The Pocoloco Theater - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 112 Old 11-14-2012, 01:00 PM
amb1s1's Avatar
I see that you remove the black cover to access the back of the screen. How do you do that? Is there a clip?
amb1s1 is offline
post #92 of 112 Old 11-14-2012, 01:41 PM - Thread Starter
pocoloco's Avatar
Theres a fabric pull attached to the side of one of the frames. I use that to remove the first frame. All other frames come out easily after that.
pocoloco is offline
post #93 of 112 Old 11-14-2012, 02:03 PM
amb1s1's Avatar
If you have time take a pic of it, so I can see it. This is perfect for me, because the area where I want to put the screen there is a Pipe that I might need to access in the future. Thanks
amb1s1 is offline
post #94 of 112 Old 11-15-2012, 08:05 AM - Thread Starter
pocoloco's Avatar
Nothing fancy. Just a strip of fabric looped and stapled to the side of the frame.
8188642346_a0e9532bdf_b.jpg[/url]
pocoloco is offline
post #95 of 112 Old 11-15-2012, 08:20 AM
CalgaryJames's Avatar
Great job. Just wanted to ask where did you get your ceiling mount? I've been looking for a ceiling rail mount just like yours. Thansk.
CalgaryJames is offline
post #96 of 112 Old 11-15-2012, 09:24 AM - Thread Starter
pocoloco's Avatar
I assume you're asking about rail slide for the anamorphic lens?
http://www.avsforum.com/t/1035479/diy-lens-slide-better-than-drawer-slide-rails
The project mount is just a Chief RPA series mount you can find anywhere.
pocoloco is offline
post #97 of 112 Old 11-15-2012, 01:39 PM
amb1s1's Avatar
So basically each panel is force in? I want to know how it stay in place.
amb1s1 is offline
post #98 of 112 Old 11-15-2012, 01:44 PM - Thread Starter
pocoloco's Avatar
It stays in place by tension fit and velcro. You may not even need the velcro if you build them to fit snuggly.
pocoloco is offline
post #99 of 112 Old 11-15-2012, 02:46 PM
amb1s1's Avatar
Sorry if I keep asking you, but I'm planning to do exactly the same. How can the velcro stick with the wood? I'm don't 100% how you did it. Thanks
amb1s1 is offline
post #100 of 112 Old 11-15-2012, 02:55 PM - Thread Starter
pocoloco's Avatar
Staple the velcro onto the wood frame.
pocoloco is offline
post #101 of 112 Old 11-15-2012, 05:45 PM - Thread Starter
pocoloco's Avatar
pocoloco is offline
post #102 of 112 Old 01-23-2014, 02:44 PM
OpenMindAudio's Avatar
Quoted: 27 Post(s)
Liked: 37
Pocoloco, love your thread - a lot of the photos aren't showing up as of page 2 (just seeing the dreaded blank photo X). Any way to fix that so we can see the construction images and more details on the stage and screen construction?
"These go to eleven."
Equipment: Goldenear Triton Ones, SuperCenter XXL, Aon 2 surrounds, Invisa 650 ceiling speakers, Oppo BD 103d, Marantz 7702 mk2, Outlaw 2200 M-block (2) & 7125 7-channel, Roku 4, Sonos, and way too many old speakers, including an original pair of Ascend Acoustics CBM-170s, one of the flattest frequency bookshelf speakers SoundStage ever measured.
OpenMindAudio is offline
post #103 of 112 Old 01-23-2014, 02:54 PM - Thread Starter
pocoloco's Avatar
i've been meaning to fix this. Maybe tonight or tomorrow.
pocoloco is offline
post #104 of 112 Old 03-05-2014, 01:36 PM - Thread Starter
pocoloco's Avatar
Broken photos fixed. Sorry it took so long,
Also upgraded the three front speakers to high efficiency horns.
I've been using studio monitors in my HT happily for the past 8 years but was getting bored and wanted something with bigger, more dynamic sound. I contemplated doing a SEOS build but picked up 2 x JBL AM5215's and one JBL AM6215 for my LCR on eBay for cheap. 98db efficient using JBL's PT waveguides, with 90 x 50 degree dispersion with a compression driver and 15" woofer.
http://www.jblpro.com/BackOffice/ProductAttachments/JBL_AM5215_95.SS.v1.pdf
http://www.jblpro.com/catalog/general/ProductFamily.aspx?FId=25&MId=2
In short, they are amazing. Huge sound stage, presence, slam, detailed but not harsh and play effortlessly loud. Easily powering them with a denon 4311. The only minus is they are lacking in bass so they absolutely need a sub.
Here are a few pics while getting them installed.
pocoloco is offline
post #105 of 112 Old 03-05-2014, 06:15 PM
cheezit73's Avatar
Quoted: 13 Post(s)
Liked: 24
Thanks for fixing the pics Pocoloco, your build has always been one of my favorites on the site!
cheezit73 is offline
post #106 of 112 Old 03-06-2014, 07:07 AM
Quoted: 27 Post(s)
Liked: 37
+1 on thanks for the pics. I love this build, which is in the financially acheivable but fantastic DIY realm.
post #107 of 112 Old 03-06-2014, 10:32 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
I certainly don't intend to hijack this thread but I wanted to share how much of an inspiration it was in my own room especially since I never got around to doing my own build thread.  Anyway, here's what I did as a result of this great build thread.  Thanks (again) to pocoloco for his inspiration and help answering my pm's!
Concept in Sketchup:
Rough framing of stage and false wall:
4 Frames around screen that would be covered in GOM:
Speaker stands added (subwoofer would eventually replace center stand as that's where REW showed the flattest response for a single sub):
Final product (with masking panels to convert 16:9 to 2.35:1 shown):
I'm currently in the process of building soffit style base traps to put behind the false wall to improve bass decay and FR:
Concept:
The traps will be burlap "socks" stuffed with pink fluffy and hung from the front wall:
jkasanic is offline
post #108 of 112 Old 03-06-2014, 11:18 AM
Rjloper9's Avatar
that screen wall looks great. very seamless and clean look!
Rjloper9 is offline
post #109 of 112 Old 03-06-2014, 12:02 PM - Thread Starter
pocoloco's Avatar
jkasanic... I was curious how yours turned out. Looks awesome!
pocoloco is offline
post #110 of 112 Old 03-06-2014, 12:06 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
thanks...couldn't have done it without you!
jkasanic is offline
post #111 of 112 Old 07-11-2016, 01:10 PM
El Gabito's Avatar
The two-year bump... someone else linked to this thread and just wanted to say that this is a very well done room. Any updates or are you happy with everything you've done?
El Gabito is offline
post #112 of 112 Old 07-15-2016, 08:13 PM - Thread Starter
pocoloco's Avatar
I'm pretty content. I craved a bit more mid-bass kick so I added two 12" subs behind the seats. Highly recommended. Other than that, no other updates. Just enjoying movies for once.
pocoloco is offline
