future proof cable wiring - AVS Forum | Home Theater Discussions And Reviews
Old 06-05-2008, 12:21 PM - Thread Starter
sladewatts's Avatar
Quoted: 13 Post(s)
I'm going to drywall my theater room in the near future and so am currently running wires through my walls. I'm doing component and HDMI to the pj. Is there another cable I should run now to make it more future proof? I'm setting it up so that I can always try to pull more cables through, but it will never be easier than now to do it.
On a related note, I'm growing concerned about the size of the holes I'm drilling through the 2x4s (note that they really are 2x4 as the house is 90+ years old). How big it too big? Are two smaller holes better than one big one?
Sorry if this is a redundant thread. I tried to do a search, but am feeling a bit lazy today.
Thanks a lot!
It's amazing that brain can generate enough power to keep those legs moving.
sladewatts is offline
Old 06-05-2008, 12:29 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
So are you doing conduit, for future proofing? Are you planning on connecting a computer to the proj.? If so a VGA/RBG cable is in order. Also might want to run a coupled of cat5 or cat6 cable just for the sake of running them. They can be used for many things that are often an afterthought. Good luck.
oman321 is offline
Old 06-05-2008, 01:09 PM
Weasel9992's Avatar
When in doubt, put the conduit in. Better to have it and not need it than need it and not have it.
I also agree with the VGA/RGB idea. Will you need speaker wire in the future?
Frank
Frank Oesterheld
Weasel9992 is offline
Old 06-05-2008, 01:23 PM
In2Photos's Avatar
I disagree with the VGA cable. With the resolutions going above 1080 VGA is useless, is it not? DVI and HDMI are todays prominent video connections for computers. A second HDMI cable would be a better bet, since you can buy a DVI to HDMI convertor.
Mike
In2Photos is offline
Old 06-05-2008, 01:34 PM
percept's Avatar
vga connections are also used for monitors...which have higher resolutions than 1080, no?
percept is offline
Old 06-05-2008, 02:29 PM - Thread Starter
sladewatts's Avatar
Quoted: 13 Post(s)
Yes, I'm planning on doing conduit.
Yes, I'm also doing speaker wires, but I'm not worried about upgrading them in the future (I'm assuming that's safe).
I thought about VGA, but decided against it b/c it seems like most computers have HDMI outs now, yes? I only really use the HT for DVD and Tivo, but I can see the computer as a possibility as downloads become more ubiquitous (though netflix has a box now for that too).
I don't understand how a cat6 cable would be of benefit going to a projector?
thanks.
Old 06-05-2008, 02:45 PM
BigSlade's Avatar
One thing I did was I put an outlet in the ceiling by where I had my HDMI cable ran and ran a power wire to another outlet on the wall where my equipment will be located. This is a closed circuit between the two points. Now, when i install my projector I will need to make a custom power cord with male ends on both sides, one side will be plugged into my surge protector and the other will be plugged into the outlet on the wall where my equipment is located.
BigSlade is offline
Old 06-05-2008, 03:10 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
BigSlade, you should only need one male end with what you are describing. The end in your equipment area is where you should have your surge protector the male plug there would then provide power to the other end which should be a basic outlet. You then have a protected outlet for your Projector/set.
oman321 is offline
Old 06-05-2008, 03:13 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
sladewatts,
If your gonna have conduit don't worry about it, but cat5/6 can be used for several thing including IR control, svideo, component, HDMI etc...
oman321 is offline
Old 06-06-2008, 10:29 PM - Thread Starter
sladewatts's Avatar
Quoted: 13 Post(s)
So, I went and bought 1" conduit today and couldn't even get my component video cable into it; to say nothing of the HDMI cable or anything else that I might want. But, I don't think I want to drill holes bigger than an inch through my 2x4s. What's the solution here?
Old 06-07-2008, 05:46 AM
Cathan's Avatar
2 inch conduit it your only real option for future proofing the projector. Doesn't put your cable in it though. You want the conduit empty so that it is there if you need to run something. You can order 2" raceway online. It ain't cheap.
http://www.hometech.com/techwire/resigard.html
And btw - I ran mine through a soffit. You are right that a 2 1/4 hole in a normal stud is too big.
Cathan is offline
Old 06-07-2008, 05:11 PM
Tedd's Avatar
Quoted: 922 Post(s)
Liked: 339
How about hiding a surface mounted conduit disguised in a faux ceiling beam? You build your own or use a commercial reasy to use product.
http://www.fauxwoodbeams.com/beams_regal.php
Tedd is offline
