it to understand?"
OMG!!! %*^% it took every ounce of composure to not laugh so much I wet myself. I just played along with it and said, "I apologize, I misunderstood".
I then ran inside and had a laugh with the Starbuck girls as I told them the story. One of the ladies said "I am sure things will change when he starts High School.." trying to make excuses for him.
"Start High School? Hell, he is a SENIOR!!" Hahah lil mis positive was left speechless.. I grabbed my coffee and said "I win" as I walked out the door
Tonight, I took a short break to run over the conversation again in front of the wife, his stance had not changed and I told the wife not to argue with him. I still cry/laugh about it.
I laughed my a$$ off after reading that!!! I swear we share the same son!
Here is a good one for you. A couple weeks ago my son asked if I could pick up his girlfriend and bring her to his wrestling match. I told him to leave me directions to her house and I would do it. Well I come home and on the kitchen counter was 2 pages worth of directions to her house. I only had to drive on three streets to get there. Our street, the main street and her street! He explained in detail the 4 stoplights I would go past(he spelled it "pass" 4 different times). He listed every street that didnt have lights that I would go past (spelled pass again) plus the golf course and the school! I wish I would have saved it because I would type it all out for you. So it ends up she only lives a mile away!!!!! I could tell someone how to get to her house from our house in 1 sentence. His directions had me scratching my head. Its really hard to believe he is going off to college in the fall!
Just think, they will be taking care of us when were old!
And by the way I like how the theater is coming along!
joekelli is offline
Old 03-10-2009, 07:30 PM
joekelli's Avatar
Here is another son story that just happened.
Monday afternoon my son is gathering up the trash and taking it out to the curb. You would think this was pretty good, right? Well Today(Tuesday) he comes home from school and ask me why they didnt pick up the trash. Well, I had to tell him that they pick up trash on Wednesday morning the same as they have done the last 12 years! I guess he never noticed that we were the only house that had our trash out. God help us!!!
joekelli is offline
Old 03-10-2009, 09:51 PM - Thread Starter
Staffy's Avatar
Tonight I unpacked all of the prushed metal accessories I purchased over the last month and started installing the door hardware and a bumper stop.
Next I put all of the pocket door hardware on and put on/adjusted the guides.
My neighbor Mark then came over and helped me mount the front speakers so the days of slaving away without tunes blaring is over!
Staffy is offline
Old 03-10-2009, 10:01 PM - Thread Starter
Staffy's Avatar
I rented a floor scrubber from Lowes and scrubbed all of the concrete floors a few times over the last 24 hours. My wife even pitched in and vacuumed the office area before I scrubbed it. She kinda got a lil pissed when I yelled over the scrubber: "That is a vacuum, it sucks up dust and dirt, would you like me to show you how to turn it on?"
As soon as I got "the look" from her, I turned around and scrubbed the theater to stay out of reach
Then I installed the access panel in the ceiling of the office, I did not want to drill any holes in it, so I used silicone around the edge, then clamped it into place. I figured this would hold it fine as the top section of my riser had silicone on it, and I could not seperate it when I wanted to change it per Ted White's advice and ended up having to use a saw blade and cut around the whole thing... so it should have no issue holding a small hatch in place.
Staffy is offline
Old 03-10-2009, 10:04 PM - Thread Starter
Staffy's Avatar
Tonight I caulk sealed around the 13 recessed can lights in the basement.
Next I installed the 2 quiet air grills for the vents.
Still waiting for the carpet folks to call and tell me the carpet is in, until then, just nonstop tedious boring crap!
Staffy is offline
Old 03-11-2009, 12:13 PM
ICBM99's Avatar
Staffy,
Looking good, I love this thread. I was following it around Christmas, then lost it, I found it again, you crack me up. It will be nice to see the finished (or as finished as most HT's are) product.
Keep it up.
Later
ICBM99 is offline
Old 03-11-2009, 07:21 PM
RPh Drew's Avatar
That there is one fine looking door.
RPh Drew is offline
Old 03-11-2009, 07:28 PM - Thread Starter
Staffy's Avatar
Response I posted on your thread HERE
I SWEAR I WILL PISS IN YOUR CAPTAIN AND COKE... MY DOORS ROCK HARD LIKE YOUR SISTER'S DATE'S VAN ON PROM NIGHT.
BEEEEOTCH!
(Your speakers suck)
Staffy is offline
Old 03-11-2009, 07:49 PM
RPh Drew's Avatar
Mine??? Yours look like they came out of the van in the pic you just posted... What are you using for surrounds... Bose cubes???
And what is with this double posting? Now I have to insult you two different threads Xerox style??? Now we know where your kid gets his wits from. That whole fruit and tree thing is making a little more sense.
RPh Drew is offline
Old 03-11-2009, 07:54 PM - Thread Starter
Staffy's Avatar
That's it, I am sending my kid over to kick your ass..
Staffy is offline
Old 03-11-2009, 07:55 PM
RPh Drew's Avatar
lol
RPh Drew is offline
Old 03-11-2009, 07:58 PM - Thread Starter
Staffy's Avatar
You know, all this fighting kinda sucks without other folks refereeing and keeping score.
On a positive note, your riser looks sweet, I will give you that
Staffy is offline
Old 03-11-2009, 08:08 PM
RPh Drew's Avatar
Don't sweat it... Not much fun for a score keeper in a blow out.
Ya your... ummm. ummm. No I mean your... ummm... ummm... escape hatch thingy in the ceiling there looks... um.... cool.. too.
RPh Drew is offline
Old 03-11-2009, 08:15 PM - Thread Starter
Staffy's Avatar
You bitch. Drink some more so you can get your west side tatoo finished..
Staffy is offline
