Trying to find a MFR for a Coaxial Cable Patch Panel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-15-2008, 06:29 AM - Thread Starter
Bigchingan's Avatar
I'm looking for something exactly like this:
h t t p : / / www . l-com.com/item.aspx?id=8679
I tried to purchase this one over 2 weeks ago, but the company keeps giving me the run around about it not being in stock. I have a time sensitive project and need something sooner than that. I've been searching google & ebay for hours, but the closest similar item I can find are BNC patch panels. Anyone have any ideas where I can purchase one of these (and get it shipped very quickly)? I'd like to find one elsewhere and cancel my order at this other shady company.
BTW, requirements are it has to have at least 24 ports and be able to fit in a 2U rack mount enclosure.
Bigchingan is offline
post #2 of 6 Old 08-15-2008, 06:41 AM
carboranadum's Avatar
Quoted: 22 Post(s)
Liked: 26
I'm going to use a 24 port blank keystone patch panel for this. I have the unit installed in my rack, but have not added teh connectors yet.
Here's a typical unit without the keystone F connectors installed:
http://cgi.ebay.com/19-Rack-Mount-2U...QQcmdZViewItem
Here's the keystone F connectors:
http://www.cablesnmor.com/index.asp?...S&Category=172
CJ
carboranadum is offline
post #3 of 6 Old 08-15-2008, 07:13 AM
Staffy's Avatar
That is what I am doing on mine as well. That way you can use the panel to patch multiple things.
I am such a NOOB at A/V..
The "Not Hers" Build
Staffy is offline
post #4 of 6 Old 08-15-2008, 09:37 AM
eskay's Avatar
www.fpatchpanel.com
I don't know anything about them, but I'll probably order a panel from them soon.
eskay is offline
post #5 of 6 Old 08-15-2008, 10:21 AM
Quoted: 22 Post(s)
Liked: 26
Originally Posted by eskay View Post
www.fpatchpanel.com
WOW...24 port for $80? You can make 4 of them for less...
CJ
post #6 of 6 Old 08-15-2008, 10:28 AM
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
try this one 24 Port Keystone Blank Patch Panel Rack Mount You can put any thing you want in it:
Example:
This one has speaker connections, RCA jacks, F-connectors, and RJ45
GPowers is offline
