I am looking for a guide for terminating Mini Coax cable with RCA Connectors. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 06-16-2008, 11:49 AM - Thread Starter
curtis104's Avatar
Here is a link to the RCA connectors I purchased. This is the Mini Coaxial Cable I am using. I have all the crimping tools for terminating RG6/RG59 and have had plenty of practice doing it over the past year.
Mostly I just need the length of how I should cut the conductor and outside sheath to.
Curtis
Xbox Live ID: Blaze104
MSI Media Live DIVA 5.1
Ahanix MCE701 case
LG Blu-ray/HD-DVD
3 Cable Card
1 HDHomerun
Windows 7 32bit
42" HP MediaSmart
WHS Norco 4020 case w/ WHS 2011
curtis104 is offline
post #2 of 16 Old 06-16-2008, 11:52 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 111
Mini-coax cable (not RG59) typically terminates with BNC connectors. I doubt you'll find a RCA crimp connector for that size of cable (it may be out there). If you need RCA, you'd terminate with BNC and then use a BNC to RCA adaptor.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Chairman
www.erskine-group.com
Dennis Erskine is offline
post #3 of 16 Old 06-16-2008, 01:05 PM
Quoted: 64 Post(s)
Liked: 111
My bad. Beldon makes a crimp on...part number HC2910A. The crimping tool is a bit pricey however.
CEDIA Chairman
post #4 of 16 Old 06-17-2008, 07:46 AM - Thread Starter
curtis104's Avatar
Thanks for the info. I guess there is no type of guide out there about the length the cables should be cut.
Curtis
Ahanix MCE701 case
LG Blu-ray/HD-DVD
3 Cable Card
1 HDHomerun
Windows 7 32bit
42" HP MediaSmart
post #5 of 16 Old 06-17-2008, 08:20 PM
jeffthx's Avatar
I have used Liberty multiconductor cable, which has worked very well for me (Solid 23 AWG RGBHV COMPOSITE CABLE - NON-PLENUM). The product shown on that link isn't exactly the same as what I have used in the past, but I got my cable a couple of years ago and they have changed the lineup slightly. This cable uses a 3-piece connector to make an RCA end out of the cable. I have used it to make component, composite, and S-video (using an adapter cable), and it offers flawless performance when terminated correctly.
The cable is not easy or intuitive to terminate (like standard RG6), and it is only because of my work with home theater installers that I learned how to terminate it myself (trained in person with a Liberty rep).
The cable requires a special stripper that strips the mini cable in sections, along with a crimper specifically designed to work with mini coax. I don't know if it's possible to terminate mini coax using standard RCA fittings, but I've never used a different brand of cable. The mini-coax fittings have a smaller opening, and they are designed to work with the gold-plated pin that is used with the Liberty cables. I could be wrong, but I'm not sure if you can easily mix & match mini cables and standard ends (and expect to get proper performance/fit).
With all of that said, I'll add that I'm not an expert on anything besides the Liberty brand, so take my comments with that in mind.
jj
jeffthx is offline
post #6 of 16 Old 12-19-2008, 08:38 AM
6344501's Avatar
Hi curtis104
Did you get it done yet.
I'm in the same situation as you now trying to run mini coax component cable for HDTV.
If you did, can you give me some guidance please.
6344501 is offline
post #7 of 16 Old 12-19-2008, 09:51 AM
Glimmie's Avatar
Quoted: 764 Post(s)
Liked: 638
There's no reason you can't just use solder on RCA connectors. That's what I do with mini coax. Even at analog HDTV frequencies, the impedance mismatch is not significant. Plus, most RCA connectors are not 75 ohm anyway. Canare makes a 75 ohm crimp connector but it's for RG59 cable.
Glimmie is offline
post #8 of 16 Old 12-26-2008, 07:46 PM
CJO
CJO's Avatar
They make crimp connections for mini coax too.
CJ
coneilliv at aol dot com
The Dark Knight Theater
(a bunch of good reference links and material in first 15 posts)
CJO is offline
post #9 of 16 Old 12-27-2008, 09:15 AM
Glimmie's Avatar
Quoted: 764 Post(s)
Liked: 638
CJ
Yes, they make BNC, but RCA as well?
Glimmie is offline
post #10 of 16 Old 12-27-2008, 12:23 PM
Grae's Avatar
There are a bunch of companies that offer RCA's in all different cable gauges. We use Liberty cable/connectors where I work. Termination is the same as any type of coax cable. 1/4" x 1/4" sheath and center conductor. You don't need special strippers for them either. You can find strippers that'll work at Home Depot if you need to. The grey ones with the orange removable center work fine, and they're cheap. You just have to calibrate for whatever type of cable you're using. If you're good you could also just use a razor blade to strip the cable. Fold back the braid, insert the connector, and crimp.
Grae is offline
post #11 of 16 Old 12-27-2008, 12:26 PM
Grae's Avatar
Also, make sure you get connectors that are made for the solid-core conductor. Some cable manufacturers have stranded center conductors which usually use a completely different type of connector.
Grae is offline
post #12 of 16 Old 12-28-2008, 12:23 PM
CJO
CJO's Avatar
RCAP-3CA and RCAP-3CF, if I'm not mistaken.
CJ
CJO is offline
post #13 of 16 Old 12-29-2008, 12:16 PM
Glimmie's Avatar
Quoted: 764 Post(s)
Liked: 638
CJ
Good to know. Thanks.
Glimmie is offline
post #14 of 16 Old 03-02-2009, 06:15 AM
TreyS's Avatar
Why not use the compression RCA ends instead of crimp on ends? They seem to be better quality.
TreyS is offline
post #15 of 16 Old 03-02-2009, 06:59 AM
CJO
CJO's Avatar
I have yet to see a compression RCA that competes with the quality of the Canare crimp-on ends.
CJ
CJO is offline
post #16 of 16 Old 03-02-2009, 08:17 PM
mikieson's Avatar
Those mini cables are a neat way to make many rca's and keep them nice and tidy and together...cool..
mikieson is offline
