Acoustic treatment w/o panels? - AVS Forum
post #1 of 4 Old 05-20-2008, 06:37 AM - Thread Starter
DedicatedHT's Avatar
Most of what I'm reading uses panels/bass traps. But some of the demo rooms here locally basically wrap all the walls in a solid piece of fabric with some sort of 1/4" or so absorbtion padding underneath. Sounds easier but is it cost effective? What materials do they use? Are those rooms too dead?
DedicatedHT is offline
post #2 of 4 Old 05-20-2008, 06:44 AM
Kal Rubinson's Avatar
Quoted: 38 Post(s)
Liked: 118
1/4" will not do anything except at the very highest frequencies. To get the lower frequencies, more bulk is necessary. There are no shortcuts.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #3 of 4 Old 05-20-2008, 06:53 AM - Thread Starter
Thanks. 1/4" is only a guess, the rooms are padded all around and the question is more, this seems easier as you can't miscalculate where all the reflection points are, because everything is covered. Even if you went to 1" is this advised? Could you then add corner traps for lows? and what material would you use?
post #4 of 4 Old 05-20-2008, 08:26 AM
AVS Club Gold
Dennis Erskine's Avatar
Liked: 45
Most demo rooms I've seen are pretty poorly done. I'd be very surprised to see 1/4" of "stuff". More likely it's 1" ... and that is only a partial solution to the acoustics of a room. The fabric is to hide absorbers, diffusors and other items which do not lend themselves well to good interior decor.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
www.CinemaForte.net
Dennis Erskine is offline
User Tag List
